Question about Raymarine Raychart 435 GPS Receiver
Rc435 works but looses it's fix periodically
I have a functioning rc435 on my sailboat. I have noticed that it looses it's fix every few minutes and the alarm sounds. After repeatedly inspecting all connections...I finally decided to examine the gps antenna that is mounted on the rail. I opened the basic case...two screws ...and examined the rg58x cable and found some electrical tape wrapped about it. Although the plastic gates had been removed in the channel were removed the tape was at that point. I removed the tape and found that the outer casing of the cable had been pierced. I must assume that there is damage at that point. When I opened the antenna package further...6 screws...I saw that the cable is soldered to a printed circuit card. The center of the cable is obvious but the shielding is in a rectangular metal fitting that is crunched on the shielding and then soldered to the circuit board. Of course I cannot find the metal fitting anywhere. I was going to cut the cable before the damaged area and reattach to the printed circuit card. Any ideas? Is the cable just a connection of an antenna to the rc435 or is something more sophisticated such as power going to the antenna. The dealer who installed this is gone...defunct so I am on my own. Are there some rf considerations? I know that the metal fitting also provide cable strain relief.
The gates are to be removed only for surface mounting, and are there to prevent water ingress under the base. The cable would be crushed if the gate was not removed and the base was screwed onto the cable...
The antenna is powered from the base unit via the cable, but that's a simple DC circuit. The RF circuit is carried in the 'normal' way by the coax cable.
If you can clean the soldier from the scrunched fitting and get a good mechanical support, the soldier will provide the electrical contact. Be careful not to overheat the contact, and be sparing with the soldier when you reattach the braid. The braid is likely to be damaged / oxidized for some distance from the damage, so be sure you have enough slack in the cable. Raymarine's web site says you should see 4.8 / 7.2 Mega ohms of resistance across the antenna plug leads (different ohms depending on polarity of test leads) Good luck.
Posted on Oct 15, 2009
Problem with 2004 Kluger.
check for loose connection ( battery earth wire) or bad earth on units . check for loose alternator wires or loose fuses.
Feb 14, 2015 | Cars & Trucks
Faint beeping sound
Someone lose a cellphone? Could be a phone function for call message on the built-in sync. There is a speed alert function for going over a predetermined speed setting. There are traffic alert tones from the Mytouch Navigation. They even have an Alarm clock and interval Alert (every selected minutes). Could be a mileage count to tone after each passing mile.
Apr 09, 2014 | 2010 Lincoln MKX
A/c cycling switch 2005 toyota corolla
i ran into this problem. change A/C compressor relay. dealer has updated one.
Aug 12, 2012 | 2005 Toyota Corolla
Hello, I have just bought my Bavaria 36 in the netherlands. We have sailed her to Sweden a few days ago. The boat is equipped with a chartplotter RayMarine RC 435. During our trip we noticed the folowing:...
One thing you might check is for any corrosion in the 12VDC power cable at any point on the way to the unit. If the wires are somewhat corroded they will heat up as the unit draws power and the inherent voltage drop a from heated wires may lower the available voltage to the unit so it shuts down.
Jun 20, 2011 | Raymarine Rc435 Chartplotter
I have a BX900R that suddenly the red light came on and the alarm sound was constant - not beeping and the unit did not supply any backup power. The most recent status on the monitor program showed about...
If the device was still under warranty, you should call APC support and ask to send it in for repairs or replacement. Just keep politely asking, and ask to talk to their superior whenever they say it isn't possible and eventually you will get an RMA ticket/number.
If the device is not under warranty, you might be able to convince APC to service the device for a fee.
Mar 02, 2011 | APC Back-UPS XS900 (BX900) UPS System
Thinking of getting the TI150 3-in-1 Timer - Can it set to repeat a countdown over and over?
Review at Amazon seems to say the timer can repeat the same countdown each time button is pushed and countdown is activated.
Amazon review says:
http://www.amazon.com/General-Tools-TI150-Visually-Impaired/product-reviews/B001TOJG7Y/ref=dp_db_cm_cr_acr_txt?ie=UTF8&showViewpoints=1
The timer is easy to set. You just set the time, then hit the big "start/stop" button and the little "H" and "M" on either side of the timer display flashes.
To clear the timer, just hit both the "h" and the "m" buttons simultaneously. (so time has to be cleared)
To stop the alarm or to turn off the timer before the alarm sounds just hit the "start/stop" button.
On the back of the timer, there are 4 different on/off switches: flashing light alarm, sound alarm, vibrating alarm, and one for hours/minutes or minutes/seconds.
When I set the timer on my desk, it moved around when the alarm went off but when I turned off the vibrating function, the timer didn't move around.
If you need to turn off both the sound and vibrating alarms and use only the flashing light alarm, the light is quite noticeable by itself if placed nearby in your line of sight (within a foot or so). This would be very handy if you're near a sleeping baby! :) But if you clip it on a breast pocket, I would use both the flashing light and vibrating alarms. The vibrating alarm does make a sound, but it's not as loud as the ringing alarm.
Dec 27, 2010 | General Tools Hardware & Accessories
My 410 deville's channel switching doent work and is stuck on the clean channel. This really isn't a problem as I always use the clean channel and I only mention this in the event it helps diagnose the...
You may have a switch that may be bad. For the sound level high and low may need new tubes or possibly may not be seated fully into position. These tubes due get quite hot and do get loose over a period of time.Hope this helps.
Nov 13, 2010 | Fender Hot Rod Deluxe Guitar Combo...
In the last few days I have noticed that my thermostat goes from C to H in no time when driving and the little sailboat light comes on( like it needs water or something). I assume the car is overheating,...
i,ve worked on alot of these with the same problem and they were low on coolant due to a small waterpump leak that never hit the ground, check the level first, if not low then replace the thermostant.
Sep 15, 2010 | 2000 Dodge Grand Caravan
Raymarine Raychart 435 GPS Receiver Logo
429 people viewed this question
Top Raymarine GPS Experts
Shehu Pro
Shehu Pro
Steve
Steve
Are you a Raymarine GPS Expert? Answer questions, earn points and help others
