Question about Maxtor OneTouch III Mini Edition 120GB External USB 2.0 Portable 120 GB IDE Hard Drive
Other computers dont recognize my Maxtor OneTouch 4 Mini
It even won't recognize it when I plug it in. nothing happens. The light comes on but it starts beeping i can't install my external hard disk I installed my Maxtor OneTouch Mini 160 GB on my laptop and it successfully opens. But when I try to open it on other computers, it says, hardware recognized and its light goes on, but when i open "my computer" nothings there!
  • 154 Answers
Please Make sure you External Hard disk USB cable is working correctly. Your cable is probably having partial contact, so try another cable
Posted on Apr 09, 2010
2 Suggested Answers
  • 155 Answers
SOURCE: I need software for Maxtor (160 gb) onetouch 4 mini OS X 11.4
Maxtor is now part of Seagate, so your first step should be http://www.seagate.com
Posted on Dec 09, 2009
When I plug my maxtor in, I can hear it "thinking"
use an external usb ide( or if your hdd is sata,then use a sata cable)then insert to a working computer then you can copy your files
Feb 19, 2011 | Maxtor OneTouch 4 Mini 160GB External USB...
I changed my windows to vista and then i tried to re-install my maxtor one Touch 4 mini 250 GB but the computer can not recognize it, so plz tell me what is the steps to re-install thx
By 'install' I think you mean install Maxtor Manager, but perhaps you have files which were saved by 'drag-and-drop' with the previous OS. These might be recovered the same way, even in Vista, if you can open the OneTouch from Control Panel. To use Manager with the OneTouch which had stuff saved via Manager with a different OS, you could first try to recover the files with Manager installed on another PC using the old OS version. Then format the OneTouch through Control Panel in Vista and with luck Manager will recognise it. If it does not, and you can see the drive in My Computer, then uninstall Manager (which might be corrupt) and try re-installing it. Regards Chas
Nov 28, 2010 | Maxtor OneTouch 4 Mini 160GB External USB...
I cannot get the computer to recognise the Maxtor device. I had it working 18 mths ago and have now just reconnected it. Not sure if I have all things plugged in correctly but can't find a diagram of...
The correct lead should be Y shaped and two of the limbs plug into two USB sockets on the PC, the third lead has a small jack which goes into the OneTouch. It should light up if it is getting power from the USB and there should be an icon showing for it in My Computer.
Aug 17, 2010 | Maxtor OneTouch 4 Mini 120GB External USB...
Hay i am having Maxtor OneTouch 4 Mini (160GB).it does not detected by any computer except where its software is installed.plz ans immed
I've had this problem before (something similar) you'll need additional software from Maxtor.com so you're PC will recognize the new drive.
Jul 18, 2009 | Maxtor OneTouch 4 Mini 160GB External USB...
Light turns on but My Computer does not recognize the drive
Sounds like you lost the drivers for your external. W/ out an online PC you cannot download them either. Do you have a friend that could do this on their PC? That is the only way.
Feb 16, 2009 | Maxtor OneTouch III Mini Edition 120GB...
Maxtor One Touch 4 is beeping when I connect it by usb
Does the HDD spinup?
My slightly educated guess... the Ext 2.5in HDD requires more power than it is getting from the single port.
1. Try another port
2. Try it on another computer (all USB ports do not provide 250ma to a load)You may be sharing this avail voltage with all plugged in devices and will have to pull 1-2 others to get the HDD online. Since STARTUP current is high, the HDD pulls all it can from the ports (logical) then settles down and uses 1/3 to keep spinning. After the HDD is up and online, try plugging the other USB devices back in, 1 at a time. If it stalls the HDD - you know the why
3. Take it back and find something a bit less power-hungry (Like Hitichi or Toshiba)
Jan 16, 2009 | Maxtor OneTouch 4 Mini 120GB External USB...
Maxtor OneTouch 4 Mini 250GB External Drive Does not show up on my computer
I have a Onetouch Mini 4, operating fine on two computers with Windows XP but couldn't get it working on Windows 7. I plugged it in and it would be recognized but a message would come up saying there were errors and to scan. Tried scanning and not scanning and couldn't get the drive to work. If I tried to open it would give me the "access denied". I couldn't get to a security tab from a folder as none of them were working.
It ended up that I wasn't listed as an owner nor had any permissions so I needed to be added to the device.
Here is what I did -
System, device manager, disk drives, right click on onetouch, properties, volumes, populate, the select on touch volume, properties, security, advanced, change permissions, add, typed in my user name - hit checked names (it fixed the format), then hit ok.
Then make sure you set the permissions for all the users.
Sep 08, 2008 | Computers & Internet
Are you connecting Drive via a USB hub or direct into two separate USB sockets on PC?
May 05, 2008 | Maxtor OneTouch 4 Mini 160GB External USB...
Maxtor OneTouch III Not Recognized by XP
sounds like the USb Port is burned out, might as well chuck it
Jan 09, 2008 | Maxtor OneTouch II external hard drive...
Maxtor OneTouch III Mini Edition 120GB External USB 2.0 Portable 120 GB IDE Hard Drive Logo
539 people viewed this question
Top Maxtor Computers & Internet Experts
Computer Links
Rick Arnold
terminalcon
Are you a Maxtor Computer and Internet Expert? Answer questions, earn points and help others
