Question about Maytag Atlantis MAV6451 Top Load Washer
Washer recently started turning my sage colored towels gold
My Maytag washer recently started turning my sage colored towels gold! I have not changed detergents (have used a plant-based one for several years now) or fabric softener (use Downy Free and Clear) and I do not use bleach. Any ideas?
  • 332 Answers
You have hard water think about putting a filter in line before it goes into the washer or the whole house,
Posted on May 30, 2009
  • gary miller
    gary miller May 30, 2009
    you have hard water think about putting a filter in line before it goes into the washer or the whole house,
My maytag neptune washer is spotting my laundry - especially light colored towels with possibly an oil spot - about the size of a dime or sometimes quarter. I tried running a cleaning disc thru it twice ,...
f you use cold water wash and rinses regularly it may have an accumulation of un-dissolved detergent, dirt/grime and body oils stuck on the inside wall of the outer tub. When washing whites I assume that you are using Hot water and it could be causing some of the accumulation to break loose in small clumps and re-depositing on the clothes.
Jan 10, 2011 | Maytag Neptune Washer
My towels smell and I have to rinse at least two additional times. Have changed detergents always using HD, use more, use less, stopped using liquid softner.
Run a load of whites (or with no clothes) with bleach to kill any mildew or bacteria build-up in the washer. If you have your own well, install an anti-bacterial and odor removal filter in the water line.
The first time you wash towels after doing this, pre-soak the towels in water with a "color-safe" bleach to get any little stinkers hiding in them. Also, disinfect your towel storage and any place where they are hung after use, and after that make sure the towels are dried out before they are thrown into the laundry basket unless they are going to the washing machine immediately.
Dec 30, 2010 | Maytag MAH6700AWW Neptune Front-Load...
I am sick of my washer smelling all of the time. We have done all the things that others have stated to try. I think that there should be a recall on the Frigidaire front load washer. I am very sorry...
Maytag is not american anymore. You will have the same problems. Front load maintenence 101.
dont use natural or green detergents that are plant oil based. Use HE detergent only, powder is preferable. Leave the door open for 24 hours after the last wash load is done. mildew can not grow in the absence of moisture. Once a month run the washer empty with 2 cups of bleach on the hottest setting possible. If you dont do this from day 1, you may have to do it several times to get rid of the built up gunk.
last tip, and the most important. dont use too much detergent. HE washers use much less water than a regular washer. If you put a ton of soap in there, it will build up over time because your washer doesnt use enough water to rinse it out. If you start a load of laundry with no soap, but you see bubbles in the water, it means you have too much soap residue in your washer.
use good quality detergent. Save money by using less of it, not by using cheap detergent. Unless your clothes are really dirty, you can safely use half of the recommended amount.
Nov 21, 2010 | Frigidaire GLTF2940ES Front Load Washer
Recently our Maytag Performa washer has started
The transmission might be going bad.
Nov 02, 2009 | Washing Machines
Our towels and clothes have a mildew/musty smell. when I spin the stainless drum inside, i can hear water sloshing around.
Towel mildew odor is transferred from the washer to towels and clothes. The washer must be cleaned first. After cleaning the washer and towels washing habits must change to stop mold smell from returning.
Washing machine mold / mildew is caused by:
#1 cause is overuse of detergents. Detergent companies are notorious for instructing to use too much detergent. Especially with soft water or when using liquid detergent no more than 1 tbsp of any detergent should be used.
#2 most common cause is using fabric softener because it's dispensed in the rinse cycle and will coat the inside of the outer tub with residue that is a food source for mold to grow.
#3 using only cold water for washing is fine but makes preventative maintenance very important. A weekly hot soak will dissolve odor-causing residue from inside your washer.
#4 not using the washer. If the clothes washer isn't used very often maintenance is especially important. If leaving for a vacation it's a good idea to clean your washer. Do a search to "remove washer odor" to read just how big the problem is. There are all natural washer cleaners that will also remove mildew odor from towels and clothing after the washer has been cleaned.
Oct 06, 2009 | Maytag Neptune MAH5500B Front Load Washer
Stale odor in machine and on towels and clothes. I have used the affresh, Bleach, baking soda, use powder HE detergent, no liquid fab softner, I am at the end of my rope with this stinking machine ready to...
Towel mildew smell is being transferred from the washer. The washer must be cleaned first. The problem is not "brand specific" all clothes washers have mold growth to a certain degree. Bleach or vinegar will kill the mold inside your washer but won't remove it or the residue it grows on thereby making the situation worse because it leaves a "base" for more detergent to collect on and more mold will grow.
Washing machine mold / mildew odor is caused by:
Sep 11, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Odors on the clothes after washing in Maytag front loader
The brand of your front loader is not that material on this issue. What is happening is that your old top load washer may have used as much as 45 gallons of water per cycle, while some front loaders use as little as 12. Because of the low water use, you must cut back on the additives you are using. Use only 1 tablespoon of HE detergent (even less if 2x or 3x detergent) per load. If you use fabric softener, use only 1 teaspoon per load. Odor on clothes after wash is indicating that the detergent and or softener has not been fully rinsed out. If you throw a load of washed towels into your machine and start a cycle without any soap, then stop the cycle, you should not see any suds. If you do, there is obviously soap left in the clothes. With bath towels, the towels are used to absorb clean water off a clean body. They do not need soap when you wash them, and never use fabric softener on towels.
Oct 23, 2008 | Maytag EPIC MFW9700S Front Load Washer
Musty smell on towels
I had this problem last year. I was not using HE detergent. The other detergent was causing soap scum to build up in the drain hoses. After they were cleaned (it took more than one time taking it apart and cleaning), and we started using HE detergent, it worked fien with no odor.
Jul 14, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Detergent goes where?
MLG2000A - Maytag Neptune Super Stack SL-3
1 - Select Wash/Rinse Water Temperature
2 - Select Options (Max Extract, Extra Rinse, Signa)
3 - Select Cycle
4 - Load the Clothes Washer (add detergent on top of the load in the tub, and additives [fabric softener, bleach] in their dispensers).
5 - Start the washer.
This is according to the owner's manual I have. Has worked for 9 years for me.
Jun 28, 2008 | Maytag Neptune MLG2000A Front Load Stacked...
Streaks in towels/sheets
From experience, Bleach will stay in the machine and bleach load after load (esp with an enamel or poly drum). Normally have to run a HOT empty cycle to clean it out.
Sep 15, 2007 | Whirlpool Gold Duet GHW9400P 3.8 Cu. Ft....
Maytag Atlantis MAV6451 Top Load Washer Logo
89 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
