Question about Sony Cyber-shot DSC-W80 Digital Camera
Slight water damage- Sony Cybershot w-80 doesnt turn on
A little bit of water came in contact with camera... It now doesnt turn on.. how do i fix it?
  • Sony Master
  • 586 Answers
    Please contact any nearest SONY SERVICE CENTRE to rectify the problem.
     Thanksfor using fixya.
Posted on May 31, 2009
How you can eliminate the sign on E:61:00 the camera sony DSC T-5 series Cybershot
Hello and Welcome
The symptoms of this error is
  • After pressing the power button in capture mode, the lens would extend and a slight humming from what appeared to be the auto focus motor could be heard for about 5 seconds. When the motor stopped humming, the camera would beep and display E:61:00 in the LCD Screen.
  • Camera would extend the lens but not be able to focus on anything past 8 inches or so.
  • Zoom in and zoom out would not work.
  • Playback mode and the Setup mode was not affected.
To solve this
Put the camera about a half inch from a hard surface.
Let the lense go out and hit the surface and retract a little bit. Let it go out all the way when it tries the next time.
If that doesnt fix it, try this:
Turn it on and let the lense go out fully
See where the lens comes out of the camera? The little round crack that surrounds it? Wiggle the lense a bit and blow in there a bit. (Be sure not to blow on the lense!)
Now turn it off/on again, and it should be fixed
See the following video, It may also help you
Your Rating As Four Thumbs which are given below to this solution will appreciate me
Thanks and Keep using Fixya
Mar 11, 2011 | Sony Cyber-Shot DSC-T5 Digital Camera
E:61:00 on sony cybershot camera
To solve this
Mar 02, 2011 | Sony Cyber-Shot DSC-F828 Digital Camera
My camera Cybershot DSC-W150 has a problem with zoom
Sounds like your lens might be stuck. Do not force it closed or pull it out for that might further damage parts that are an integral part of its sliding mechanism. http://www.teleplancamerarepair.com/Sony_Cyber-Shot_DSC-W150 can repair this for you and they also clean your camera as part of the repair.
if there were any parts you were not able to put together after you opened it , make sure to very carefully put those back to go along with your camera.
Jul 08, 2010 | Sony Cameras
Problem with zoom and touchscreen
there is two problum in your camera one is lcd defective & other is lsv assy so please go to youe nearst sony service centre & fix these two problums
Apr 26, 2010 | Sony Cybershot DSC-T200 Digital Camera
Sony cybershot dsc-t77 fell in fresh water
Hello :
Please read this solution here . Please give the solution a try . It has worked with alot of mini devices just like your Camera .
good luck .
please don't forget to rate !
Apr 07, 2010 | Sony Cybershot DSC-T77 Digital Camera
Orange light stays on and camera doesnt switch on
Water is second only to fire as being the most destructive thing you can subject your camera to.
Sorry, but it is a write-off. Even after drying out there will be residual and ongoing corrosion and retained moisture in internal components. This is specifically why your warranty is invalidated by such damage and why no camera repairer will even attempt a repair.
All you can do is to see whether you can claim for accidental damage on any insurance policies which you may have.
Feb 11, 2010 | Sony Cybershot DSC-S950 Digital Camera
I don't know what to do... I have a sony cybershot... Turn it on and the lens goes in and out 3 times and then stays out then the lcd says turn camera off and on. Please suggest a remedy... camera just...
If the camera has recently been dropped you may have lens damage that's preventing it from powering up. If it hasn't been dropped your problem may be due to corrosion on the battery contacts inside the camera - which can prevent the full power of the batteries from flowing into the camera. Try this free fix before you do anything else: remove the batteries and wipe the camera contacts firmly with a dry cloth (heavy corrosion may require cleaning with a wire brush, steel wool, or sandpaper). Remove any residue that may have fallen into the battery compartment during cleaning, then clean the battery contacts, place the batteries back in the camera and give them a full charge (assuming that you're using rechargeable batteries). This cleaning clears the problem about 80% of the time. If it doesn't work for you, the camera may have a problem that requires professional repair.
Jan 08, 2010 | Sony Cyber-shot DSC-W90 Digital Camera
When i turn on my sony cybershot DSC-S950 camera, I get a message that says "Turn the power off and on again" and it just keeps coming up over and over again please help
OK you are probably going to think I am loony giving you this advise But No I am completely sane!
Get a can of compressed air OR acces to a compressor at your local garage Get them to fit the triggered air blower tool to it.
Blow around the lens in all the extension joins the firmly slap it in the palm of you hand with the side of the camera making contact with you palm. Do the procedure two or 3 times and inbetween the slaps turn it on to activate the lens mechanism. I have now fixed about 80 of these cameras with this method. I obtained the fix from Sony who charge $90 to do exactly the same. Keep at it as it will eventually work. One tip, make sure the battery is charged before you do this.
Please rate our help++++Thanks for using FIXYA
Oct 09, 2009 | Sony Cybershot DSC-S950 Digital Camera
Sony Cyber-shot  DSC-W80 Digital Camera Logo
165 people viewed this question
Top Sony Cameras Experts
james laughton
james laughton
JonSnell Electronic
JonSnell Electronic
Are you a Sony Camera Expert? Answer questions, earn points and help others
