Question about RCA Analog (RCA) to Digital (VGA) Converter for PC (displays TV image on PC) (AD01)
No channels found with automatic channel search
We purchased a RCA Digital TV converter box to use at our cottage. It is located west of Crivitz, Wisconsin. We had no problems with the set up. The TV is a Philips brand. After completing the channel search, no channels were found. Prior to this time, we received, in this area, channels 2,5,11,26, and 32 without any problems. We have an outdoor antenna that is at least ten feet above the roof of the cottage. Any suggestions as to what to do next? I am currently at home but we plan on going up to the cottage next weekend again. Thanks
    Master:
  • 469 Answers
    Master:
  • RCA Master
  • 708 Answers
Bought vga to rca and works perfit,details information pls click Amazon com MALLCROWN VGA to RCA Converter PC VGA TO TV Convert VGA to AV...
Posted on Nov 21, 2016
  • 864 Answers
You may need a new antenna.  Go to www.antenna.com for info and help.
Posted on May 30, 2009
  • John Morganti May 30, 2009
    Whoops!! Wrong site.  Go to www.dtvanswers.com/dtv_antenna.html for info and help.
How can i get local channels on my rca tru flat tv BD20TF10
The RCA BD20TF10 was manufactured before digital tuners (ATSC) were required. It only has an analog (NTSC) tuner so you will need a digital to analog converter box to watch most local channels. (These were the boxes available with the discount coupon as the ATSC broadcast transmitters were enabled.) Depending on the converter box model, use either the composite video input or use the RF antenna connection. If you use the RF output from the converter, you will need to set the TV to channel 3 or 4 (set the switch on the box to match). Then follow the directions for searching for channels with the converter box.
You may be able to find a low power analog station still broadcasting. However, you'd need to be close to the transmitter or have an antenna that is rated for a long-range signals. (Usually this will need to be an outdoor antenna with few obstructions between the transmitter and the antenna.) To scan for any available NTSC channels, make sure that the TV is set to TV mode. Then press Menu. Use the Up/Down arrows to highlight Channels and press OK. Select Auto Channel Search and press OK. You may need to confirm this step by highlighting the Start Search option and pressing OK. This will also let you add the appropriate channel for watching the signal from the converter box with the RF cable. The manual for this TV is available from Sears Parts Direct here: http://www.searspartsdirect.com/partsdirect/user-manuals/BD20TF10-Rca-Parts-Television-Parts-manual . The direct link to the manual is http://c.searspartsdirect.com/mmh/pd_download/lis_pdf/OWNM/L0312126.pdf .
I hope this helps. I'm not sure if the Menu feature is available from the front panel buttons. You may need a remote with a matching code to do the channel scan.
Sep 26, 2016 | RCA Televison & Video
19" Element HD Digital LED TV Model ELEFW195 Does not scan Digital Channels just Analog Channels.
Auto-channel search can't find digital channels - Community ...
community.insigniaproducts.com/...channel...can...digital-channels/.../13...
Aug 6, 2010 - When I ran the auto-channel search it could only find 4 analog ... Notgetting Digital Channels on NS-26L450A11 ... I've plugged the cable from the wall into the TV, and preformed the auto channel scan, with "cable" selected.
Troubleshooting Guide for Digital-to-Analog Converter Boxes
https://www.fcc.gov/.../troubleshoo...
Federal Communications CommissionIf you aren't receiving digital signals on your analog TV, you can purchase a ...antennas are designed only for reception of either VHF or UHF signals (but not both). ...The channel scan will automatically search for digital broadcast channels ...
Antennas and Digital Television ' Federal Communication
Jan 13, 2016 | Televison & Video
Do i need a digital converter box to watch tv with an antenna with model 46la55r120q
According to the user's manual, the TV can receive and decode analog and digital TV signals, so no, you should not need a digital converter box. During the channel scan it will search for analog channels first, then digital ones.
Oct 23, 2015 | RCA Televison & Video
RCA STB7766G1 Converter Box not working with Comcast cables
The RCA STB7766G1 does not support any cable or satellite connections.
Jul 22, 2009 | RCA Analog (RCA) to Digital (USB)...
Can't get channels.
You need a converter box on that unit.
Jun 22, 2009 | RCA TruFlat 27F520T 27" TV
NO channels now, we had some before!!!!!
Here is how you should have it connected.
1- Antenna (rabbit ears or whatever)
2- Converter box
3- Television
When you turn on the TV and the converter box, go to channel 3 on the TV. You should see the converter box signal there. If you do not see it try channel 4. Bring up the convert box menu and go through the AUTO SEARCH, not manual search. Now your box will search all the frequencies and add any stations that are in your area. Make sure you change channels with the converter box, not the tv. An antenna on the roof will still provide somewhat better range, but even rabbit ears will likely pick up something. If you still get no channels you could be too far away, digital signals have a shorter range than analog signals. You can check your local TV stations website or call to see if they are broadcasting digital yet.
Apr 08, 2009 | RCA Analog (RCA) to Digital (VGA)...
Is a booster needed for the tb100mw9 dtv converter box?
Best solution would be to use an outdoor antenna with an amplifier(booster)--but in some areas you may get by with an amplified set top antenna. Just all depends on your location..
In perspective, I have an outdoor UHF dish and 10 foot VHF antennas with an amplifier and still i get only fair reception on outlying digital stations that normally come in clear on analog.
Also--this converter box must complete the autoscan with an antenna attached, or else you'll receive NOTHING; not even by manually selecting a known digital channel.
This #@!! box automatically locks out what it considers to be unused or weak channels. It makes the decisions and you're left with 'no signal' messages and nothing to do but try a rescan.....and you cannot add channels to any it has already found.
Feb 02, 2009 | Insignia Digital-to-Analog Converter for...
Insignia Digital to analog converter menu doesn't come up
When my Menu did not come up, I found it on the AUX channel (one below channel 3). I was able to go through the set up, but found only one digital channel available. Hope this helps!
Nov 10, 2008 | Televison & Video
Digital turner or not
CONVERTER BOXES are For those who use a antenna to receive a Free Signal Channels.So if you have Cable or Satellite this will NOT have any affect on what you are now receiving.
Sep 10, 2008 | RCA 27V530T 27" TV
Digital
Nope. Not a digital Television. I'm guessing it's an older one. Most TV's sold nowdays are Digital TV ready.
Jan 02, 2008 | RCA F32665 32" TV
RCA Analog (RCA) to Digital (VGA) Converter for PC (displays TV image on PC) (AD01) Logo
579 people viewed this question
Top RCA Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
