Question about Bosch 24 in. SHU53 Built-in Dishwasher
Drain water wont drain there's about 2 inches of water in the bottom
Happens on mine also. It's normal for a little water to remain after the rinse water is pumped out.
Posted on Nov 21, 2007
Holding water in bottom of unit
drill a hole and insert a piece of tube from home depot 3.00
Jul 28, 2014 | True 598-TSSU7218 SandwichSalad Food Prep...
Water won't drain after cycle is done. Leaves 1-2 inches of water in bottom. Checked hose and its clear. Put hose going to disposal in bucket and water comes out when diswasher is cycling
it is easy track this path of water from bottom of m/c it will b afilter then small hoses to drain pump thenouter hoses <
thanks
Jul 13, 2009 | Dishwashers
There is about 2 inches of water left at the bottom of the washer after the whole cycle runs. it wont drain
Check drain hose first.
If you do not find any blockage, then you will need to access the pump, remove pump hose and look for blockage in there.
If there is no blockage at all, then either the water level switch, a faulty pump, a wiring problem, or a faulty timer board can be cause the machine not draining.
May 15, 2009 | Kenmore 24 in. 17482 / 17484 / 17489...
Water in the bottom of dishwasher
try running it empty there is usually a drain hole in the bottom check if anything is in it or try a dish washer wash solution I bet the drain or drain line is cloged let me know if this dont work. Hows your sink draining
Feb 15, 2009 | Kenmore 17459 Free-standing Dishwasher
Ran on normal cycle when done 2 inches of water on bottom
Test by restarting the cycle and see if water drains if it does not then there is either a blockege in the pipe ,pump,or in the machine where the water passes out normally through a filter if you have checked and cleaned out filter and drain pipe and there is still no draining then listen to the pump if you can hear a humming niose then there is something in the pump itself and you need to take it out and inspect the impelar houseing remove what ever is there put back and enjoy if there is no noise and pump is clean then it is proberly fualty and nedd replaceing.
Jan 23, 2009 | Whirlpool Gold 24 in. Built-In Dishwasher...
DD601ver2
check for restriction in sump. ie remove rotor, push pipe cleaner or similar from filter sump into rotor sump
Jun 21, 2008 | Fisher and Paykel 23 in. DD-603SS Built-in...
How to install diswasher
To get the water to the dishwasher, it depends on your plumbing setup. If you have shutoffs under your sink(1/2" X 3/8" compression angle stop), you will need to buy a 1/2" x 3/8" compression double stop. This will be easy to change.
#1 Drill a 1 1/2" hole in the back bottom of the cabinet to run your water, drain line, and power cord through.
#2 First turn off the water at the Hot Water Tank, or the House supply, and turn on the sink to relieve the pressure.
#3 Next remove the Hot supply stop, and install the double stop.( The nut and ferrul do not have to be removed, as they will attach to the double stop. Reinstall the hot supply to the sink to one of the connections on the double stop.
#4 Install a 3/8" x 3/8" x 48" braided flex with the 1/2" MIP
x 3/8" compression ell at the dishwasher.
#5 Install the drain hose supplied with your dishwasher at the bottom of the dishwasher.
#6 Install a 6' pigtail power cord to the power box under your dishwasher.
#7 Feed the drain line, power cord and water supply through the hole in the back of the cabinet at the bottom. As you push the dishwasher back into the enclosure, you will need to feed the 3 lines into the cabinet under the sink.
#8 Attach the water line to the open connection on the double stop.
#9 The drain line will attach to your garbage disposal.(If you have one) Be sure to knock the small piece of plastic out of the drain connection, and retrieve it out of the disposal, before connecting the dishwasher drain line.
#11 Raise the middle of the drain line as high as possible under the cabinet under the sink, preferably attach it to a screw to the bottom of the counter top. This will keep the dishwasher from drawing a back siphonage and getting a bad odor.
#12 Plug in the dishwasher. Assuming you have electrical under your sink. Otherwise an electrical outlet may need to be installed.
#13 Balance the dishwasher using the front legs. After you adjust the depth of the dishwasher, and the level. Use the 2 mounting screws included with the dishwasher to fasten the 2 clips above the door to the bottom of the counter top.
#14 Remove the installation manual and styrofoam from the tray, and turn the dishwasher on. Inspect for leaks as you run a cycle.
#15 Attach the bottom kick panels
You are done.
If you have any questions, please let me know.
Jan 20, 2008 | Whirlpool GU2400XTP Built-in Dishwasher
Ice 2 inches thick in bottom of refrigerator
the defrost drain is more than likely plugged. unplugg the fridge, take the back pannel of the freezer. remove as much ice as you can from the drain trough (putty knife works good). Once you can see where the drain spout is use hot water and a turkey baister to clear the ice from the drain. this will stop the build up of water(ice) in the bottom. as for the eggs i know it souns simple but turn the fridge down a half point per 24 hrs. use a thermometer in a glass of water to check the tmp. can safley run between 33f and 40f. Good luck.
Sep 25, 2007 | Refrigerators
Bosch 24 in. SHU53 Built-in Dishwasher Logo
141 people viewed this question
Top Bosch Dishwashers Experts
Gerry Harvey
Gerry Harvey
Are you a Bosch Dishwasher Expert? Answer questions, earn points and help others
