Question about Alpine Car Audio & Video
My car amp kills my car battery
I recently installed a 15 sub in the back of my car when i finally managed to get hold of an amp to power it i got my friend who has some idea what he is doing to help me to set it up. we connected everything up and tested it but it didnt work, we tried everything until we finally realised he had connected the live power cable to the negative terminal o n the battery so we rectified this and the amp worked fine powering the sub nicely, then the next day i went to start my car and the battery was dead, so i charged for about 15 mins got the car started and carried on, i left my house went out for a few hours got back to my car and the battery was dead.. again! so i tried to create a better earth point for the amp and once i had done so i tired the amp again and the amp appeared to power but made no sound so i gave up disconnected the amp and speaker and took them out of my car and went out, once i got back to my car my battery had died once again! so i decided to at this point disconnect the power inverter i was using 2 run a PS3 which had been connected to my car for a few weeks perfectly fine and had not caused a problem and afterwards my car seemed to work as normal, i have recently attempted to try the amp again and it once again appeared to power up but made no sound and i realised at this stage that the fuse in the wire connecting to the battery had blown quite spectacularly although i do not know at what point it had blown. It was also in fact the power on cable from my head unit that was powering the amp. can anyone help me figure out why the amp has been killing my battery and why the fuse has gone???? i got the amp free off of a friend and all of the cables and necessary equipment to run it from him under the promise that it had all worked fine in his car for a long time and should have been fine when he gave it to me but as a result i have no warranty and could not easily get it repaired if it does have a fault. i also wonder whether the fuse went when the amp was connected to the wrong battery terminal although i am assured it shouldnt have and i also wonder if this error could have caused damage to another component or my car????
    Problem Solver:
  • 18 Answers
It should not have affected anything unless the amp gets too hot due to being bridged or the ground and a power source touched each other which would have sparked and put the some amps in protection mode unless it has a fuseable link then it will blow the fuse such as the 12v battery or the power on wire which is blue and is called the (remote wire).
When adding (Amplified Powered Equipment) to your car you have to in most cases:
  1. What kind of sub and amp do you have?
  2. Make sure that your battery terminals are tighten.
  3. Depending on the size battery thats already in your vehicle you will need to Upgrade your battery size with about 800 Cranking Amps or add a Capacitor depending on the wattage of the amp
  4. Alternators are a big issue as well due to amp outputs in your case it shouldn't unless your light is slightly visible on the dash.
Posted on May 31, 2009
My kenwwod kac-9105d power led indicator turns on with my kill switch, but there is no output to my two 12 inch 4ohm kenwood subs. i dont know what the problem is, i checked the wiring and it was fine....
check the leads that your using to send the audio signal to your subs and try a few different ones, if its digital do the same, both from amplifier to sub and from device to amplifier. you can also try a direct audio connection to the speaker or use a 9V battery and a couple of cables to see if the sub speaker moves or makes a hum or something when electricity is pushed through them. other than that i dont have a solution. best regards
Oct 30, 2013 | Kenwood KAC9105D Car Amp
I have a 1200 watt amp and 2 12 in pioneer champions and it keeps killing my battery how do I hook up this capasitor I just bought?
first make sure your power wire is directly hooked to the battery, {make sure ure in line fuse is pulled} power wire that goes to positive of power cap , ground wire is grounded to chasis, now attach aditional power wire to amp and aditonal grond to amp . make sure all conections are solid and tight { also make sure inside of power cap is tight as well after long periods of time the insides loosen } i have 2 -1,000 watt sony xploid amps and 2- 1,200 watt sony expoid subs and they pound hard . i probley should have 2-1.2 farrid caps for what i have but it seems that its holding its own
Dec 04, 2010 | Metra Tsunami 1.2 Farad Capacitor
My subs/amp are not working
when you car is running, it charges the battery somewhat. So the voltage problem is not a problem. The red light means the amp is going into ''Protect Mode". This usually happens when something is wrong with the amp. Usually the amp is getting hot. Check all of you connectiong and check the final impedance of the subs. Make sure the amp can handle the impedance of the subs. If you need anymore help, message me.
Feb 12, 2010 | Kenwood Excelon KAC-X621 Car Audio...
POWER ISSUES
Recomend installing a capacitor, this will control voltage drop and reduce heat. The new battery should help, but it also may be that the amps final circuts could be wearing out, and no longer able to handle the load of the sub.
Sep 28, 2009 | Jl Audio 1000/1 Car Audio Amplifier
Blackberry curve 8310 fatal error during backup
I would connect the device to a PC and update the OS using Desktop Manager. If you recently installed any application, I would uninstall it as this may cause this type of behavior.
Jul 21, 2009 | RIM BlackBerry Curve 8310 Smartphone
I have a rockford fosgate punch 150 and it will power a small 5 1/4" speaker, but doesn't seem to push my 15" subwoofer. I am reading 4ohms across the sub so I'm assuming that it is fine and that there is...
amp is way too small to power a 15 inch sub. But you should get some sound out of it, not silence. You can use a 9 volt battery to test your sub, if the sub pops when the 9 volt is placed across it's terminals then it's ok. If it does not pop then your sub may be bad, or the coil may be frozen. (It can still read 4 ohms if frozen). If your amp powers smaller speakers fine, you know it's not the amp. If the sub tests ok, then verify your connecting it properly to the amp's correct bridging terminals.
Jun 12, 2009 | Rockford Fosgate Punch 150S Car Audio...
Ive had 6 blown subs in the last 6 months
be careful with fosgate amps. They are more powerful then what is stated on them. I found this out when I blew a 15 with a punch 260ix. These amps are made for competion use. The 600.1 does not push 600 watts as stated. I had one tested and it actually pushes close to 800 watts. Turn ur bass level and ur gain to about 3/4 power and this should solve your problem
Feb 23, 2009 | Car Audio & Video
Cd player plays, but no sound comes out of speakers.
first off the amp gets power straight from the battery. the amp is used to power the subs. the subs are suppose to be connected to the amp only( never the speakers).
for the second part you mostlikely killed the wires. you should get some one to look at it and check the wires. thee speakers might need to be re-wired
Jan 31, 2009 | Kenwood KDC-MP238 CD Player
Power surge blowing fuses on amp when car is turned on.
the voltage regulator in the alternator or the capacitor is malfunctioning. get a multimeter on the battery when u start the car (before the capacitor) if it reads a large surge (something greater than 14 or 15 volts) then u may need a new amp, if not, then test it on the back end of capacitor to the chassie negative, see if u detect spike there.
Nov 26, 2008 | Car Audio & Video
Car Audio & Video Logo
1,741 people viewed this question
Top Alpine Car Audio & Video Experts
xxxxxx xxx
Tygh Duval
Tygh Duval
Jaime Hernandez
Are you an Alpine Car Audio and Video Expert? Answer questions, earn points and help others
