Question about New World 60ESO Electric Kitchen Range
Oven stopped working
Hello I wonder if you can help.
The oven of our new world 60eso jsut stopped working.
The grill and gas still work fine.
Any ideas what might be wrong with it?
Thanks in advance
Gavin Colborne
gavin@planet.nu
  • 1 more comment
  • Anonymous Jan 02, 2008
    oven stop working
  • Anonymous Apr 05, 2008
    gas burners work fine but oven doesn't. Even the broil stopped working.
  • suziebinxs May 29, 2008
    the gas supply to my hobbs have stopped but the grill and oven still works fine. why is this
    Habit-Forming:
  • 171 Answers
Replase the oven ignitor it's located nest to the oven burner.
Posted on Dec 11, 2008
Why has my oven and grill stopped working?
manufactor have recalls check the website to see if it includes your item. electronic controls due go bad
May 26, 2014 | New World G70m Gas Double Oven
Gas oven stopped working
Sure i will be able to provide you solution
Apr 15, 2008 | Ovens
I have a Leisure Gourmet Classic double oven. The hobs, the grill and the upper oven all work fine, but the lower oven suddenly stopped producing any gas. I turn the knob and the austomatic ignition s
Apparently there is a bad valve for that oven , recommend calling a gas service repairman . your gas provider should be able to recommend a good one to you .
Apr 19, 2017 | Leisure Kitchen Ranges
Hello. I have an AEG electric oven which is
It seems like the element around the fan in the main oven has most probably burnt out and will need replacing.
Hpoe this helps,
May 04, 2010 | AEG B1180-4 Electric Single Oven
Oven door open or shut when using grill?
Leave the door open in the broiler position, about 4 inches.
Jan 06, 2010 | Ovens
Grill ignition is sparking when the oven is on
if the grill is constant sparking when the oven was on and turns off when the oven is not in use then u either have a defective pcb/ht lead or electrode if it is self lighting or if you have to push in a button then this button or control will have a problem
Aug 21, 2009 | New World G70m Gas Double Oven
New World TGO 70 grill not working because door was closed
THIS IS PROBABLY BEST LEFT TO A QUALIFIED ENGINEER. To reset the grill thermal cut out. This is located under the metal panel at the top of the unit and it is necessary to ether partially or fully remove the whole oven from its housing to get at it. 1. Disconnect electric supply. 2 remove the 2 housing retaining screws. These are located either side of the at the top of the grill cavity. 3.Pull the whole oven /grill unit out and support it underneath to stop it falling forward. 4. Remove metal cover covering top of oven. 5. the safety cut out is a small component that has 2 wires connected to it by spade terminals, in the middle of which is a small red button. push this button gently with the end of a pencil or screwdriver until it clicks. This should now be reset and allow the gas supply to the grill to resume. Finally reassemble making sure that the integrity of the gas and electrical supplies are, in no way compromised and test.
Aug 20, 2009 | Ovens
My grill won't light
Hi
Forgive me for asking this, but you have read the instructions haven't you?
If you have, and it's still not working, then the likelihood is that there is a fault, this could be one of the following:
Faulty solenoid valve to grill (some grills had a safety button fitted to stop you from closing the door if the grill was being used)
Blocked pipe inside unit
Either way you need to get a qualified gas engineer to take a look at it, if it's under warrranty call the manufacturers first!
I hope this helps
Steve :)
Jul 14, 2009 | New World G70m Gas Double Oven
New World 60ESO Electric Kitchen Range Logo
236 people viewed this question
Top New World Kitchen Ranges Experts
Ismael Rodriguez...
Paul Carew
John Rodgers
John Rodgers
Are you a New World Kitchen Range Expert? Answer questions, earn points and help others
