Question about Admiral 26 cu. ft. Side-By-Side Refrigerator
Moved refrig this morning and now it is not cooling... freezer works great
I have a Admiral side by side white refrigerator that's about 9 years old ..I have never had a single problem with it ... I got a new black refrigerator yesterday ( remodeled kitchen ) and gave my mom my old white one... we moved it about 6 hours ago over to my moms house about 1/2 mile away... Freezer is working great... food frozen solid... the refrigerator is only cooled down after 6 hours to 50 degrees.... it was plugged in before we moved it and was cold... any ideas why the freezer would be working great and the refrigerator not seem to be cooling to the degree that it should...
    President:
  • 1,136 Answers
Hih, Check and see if something has stopped the condenser fan motor down by the compressor from turning. Sometimes this happens in a move.
Also make sure the controls didn't get turned to wrong settings. Make sure evaporator fan motor is working in freezer and that there is no frost building up on the rear panel.
Just some ideas to help you.
lease let me know if I can assist you further.
Thanks
Vic
Posted on May 30, 2009
I have a Whirlpool Refrig. model GX5FHDXVY04. The freezer is working properly but the refrigerator is not cooling. I noticed frost on the inside back panel of the freezer. I turned the temp down in the...
Many of frost-free fridges use fans to move a controlled amount of air into the upper or side cooling chamber, check for non-working fan or a stuck or malfunctioning damper control. Keith L.
Mar 02, 2012 | Whirlpool 24.8 Cu. Ft. Side-by-Side...
Refrigerator does not cool below 50. Freezer side is ok
all cooling comes from thefreezer, lower down air flow to freezer and increase air flow to refrigerator, this should help.
Apr 08, 2011 | Admiral 26 cu. ft. Side-By-Side...
Side by side Admiral freezer freezes but fridge
check the damper vent door between the refrige and freezer and make sure its opening up to let cold air from freezer into the refrige,sometimes they freeze up and cant open and close when called upon to do so,if so deice it with a hair dryer,the side being hot is good telling you the compressor is operating correctly
Jul 28, 2010 | Admiral 26 cu. ft. Side-By-Side...
Cold but not frozen
23 years old ? That thing was costing you more than a new unit would cost for the past 5 years!
Assuming your airflows are good, Its time for a new refrigerator.
Aug 29, 2009 | Refrigerators
Admiral refrig
thats the fan hitting ice. sounds like a defrost problem. does the back of the freezer panel have any frosty ice build up?
Aug 18, 2008 | Maytag MZD2766GES Side by Side...
Same as 6-9-08 freezer ices up, frig won't cool
Not sure if this will help but I have/had a similar problem with my admiral side by side (approx 12 yrs old not sure of the model #)and I think I fixed it this morning..
At the back of the fridge compartment I removed the cover (covers the light and controls) the Freezer setting just seems to adjust a flap that sends cold air into the fridge.. around the flap was a mass of ice.. what seemed to be happening was as this 'vent' was blocked with ice no cold air entered the fridge and the temp stayed high and hence the stat did not cut out .. compressor running flat out 24/7..... I removed the ice and it now seems to be working better (2-3 hrs will see what its like when I get home from work..!)
Jul 09, 2008 | Admiral 26 cu. ft. Side-By-Side...
Wards/Admiral refrig/freezer
I put the fridge in manual defrost by advancing the timer. The defrost heater worked so the problem was with the timer not advancing to defrost every 6 hours. The plastic gears wear out over time.
Apr 18, 2008 | Admiral 26 cu. ft. Side-By-Side...
Admiral 26 cu. ft. Side-By-Side Refrigerator Logo
197 people viewed this question
Top Admiral Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you an Admiral Refrigerator Expert? Answer questions, earn points and help others
