Question about Frigidaire ATF6000ES Front Load Washer
Tub has water in it
Did a load this morning, went to put another load in and started it, got to the spin cycle and it never started to spin, took stuff out of front loader and noticed that there was water still in it..
  • 332 Answers
Sounds like either the discharge line is clogged or the pump is not working, it could be working but getting ready to stop working and doesn't have the power to completly drain the tub, take the hose off the back if the water comes out the hose is clear and it is the pump, if it doesn;t come out then it is clogged
Posted on May 30, 2009
Whirlpool LXR9245EQ2 top loading washer tub won't fill
try taking the knob off and see if the nut is tight on the timer,it might if came loose
Jun 18, 2009 | Whirlpool Washing Machines
Whirlpool LXR9245EQ2 tub won't fill at beginning of cycle
HI, you have a combination issue. the Water fill level pressure switch and, the cycle selector switch are both damaged and, they should be replaced. the total cost of these switches will run you about $90.00.
We recommend the hands of a skilled service tech when repairing this type of electrical issue.
Kenmore direct drive,will not spin.
Hi, If the coupler is ok, you might have a spin basket drive going bad. You can try and put the machine in spin, put something in the lid switch activator slot and then try and start the tub with you hand.
I hope this helps you. Please let me know if I an assist you further.
Thanks
Vic
May 14, 2009 | Kenmore 24032\24036 Top Load Washer
Frigidaire (LTF2940E) Washer starts, stops, starts, stops...
The cycle doesn't advance When the cycle doesn't advance, it's probably the timer or a cold-water supply problem:
  • It's the timer, if your washing machine fills with water and begins agitating, but the timer never advances--or if the washer is in a spin cycle and the timer won't advance. Then you need to replace the timer.
  • It may be a cold-water supply problem, if the washing machine fills with water, agitates, drains, and spins, but then doesn't fill with rinse water. See There's no cold water.
May 07, 2009 | Frigidaire GLTF2940ES Front Load Washer
GE Top load washing machine stop and stars during spin cycle
I had the same problem. The machine will do the washing cycle. At the start of the spin cycle it would start turning with a lot of clicking sounds and then would stop spinning. The water pump would continue working without problem. The motor tries to start again in about three minutes, however, repeats the same behavior. I have a reasonable mechanical and electrical knowledge. I was sure that the overload protection switch of the motor was tripping. I opened up my machine---a GE super capacity top loading machine. Took off the belt and turned the transmission pulley. It turned easily in both directions (washing and spinning). Hence, the transmission was good. Next, I checked any water accumulation in the spin tub. If the water is not drained properly before the spin cycle, it would overload the motor. There was no water clogged in the spin tub. Finally, I dismantled the electric motor. There was a clutch assembly underneath the motor pulley. I dismantled it and found the clutch very dirty with some grease that had turned sticky. I cleaned the assembly thoroughly with alcohol and assembled back the machine. The machine is running perfect after that. Conclusion: The clutch assembly was mis-functioning. Reason: When the spin cycle starts, the spin tub is very heavy and cannot achieve the full speed quickly. On the other hand, electric motors must get to their running speed fairly quickly or else overheating of motor would happen. A proper functioning clutch allows the motor to run at their optimal speed while transferring enough torque to the spin tub to slowly speed up the tub to its fullest. In my case, the clutch was sticky, thus overloading the motor which would trip as it overheats.
Mar 31, 2008 | GE WDSR2080D Top Load Washer
"OL" error message
I believe that I had this same problem. The machine was skipping the wash cycle. After the water level rose to where you would expect the machine to go into an agitation cycle to wash clothes; it would start a spin cycle and drain the water. In the process of spinning it would stop to display the OL message over and over again as quick as you redistribute the load.
I found the problem to be clothes that got stuck underneath the impeller (round thing at the bottom center of the basket). Somehow I also had clothes get pulled down and got stuck underneath the basket next to the lint filter, these items were shredded to the point that they probably were not causing any issues, none the less they should not have been in there. Even though it was not the problem, I went ahead and took out and cleaned the lint filter since it was within reach.
This machine works a bit different then other machines. The agitation cycle is dependent upon the basket floating up and disengaging from the drive shaft. I guess the clothes that got stuck beneath the impeller did not allow the basket to float high enough to disengage from the drive shaft. Because the basket was still engaged to the drive shaft the drive motor would spin the basket and start a drain cycle rather agitate the load to wash it. The imbalance of the basket caused by the clothes stuck underneath the impeller kicked of the OL error since the basket was spinning at an unacceptable angle. I am not a repair dude but based on my observation of what I did to fix the problem this explanation works for me.
I've attached some pages of a repair manual that I found on-line to illustrate the areas that I am referring to.
Mar 16, 2008 | Whirlpool Cabrio WTW6600SBT Top Load...
Kenmore spin cycle thumping noises
I just went through the same issue with my Kenmore front loading washing machine. I assumed (and a Sears repairman also told me) that it is the bearings. After I took the drum assembly out, I saw the rear drum broken and the inner tub hitting the outer tub. I ordered the outer drum assembly and only when I took the inner drum assembly out I realized the the "Spider" attached to the inner drum (and spindle) was broken. Entire drum assembly cost $417 + shipping and it may be cheaper in the long run to buy a new washer. I like the front loaders because they save water and good for the environment, but the US manufacturers have not yet perfected the technology like European manufacturers (or they don't want the machines to last too long just like cars). Anyway, I am looking into welding the spider tomorrow. If not will return the outer tub assembly and buy a top loading washer for $300!
Dec 07, 2006 | Kenmore 44102 Front Load Washer
Bosch WFF 1800
There is no draining & this is why your spin does not work. There is only one belt. First siphon out the water from the machine via your front door. Clean out your outlet filter, check the tube from the tub to the filter. Luckily there shouldn't be a block in your outlet pump
Dec 07, 2006 | Bosch Exxcel WFO 2465 Front Load Washer
Frigidaire ATF6000ES Front Load Washer Logo
89 people viewed this question
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Jason Harris
Jason Harris
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
