Question about Dell Latitude CPI-D Notebook
Hard Drive not found
Installed a new hard drive power on comes up with Primary Haed Drive 0 not found
  • 35 Answers
Try checking this issue using some other HD if the other one works fine then get this one replaced..
Posted on Jun 20, 2009
Had a problem with my drive getting on internet installed new hard drive now can not boot up dont see drives
it sounds that you have problem in the mother board, you can hooked up your drive to other pc as slave just to ensure if it will read. if ok, then their is no problem in your hard drive also with other drive.
Nov 19, 2012 | Dell Dimension 5100 (D51L1) PC Desktop
Dell: Primary hard drive 0 not found Primary
Sorry, but this isn't a good sign. Drive 0 is most likely your main hard drive, and only if you have a second one would you computer ever find anything on Drive 1.
I would check the connections inside from the motherboard to the hard drive, as well as from the power supply to the hard drive.
Here's the manual: http://support.dell.com/support/edocs/systems/opgx60/en/ug/sffabout.htm#1103481
Also, if you boot your computer to the Dell copy of Windows, go through the motions of reinstalling Windows and you probably won't be able to detect any drive to install it on.
You'll most likely need to replace the hard drive altogether. Sorry!
Hope this was helpful for you (even though it was bad news)! If so, please give a rating!
Mar 09, 2010 | Dell Optiplex GX60 PC Desktop
Cloned hard drive "C" (WD 40GB) to A Deskstar 8oGB using external enclosure. When I remove the old drive and install new drive and boot up I get Msg drive 0 not found retry or enter setup. If I enter setup...
there are few thing you ahve to keep in mind
there are two type of hard disk
1. IDE
2. SATA
As per your hdd capacity it should of IDE type.
Now there are two IDE slots on motherboard. One is Primary and other is Secondary
You can fix two hdd with one IDE Slot that mean you can fix up upto faour IDE hdd at a time
Now again there are Primary master and Primary Slave
and
Secondary Master and Secondary Slave
Now You have to examine what was the location of previous hdd
1 Primary Master
2 Primary Slave
3 Secondary Master
4 Secondary Slave.
Now you have to make a HDD master or Slave.
just in between data cable connector and power cable connector there is a jumper. that specify the master or slave. do reply me if it works well thanks
Oct 01, 2009 | Hitachi Deskstar 7K250 80GB...
Primary hard disk drive 0 not found no bootable
Your hard disk is disconnected, or not configured correctly in the CMOS. Go to the BIOS and be sure that the computer recognizes the hard disk. If doesnt happens, check the connectors, and if it doesnt fix your problem, you need a new hard drive.
Jul 18, 2009 | Dell Latitude C640 Notebook
No bootable devices-strike F1 to retry boot,F2 for setup utillity
Is there a hard disk installed inside the computer? try reconnecting it.
The motherboard, the hard drive, or the connector could be faulty in this case.
Remember to unplug and remove battery if you open the laptop, the hard drive is in most cases in the bottom under a cover with few screws or in some dells its on the side with few screws and comes out from the side instead from the bottom.
May 22, 2009 | Dell Latitude C600 Notebook
Dell dimension 2400 diskette drive 0 seek failure
Check your BIOS setting to see if it detects the hard drive (Primary disk 0). If it can't detect the hard drive then the hard drive maybe faulty. Open the case unpluge the IDE cable from the hard drive and reconnect it again, also unplug the IDE cable at the motherboard and reconnect it again including the power connector on the hard drive.
There maybe an option to test the hard drive in the BIOS, if so use it to test the hard drive.
If the hard drive is faulty, you need to replace it and install Windows, the various device drivers and your programs to get a functioning computer again.
You might consider buying a new computer (it will be faster & better than the old Dell) and you have your new monitor to go with it.
May 21, 2009 | Dell Dimension 2400 PC Desktop
Dell inspiron 5150 primary hard drive disk 0 not found
You may find that either the cable is not connected properly or is faulty, or the worse case the mother board has problems (driver, chips, breakages)
May even be a power supply problem, as the power supply has many output points and different voltages that the HDD power out may have blown. If it has then the rest of the system will appear to be ok.
So first off, check the cables connections on the motherboard, and look for any breaks in the cables, and if you have a power meter of some sort check the power connection, or plug in another power connector, the ones with the same end are generally the same power outputs. The ribbon cable for the HDD should have 2 sockets for HDDs and you must connect your HDD to the end one.
May 14, 2009 | Dell (U0614) for Inspiron 5150 60 GB Hard...
Replace A Hard Drive On E-Machines ?mperial motherboard glve
First, check the jumpers on the back of the drive to ensure that it's set for master. There will be a legend on the drive label explaining where the jumper needs to be to achieve this. If it has been used as a system drive previously you won't need to worry about this.
Second, physically fit the drive into the tower and connect the IDE ribbon cable. The motherboard end of the cable should connect to the primary IDE slot. To identify which one is primary look closely next to the two slots, they'll be marked IDE 0 and IDE 1. IDE 0 is primary. Connect a molex power connector to the back of the drive from the PSU.
Since this drive has been used previously you should now be able to install your chosen operating system from a CD or DVD. XP and Vista both have options for creating/deleting and formatting existing partitions during setup.
These are simplified instructions and assume that it is an IDE drive and not SATA and that no second hard drive will be installed on the same IDE bus. More detailed instructions can be found here:
http://www.helpwithpcs.com/upgrading/install-hard-drive.htm#install-new-hard-drive
Hope this helps,
erch.
Mar 14, 2008 | E-Machines EMA IMPERIAL GV (845GV) TG3...
Sony Dual DVD +/- RW
set the hard drive to master and the dvd to slave
Jan 24, 2008 | Computers & Internet
Dell Latitude CPI-D Notebook Logo
mukhtar21 shaikh
mukhtar21 shaikh
