Question about Troy Bilt Tb70ss Gas Trimmer
Weedeater starsts and ildes won't run or accerate
Weed eater starts and ildes on choke but dies when accerated. Have tried cleaning carb but still nothing works.
    Scholar:
  • 72 Answers
It sems to me like your engine chokes itself on a too rich fuel mix, a clogged air filter may cause this condition. Of course there is always the possibility of a needed carburetor adjustment but I would definitely check the air filter first if this machine used to work fine.
Posted on May 30, 2009
  • Håkan Sterner May 31, 2009
    So how did it work out for you, OP? If you tried the suggestion and it didn't help, please tell. Without feedback I cannot help you further.
  • Håkan Sterner Jun 04, 2009
    Did you disengage the choke after it started on choke initially? If you don't switch to half choke or no choke (Run position) shortly after you got it started on choke you will experience just that, the engine dies when throttled because of a too rich fuel mix. Those small engines can be a little tricky to get used to.
My Weed Eater FL1500LE will only run on full choke and will stop when changed to half choke or throttle is moved from fast idle to any lower speed. I have replaced both fuel lines, thoroughly cleaned the...
It is obviosly fuel starvation, have you actually replaced the fuel filter on the end of the hose in the tank? try richening the fuel mixture by unscrewing the H and L screw on the carb 1/4 turn on each, you may need a special tool to grip and turn these.
Sep 22, 2013 | Weedeater 2 Speed Gas Blower FL1500LE ()
Weed eater head spins on its own, no power.
check the compression on your weedeater low compression will cause this
Jun 26, 2013 | Poulan Genuine Weedeater Part # 36006-128
Husqvarna weed eater starts , but blows alot of smoke & then stalls out
Rod, Carb. may need adjusted, try loosening gas cap and start to see if cap vent plugged, there is a in tank fuel filter that you could fish out and remove to see if it is plugged. If still not running remove muffler and clean spark arrester screen, if screen plugged the trimmer will do this.
Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
String Trimmer Starts Then Stalls
My String Trimmer Starts But Won Stay Running
Craftsman Trimmer starts then dies
How to Clean Spark Arrestor Screen on Small 2 Cycle Engine Quick Fix
How to Clean Two Cycle Two Stroke Engine Carburetor
Sep 06, 2012 | Husqvarna 128 LD Weedeater
I have a ryobi weed eater clean carb change filter and spark plug wont run off choke
I have the same problem. It will run if I put it halfway between Half Choke and Full Choke. But, just dies if I put it on Run or Half Choke. Don't ever loan your WE to anyone, They might just try to run it on straight gas--That is what happened on another week eater that I had.
Mar 27, 2010 | Ryobi 30 Cubic Centimeter Curved Shaft Gas...
Weedeater will not run with choke open.
check your air filter,, and try if do the same thing you have to clean carb. out,, if you dont how just ask me,, thanks hope this help you
Sep 02, 2009 | Poulan/Weed Eater No. Bvm200le 711482 24cc...
15 horse mercury outboard
Clogged jets in the carb...clean out carb or rebuild carb.
Jul 28, 2009 | Boating
Weedeater starsts and ildes won't run or accelerate
Make sure your gas supply is fresh...not from last year...
Secondly, clean and service the air filter element... you may need to reoil it before installation...check your manual.
Disconnect the fuel line and drain it and what little is in the carb...push on the prime bulb if it's got one...
Then with a clean air filter and fresh gas... give it a start and after start, disengage the choke..
Let me know how you do..
K
May 28, 2009 | Troy Bilt Tb70ss Gas Trimmer
Poulan weedeater will only run with choke half way on
this could one or a combination of a few things
1 check inside the tank for dirt 2check that the filter screen inside the tank is not plugged3 make sure the gas feed tube is not restricted pinched in the case or kinked also you can try a simple carb adjustment.also check to make sure the plug is gapped to the right specs good luck and i hope one of these suggestions do the trick
May 02, 2009 | Poulan/Weed Eater No. Bvm200le 711482 24cc...
Troy Bilt Tb70ss Gas Trimmer Logo
1,254 people viewed this question
Top Troy Garden Experts
Matt Olenzek
Matt Olenzek
Mike Squire
Tim Whalen
Are you a Troy Garden Expert? Answer questions, earn points and help others
