Question about HP Compaq Presario F730US Notebook
Broadcom 802.11 wireless lan adapter
Everytime I have to restart my laptop my broadcom 802.11 wireless lan adapter stopr working. I have to recover it and sometimes it wont reload
Needs firmware
You should be able to find your solution on the following page: http://www.broadcom.com/products/Wireless-LAN/802.11-Wireless-LAN-Solutions
Not enough detail to tell you which driver it actually is.
Mar 25, 2011 | Broadcom (BCM94318MPG) 802.11g/b Wireless...
How do I get the acers drivers installed? I have down loaded all three wireless drivers,and none work.
Drivers for windows Vista are here: http://support.acer-euro.com/drivers/notebook/as_4720.html
Under Drivers and Utilities, Select and download these drives;
1. Wireless LAN Atheros
2. Wireless LAN Broadcom
3. Wireless LAN Intel
While installing, please start with "Intel" as you follow instruction there after. Restart your Laptop and install Broadcom, Atheros respectively.
Please ensure that VISTA SP1 is installed on your system prior to installing these drivers!
Driver incompatibilities on a system without VISTA SP1 might affect usability.
Rgds
Feb 07, 2011 | Acer Aspire 4720 Notebook
My gateway laptop cant connect to the internet. _When I plug a cable, the red light in the port does not respond _ The WIFI does not respond
Hello John,
It seems that: 1. Your LAN controller and the WiFi controller could be disabled in your BIOS setup.To re-enable them, if applicable,
  • Press the F1(or F2 ) key repeatedly after restarting the computer to enter the BIOS setup.
  • Navigate through your BIOS and locate the settings for LAN conroller and wireless, and select Enabled to enable them.
2. You may not have the appropriate drivers installed on your laptop for your network controllers. Upon further investigation, your laptop runs on the following network hardware:
  • ActionTec IEEE 802.11b network card installed in Mini PCI expansion slot
  • Broadcom BCM94306 IEEE802.11g network card installed in Mini PCI expansion slot
  • Broadcom BCM94300 IEEE802.11a/g network card installed in Mini PCI expansion slot
Download and install your drivers for the hardware above from: Wireless Drivers(Broadcom BCM94306) from http://www.soft32.com/download_175098.html Broadcom BCM94306 10/100Mbps LAN drivers from http://www.broadcom.com/support/ethernet_nic/downloaddrivers.php
Hope this solution helps.Good day.
Jan 14, 2011 | Gateway M305CRV Notebook
I want to download a kit for my Broadcom 802.11g Usb Wireless Lan External Card. I don`t find one. Please help me! Sorry for my english, I`m romanian!
Hi badea_adela8,
Based on your concern, I suggest to follow these steps:
1. Download the latest Broadcom 802.11g driver here:
http://www.wireless-driver.com/category/download/broadcom/
2. download the driver install it then restart your computer
Hope it helps,
Thank you for using Fixya
Best regard,
Reyjoshua07
Dec 10, 2010 | Broadcom (BCM94318MPG) 802.11g/b Wireless...
I have a Dell and net adapters doesnt work
Uninstall and reinstall LAN drivers and Broadcom drivers.
Press Windows key and R key simultaneously to open Run Window.
Type "devmgmt.msc" and click on OK.
This will open Device Manager.
Click on "+" sign next to Network Adapters and right click on the network adapter and select Uninstall.
After uninstalling right click on Network Adapters and select scan for hardware changes.
This will reinstall the drivers.
Sometimes windows prompts you to restart the computer to reinstall the drivers automatically.
You can even reinstall the new LAN and Broadcom drivers from your Dell website provided they have new version of these drivers.
After reinstalling the drivers, check if the adapters work.
If the adapters still don't work, the issue could be with the hardware.
You may even try with recovering your PC using Dell Factory Recovery.
Before performing Recovery, take the backup of your hard disk as the Recovery process will restore your notebook completely to factory settings.
Jun 15, 2009 | Dell Latitude D600 Notebook
Dell Inspiron 6400 - Wireless Adapter Problems
Broadcom is not wireless, but the normal ethernet controller.
You should go to intel / your laptop manufactuer website and download the appropriate drivers.
Mar 21, 2009 | Dell Inspiron E1505 Notebook
Aspire 4310 Broadcom wireless
ok...
the drivers are not getting installed properly and i am sure that you are installing the right drivers,
what you can go is go to device manager and then right click on the drivers and go to properties,
once the properties box opens go to the tab that says drivers,click on update drivers and then go ahead and folow the wizard to update the drivers(make sure you download a fresh set of wireless drivers)..if it still gives a yellow triangle,
go ahead and right click on the wireless drivers,click on uninstall and then restart the computer and checked if it still has the yellow bang..
the link for website is
http://support.acer-euro.com/drivers/notebook/as_4310.html
once you downlaod the drivers its a zip file,download in the desktop,right click on it and then click on unzip,once the files are unzipped go to the unzipped folder and then click on install for the setup..and in this webpage go ahead and choose wireless broadcom as the option as it shows lan broadcom and wireless broadcom,u can also try installing wireless intel because it might be that you have intel card in you computer and not broadcom..
try it out..
vedhick
Feb 12, 2009 | Acer (D10709-002) (D10709002) 802.11g/b...
Cannot get drivers to install
You will find you LAN (BroadcomLAN driver 4.28) or (Broadcom Giga LAN driver 8.27.1) storage (Intel chip set driver) and Wireless (Broadcomm 802.11b+g wireless) or (Intel 802,11b+g Wireless LAN driver 9.0.1.9)  ->drivers from here:
Plz let me know how you go
regards /Teis
Jan 09, 2009 | Acer Aspire 5500 5570-2609 Laptop
My Wireless Broadcom Adapter is not properly running
here is the drivers and utilities page for your laptop.
just download new drivers and restart.
go to your os then drivers and utilities tab then wireless broadcom and
lan broadcom.
Dec 26, 2008 | Computers & Internet
ACER 5610Z BROADCOM WIRELESS LAN DRIVERS FOR XP
I found this from Acer's website. Just click this link, And on the list you will be able to download the driver for your broadcom wireless adapter. I hope this one helps.
May 07, 2008 | Linksys (WMP54GS) 802.11g/b Wireless...
HP Compaq Presario F730US Notebook Logo
414 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
