Question about Sewing Machines
Upper Thread Error
I am trying to embroider on my Brother Innovis 4000D and I keep getting an error "Check and rethread the upper thread." I have rethreaded changed the bobbin (and bobbin case) changed hoops and stabilizer and replaced the needle. I still get this message and the few stitches it does manage to embroider in between messages, are a mess on the back side. The upper thread is making very loose loops on the bottom side of the design. Any suggestions?
  • 1 more comment
  • Wmctk2 Oct 23, 2007
    Thank you for the suggestion. I tried threading with the presser foot up, but still no luck. The pattern that I'm trying to sew is a Disney pattern that I have sewn many times before without a problem.  It seems to really have trouble with a running stitch, the stitches are extremely loose on both sides. Anyone other suggestions would be greatly appreciated!
  • Jillt Dec 08, 2007
    I have the same problem on my brother innovis 4000D. When it is good it is very very good but goes through regular patches where I get this birdsnest of loose (upper) threads looping on the underside. And I mean a couple of centimetres of loop not a few millimetres.
    Smaller needles help, but are not a cure. My machine is still under guarentee and is going back into the shop to see what they can do. I have tried new needles, defluffing, different bobbin threads, tension etc etc. yet just now it is sewing 'tigger' on felt and it looks georgous. five minutes ago it was looping almost every time.
    As far as I can see it seems to occur when starting sewing and it is as if something doesn't 'catch' at the beginnning. If that goes OK the rest does, otherwise I can have this problem and several false starts.
  • Vivienne Bahr Sep 29, 2012
    My 4000D had the same problem, I took it back to the shop & they thought it would be some fluff or thread caught in the sensors. I will be picking it up after the weekend & if the technician has found that is not the problem, I will let you know. It is definitely not a job for an amateur to try & fix.
    New Friend:
  • 5 Answers
I just posted this under another Brother machine...mine is a se 350 but, might be the same problem!! Hi....I also kept getting the check and rethread upper thread message, I'd sew about 15 stitches and it'd stop. Here's what I did. On the left of the machine, in the back there is a screw....loosen that screw, take cover off, then lift straigt up and out on the cover that has the 3 on it in your threading seqence. Next, I started inspecting and cleaning the thread route from top to bottom. Lo and behold....I get to the place where you come down the front of the machine and turn to go back up and I spot a little slice/cut in the plastic piece so, when I was threading the machine I guess I was pulling it to far to the left causing it to wear a little slice/cut in that, I finished cutting it off with a utility knife, used an emery board to smooth it down, put the covers back on and it works GREAT!!!! Who would've ever thought that it'd be so easy and save me a bunch of money!!! I sure hope this helps someone.
Posted on Jan 07, 2013
There could be thread caught in the tension disc in the top of the machine you can get the cover off to clear the thread but it is a bit tricky to get back on
Posted on Dec 06, 2007
Machine saying to rethread the upper thread but not picking up bottom thread from bobbin. Constantly rethreaded upper thread still won't sew.
Consult the owner's manual to make sure it is threaded correctly. Install a brand new needle making sure it is installed properly. Also, be sure to RAISE the presser foot BEFORE threading the upper thread.
If it is still not picking up the bobbin thread, the machine may be out of time.
Jan 20, 2016 | Brother InnovIs QC1000 Electronic Sewing...
Thread error message
rethread needle using every thread guide, also try changing the needle, if that doesn't help them the machine may have a computer problem
Dec 24, 2015 | Brother SE-270D Computerized Sewing...
Check and rethread the upper thread message on display screen appears often even when the machine is threaded
The thread may not be lodging firmly in the tension mechanism. Make sure that the thread is firmly settled between the tension discs.
Also keep an eye on what is happening with the thread in the take-up lever (the arm that moves up and down with each stitch on the head of the machine) as the thread may be 'jumping' out thus causing the message.
Oct 13, 2014 | Brother InnovIs 4000D Computerized Sewing...
My brother pe770 jamming up and i get this error msg that says check and rethread upper thread
I find that most problems for me have been from poorly wound bobbins or very dense designs. With the dense design, when nearing the end the hoop starts catching/jumping up with the needle, breaking thread. I use software to decrease density one or two increments then embroider. Clean out the bobbin shuttle and the upper thread path. Change needle & make sure your stabilizer is appropriate for the fabric. If too lightweight it tends to shred causing issues.
Sep 05, 2014 | Sewing Machines
Error Code: Check and rethread the upper thread
Yes. It is a sensor on the take up spring. If you miss threading the take up spring you get this error. If take up spring is bent or broken you get this error or if sensor is damaged this error occurs.
May 16, 2014 | Brother LB6770 PRW Computerized Sewing...
Bobbin thread wont form a stitch
Hai, Please check the bobbin tension and winding. And cleaning the machine.
Mar 20, 2014 | Brother InnovIs 4000D Computerized Sewing...
Brother pacesetter ULT2003D
try using a different spool of thead on the top and bobbin
and if these suggestions don't help then call the repair shop and check
with them about the machine not sewing light fabric
Jan 04, 2013 | Brother PE770 Computerized Sewing Machine
Machine keeps saying recheck/rethread upper thread
sounds like the computer motherboard could have malfunctioned
and needs to be checked
Nov 21, 2012 | Brother InnovIs 4000D Computerized Sewing...
Singer Futura 350 bogus thread breaking error
I had the same problem for a LONG time. Yesterday I finally removed the top and the cover for the upper tension and found thread fragments under one of the discs. I removed it and used compressed air for dust clean out and it is working wonderfully. Good Luck
Aug 24, 2009 | Singer CE350
Sewing Machines Logo
772 people viewed this question
Top Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
Are you a Sewing Machine Expert? Answer questions, earn points and help others
