Question about GE JBP24 QuickClean Electric Kitchen Range
Burners won't heat up
I have a GE jbp24 free standing electric stove. All of the sudden the burners quite heating up. The clock is still on and the burner light comes on when I turn on a burner, but none of the burners heat up at all. I already replaced the breaker at the panel. Is there some other reset or inturnel fuse I am not aware of.
  • ausm2000 May 30, 2009
    guru
    I got it working, your advice helped so much.
    President:
  • 1,136 Answers
Hi, Did you check the receptical on the wall to see if it is any good? Do you have 240V to the oven? If there is voltage, Unplug the oven and remove the rear panel to see if a wire has burned of of one of the switches. It would be either the red or black (L1-L2). I hope this helps
Please let me know
Thanks
Vic
Posted on May 30, 2009
  • Victor
    Victor May 30, 2009
    You're welcome. Glad I could help.
Burners and oven on Hotpoint free standing electric stove won't heat at all.
Find someone with a good electrical meter and have them test the sockets to see if there is any electricity to the burners.
Also, check each burner and check for continuity through the burner itself.
These elements can all burn out, I've see it happen.
Be blesssed.
Apr 17, 2013 | Kitchen Ranges
GE electric stove problems, our stove has 3 small burners and one big burner. When we use the big burner at medium heat it does fine then all of a sudden it starts glowing bright red and burns whatever is...
Replace the infinite heat control switch for that burner. (the burner switch that you turn with the knob to select the temp setting) If you list a full model number (usually behind the lower drawer panel on the frame of the range) I can look up the part number for you. It is not a very difficult repair.
Oct 11, 2009 | Kenmore 95592 / 95594 / 95595 / 95599...
Electric range burners and oven element just stopped working. Burner indicator light came on and oven temp setting displays correctly. Clock went into set mode automatically, though. Burner came back on...
check the power behind the stove, the outlet for 220 volts, i just fix one with the same problem, it was getting 110 volts but not the 220 volts. so there was nothing wrong with the stove but with the power source.when the stove indicator lights work and the clock, it means that only 110 volts are coming to the stove.
Dec 10, 2008 | GE JBP24 QuickClean Electric Kitchen Range
Electrical problem w/ magic chef electric range CER3540AAA
hi thanks for the question i would check to see if theres 240 volts at the stove if only 110 volts at stove you will not get any heat but lights will work check that replace fuses in main panel for the stove thanks the appliance doc
Sep 27, 2008 | Kitchen Ranges
How do i set the clock on my electric range
Here's the URL to page 8 of the User's manual for your JBP24 Range:--> http://www.fixya.com/support/p128492-ge_jbp24_quickclean_electric_kitchen/manual-12867/page-8 ...and the rest of the User Manual is there as well, of course. Hope that helps. ;)
Aug 09, 2007 | GE JBP24 QuickClean Electric Kitchen Range
GE JBP24 QuickClean Electric Kitchen Range Logo
584 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Mike Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
