Question about RIM BlackBerry Curve 8310 Smartphone
BB Curve 8310 keys and trackball not working
How do I fix my keys and trackball not working on my BlackBerry Curve 8310?
Is there a way to navigate thru options with no trackball
Posted on Aug 08, 2009
IMEI: 358263011833938 I need a code to unlock my BB 8310 curve
you can unlock your Blackberry eaisly with Blackberry Imei Unlock code. first call your service provider ask your Blackberry Mep Code. But it takes time to give your Mep Code. or other option is go online. there are thousand of sites available to provide Blackberry curve 8310 Unlock Code. Buy your unlock code from third party.
Jul 28, 2010 | AT&T Blackberry Curve 8300 Smartphone
The keys do not work the trackball is intermittent
If you have a warranty on the phone than you should bring it in right away, if not than consider finding a replacement. this happened to my phone and it was deemed beyond economical repair due to liquid damage.
Apr 16, 2010 | RIM BlackBerry Curve 8310 Smartphone
BB curve 8310 keyboard is not working properly
yea i have the same problem A,F,J,K,"DEL", "ENTER","ALT",X,B,V,$ these keys are not working. Last night they sudenly started working but then stopped 2 minutes later, my Blackberry wasnt dropped neither did it have any water damage. most is i have the ball removed as i await a replacement ball
Apr 06, 2010 | RIM BlackBerry Curve 8310 Smartphone
Blackberry curve 8310 gaming problems
Some games or apps are not well optimized for the 8310, try using a combination of keys with the Alt key at the bottom right (Alt +Q or Alt+P) or simply the trackball. If this does not work I suggest you delete the app or game to free the internal memory.
Mar 13, 2010 | RIM BlackBerry Curve 8310 Smartphone
I cannot click using my trackball (AT&T Blackberry Curve 8310).I can scroll up and down but when i go to click on any applications, a menu comes up just as if the menu button to the left of the...
Trackball doesn't work if you have not selected the sensitivity. To select the sensitivity, kindly follow the steps: 1. Select menu. 2. Select option. 3. Select screen/key board. 4. Scroll down to find horizontal and verticle 5. Select horizontal-100 and verticle-100.
Oct 19, 2009 | AT&T BlackBerry Curve 8310 Cell Phone -...
Trackball click not working
disassembling it will get problem even worse. dont do it, to clean it simply use the rotating straw tricks, you can read the full article from the source at http://www.unique-stuff.co.cc/fixing_sticky_blackberry_trackball.html
Jun 30, 2009 | RIM BlackBerry Curve 8310 Smartphone
Cannot scroll up with my Blackberry Curve 8310 trackball
It is a very common problem. You just need a new trackball. Should be about $25. If you want to make it work temporary, then just removed it and clean the trackball and the phone part under it (on the phone itself) with 99% alcohol. It might work for a while again
May 13, 2009 | AT&T BlackBerry Curve 8310 Cell Phone -...
Blackberry Curve says Memory card not formatted.
Options, Media Card, click the BB button to the right of the trackball and you will see the option to format card.
Hope this helps, if so please rate my solution accordingly.
Thanks,
david
Mar 16, 2009 | RIM BlackBerry Curve 8310 Smartphone
Blackberry curve 8310 trackball wont go down
Hi there
I had exactly the same problem. I spent a while trying to use a qtip to flush out the dirt but this didn't work.
I eventually sorted it by carefully lifting the cover (use a credit card to lift it up - slip it in the gap above the y key).
Then carefully hold the bb upside down and the trackball will fall out. Catch it in your hand.
Remove any obvious grit. I also used something out of a manicure set. I am not sure what it is called but it looks like a small tick remover. Anyway using one side I carefully slotted it into the small gap between the rubber ring and the trackball and lots of other bits of grit fell out.
Then once it was clean, I popped it back into the bb and refitted the cover - making sure to put the legs in the correct position.
It now works fine
Hope this helps
Phil
Jan 16, 2009 | RIM BlackBerry Pearl 8100
RIM BlackBerry Curve 8310 Smartphone Logo
851 people viewed this question
Top RIM Computers & Internet Experts
Computer Repairing
Computer Repairing
Andrew Wright
Trisha
Trisha
Are you a RIM Computer and Internet Expert? Answer questions, earn points and help others
