Question about Canon imageCLASS D761 Copier
NP 6030 paper jam
When I try to print a 2 sided copy the paper jams after the scan and print of first side. Acts like the bottom half not working.
    Renaissance:
    An user who is expert in 3 categories / brands.
  • Canon Master
  • 1,362 Answers
It may be this simple:
1- as silly as it may seem, are you sure the size  is correct, if it is a letter size paper and it says legal, it will jam. open the paper tray and make sure the guides are snug againgst the paper,
does it say letter (or legal) for the tray you are going to use, if they do not correspond then look behind the tray inside the machine, is there a paper jammed in the back?
Or not so easy
2-You are having a sensor problem, take a look at the duplex tray,
pull it out and look at the sensors ( black little levers that stick out) are there any pieces of paper, can you move them and they spring back into place?
Posted on Oct 23, 2007
How do I clean toner from machine?
Probably it's the jammed paper that might caused the error. I suggest have it serviced by the technician. Be aware of the paper handling capacity of your machine to minimize jamming:
3300MFPV_X
Phaser 3300MFPV/X, Copy/Print/Colour Scan/Fax, B&W, 28 ppm, A4, 1200 dpi, 50-sheet ADF, 250-sheet Paper Tray, 50-sheet Multipurpose tray, 150-sheet Output Tray, 96 MB, Automatic 2-sided printing, USB/Ethernet, PCL/PS3, Scanning software, 220 V
Apr 28, 2014 | Xerox Phaser 3300mfpv/x Print Copy Scan...
Lanier ld040 paper jams
your web fell out, remove fuser,( lift handle on each side), take off web assy 2 screws 1 each side, rewind web and reinstall
Dec 03, 2013 | Lanier Ld 040 With Feed, Print, Scan,...
Can not copy two sided.paper always jam
Check for some obstruction in the paper path where the paper stops. There can also be paper cuts in some of the sensor arms that may be giving hesitation delys csusing the jams. Jam codes in service mode will also help isolate the problem to a more specific area.
Jun 17, 2011 | Canon NP 6050 Copier
Printer says paper jam, now scanner wont work
you will need to open it to remove this piece of paper.
Aug 14, 2009 | Kodak ESP 3 Multifunction Printer/ Copier/...
False jamming at duplex unit
Sounds to me like a paper jam switch has either become dislodged, or malfunctioned...you'll need a tech.
Feb 21, 2009 | Canon NP 6050 Copier
Help needed on ricoh ft 4015 copier
1-you need to determine if the two are part of the same problem
If the jamming occured first with no signs of copy quality issues then, it depends on where it's jamming. Locate the 1st jammed paper, the one that is furthest towards the exit. this stops all other paper after it. for example if there are papers in the fuser -by the drum and coming out if the tray the problem is most likely in the fuser area. Are the papers being crumbled? or just stop at that location?
2-the half dark copies could be a couple of things
a) the seperation unit is going bad and making the copies rise up against the drum
b)does the lamp that come on to scan the original stay on the whole lenght of the paper or does it turn off half way down the page? if yes the cable that connects to the lamp is probably broken and not making contact at the half way point as it is scanning.
Sep 17, 2008 | Office Equipment & Supplies
My Canon ir c2100 has a paper jam issue.
Have you tried to run copies from both paper trays? Will it jam in the same spot with both trays? If one works, but the other jams, it may be as simple as making sure the paper tray is set to the correct paper size? Is it set up in the paper tray as LTR, but the tray is saying LTR-R on the display. If so just change the paper size knob to the correct size. Also, if it stops in the same spot with all of the trays, look for something blocking it. Also, try to cheat the side door and make sure everthing is turning correctly.. Good Luck...
May 22, 2008 | Office Equipment & Supplies
Canon np 6030
Is it looking for toner or is there still a jam in it. You may want to try to turn it off and unplug the sorter and turn it back on. If that dose not work turn off again and unplug the adf and turn it on again. If that dose not work if you have unplug the bottom 2 trays. If one of those is causing the problem look deeper in to one of those units. Also, will it showw or flash a error code on the display?
Mar 18, 2008 | Canon NP 6050 Copier
Canon imageCLASS D761 Copier Logo
186 people viewed this question
old marine
old marine
