SOURCE: I have a jenn-air sealed gas cooktop jcg8430 only 1 burner lights
you have a problem with the ht leads or spark electrodes
SOURCE: turn on one burner, second burnertrise to light
hi.gud day...tnx for question.im gerbee here in the phillipines, the problem of the the unit is have an dirt or water,& oil coz why the unit is not stoping cliking sound.the best thing to is clean the area were the problem it is,first unplug the unit & turn in off the gas line for the safety..get the vacium & bottle of thinner...first remove all the knobs of the control valve(make sure to remember how to remove the knobs coz if turn back as how you remove it). then drops some thinner located on valve switches(knobs position) 5-10ml,,,then put the vaccium in the place were u drop the thinner to suction the thinner,oil & some dirt.try 2 times for good result...after this if is not work n nid to call an expert tecnician to dismantle & clean the micro swicth one by one(no nid to replace the parts)
tnx gerbee
SOURCE: Jenn-Air Expressions cvgx2423b manual request
I have a Jenn-Air Expressions cvgx2423b model. One of the knobs fro the burner is stuck in the middle and will not rotate to trun off. So I have to shut down the gas each time. Any body has an idea what is the problme
SOURCE: Right front burner fails to heat (at all) Jenn air
I suspect a faulty element or electrical connection to the element.
