Question about Lexmark All-in-One Printer with PictBridge
Lexmark 2500 - just replaced both ink carts; still says I'm empty
New carts in, but it won't print. Insists I'm out of ink! Carts came right out of foil wrap. I am having the exact same issue. I called walgreens and asked if they refill my cartridges (28,29) they told me that 28a and 29a are the same thing and I brought them in. Now I cant get the printer to recognize that they are there.....
  • candyman1378 May 31, 2009
    Spoke with a manager at Walgreens. She confirmed that they should not have filled them and offered me a refund...too bad they want to keep the cartridges and I can no longer send them back now.....
  • 221 Answers
Please unplug the printer from the computer, and from the ac-dc, replug it. Turn off the computer and reboot it. Make sur that every cartdridge is well installed,
Hope this helps
Posted on May 30, 2009
What cause lose of new ink on aligning cartridges.
Unfortunately, the printer does not actually measure the ink in the carts, but measures how many droplets called for. The carts may actually be full, but the printer now thinks they're empty. Most likely the black ink needs to be "charged" because you've cleaned out the pipe. I don't know what to do to charge it, and you'll likely need new carts.
Sep 11, 2014 | HP Officejet Pro 8500 All-in-one -...
Put new lexmark cartridges in my 8350 but still shows empty
It sounds like the carts are a little defective. This sounds like the situation that occurs when these carts are refilled. The only thing I think you can do is either have them replaced where you bought them, or just go into the printer properties and go to supplies page and uncheck the ink levels monitor box. This will disable the printer giving you an alert when you print....
Mar 10, 2009 | Office Equipment & Supplies
Continue to get "empty" messages after replacing both ink cartidg
hi... try these steps
>unplug power adaptor and plug it back in
>try to identify whick cartridge is giving u trouble..black or colour by inserting carts one by one
>if sam ething happens..contact tech support on 800-332-4120..printer would be replaced
Feb 12, 2009 | Lexmark X2500 All-In-One Printer
Refilling lexmark cartridges x2500
Hey....I solved the lexmark out of ink problem!!!HA!!! what you have to do if you want to refill these is "pop" off the top of the cartridge. It is not easy as it is glued down...using a small screwdriver preferably a small flat jewelers screw driver you can peel back the plastic that seperates the "lid" of the ink cartridge. you have to use a little force but you can get it off. Once you do this the cartridge will always read full!!!!!! just tape it or super glue it back on. You never have to take it off again! although I recomend cleaning the ink sponges inside every 3 refills. but this works great.....ha ha lexmark.....I got ya!!!!
Jun 03, 2008 | Lexmark X2500 All-In-One Printer
Refilled cartridge does not work
First of all lexmark doesnt support refill carts. but what u can do is reseat the carts & then press the options button till u see cart new both. & then select both the blk & clr as new. it should work other wise buy new carts
May 27, 2008 | Lexmark X125 All-In-One InkJet Printer
Lexmark X2500
1.Cleaning the copper contacts on the carts as well as the copper contacts inside the cartridge carrier......
2. Remove the carts....and install the carts thru the solution center...(Start-programs-lexmark-solution center-maintenence -install carts) while installing the carts choose the option "new carts"
Leme know if this has helped u
Dec 08, 2007 | Lexmark All-in-One Printer with PictBridge
My MFC-210C always says replace ink.
Try this: Unplug machine from power. Wait 5 min.  Open scanner cover and take the carts out of the holder. Close cover. Plug machine to power. Machine will cycle and demands the carts. Use all NEW carts: Insert carts as demanded and answer question shown on display.
Always print until machine STOPPS printing because of EMPTY cart. Change cart then and machine will print the rest of job!
Plz, never change carts when it says NEAR EMPTY: This will cause a lot of trouble ;-)
Nov 18, 2007 | Brother MFC 210C All-In-One InkJet Printer
First, wouldn't print black, now won't print magenta- all new cartridges!
Unplug machinepowercord. Open printer and take all carts out. Plug in power. Machine demands carts. Put new one in: Replace with original ink carts!. When asked push 1 (yes New cart). If you have used thirdparty carts, there could be a prob due to construticon or ink quality. In case there is no bk after 3x cleaning cycles anymore, the head is clogged: This happens because the filter in front of the nozzels is clogged by pigmented ink. DO USE ONLY DYE INK for all types of brother inkjet machines!!!
Sep 24, 2007 | Brother MFC 420CN All-In-One InkJet...
Inputting new ink cartridges
Error 1102 means cart error. Try cleaning the copper contacts on the cart and the contacts in the printer also. If still fails, then put old carts and check if u still get same error. If u dont get the error then there is a problem with the cart itself. But if you have bought a refilled cart then the print heads on the carts are bad. Needs replacement.
Sep 19, 2007 | Lexmark P4350 All-In-One InkJet Printer
Lexmark All-in-One Printer with PictBridge Logo
607 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
