Question about Dryers
Dryer will not start?
Our dryer will not start. I replaced starter button but that was not the problem. The timer works but when I push the starter button nothing happens. I opened the back panel and check the belt. Looks like it's still on. Cannot get to motor to check. Please help. Would like to fix myself but may have to call mechanic.
    President:
  • 1,136 Answers
Hi, please get em model # so I can look this up and give you direction. If you have the back off, you can try and locate a duse (if this is a whirlpool brand) and test it. It has to have continuity to be good. Let me know if I can assist you further.
Vic
Posted on May 30, 2009
Dryer does not turn on? voltage good to dryer,push
here are some other problems/causes as to why a dryer won't start, Tim :
http://www.partselect.com/dryer+dryer-wont-start+repair.htm
Nov 21, 2010 | Kenmore 64902 Electric Dryer
Whirlpool dryer will not start, used to start if I turned timer
whirlpool electric dryer will not start when you push start button. Model No. LER5634AW0. There is power to the dryer. The door switch appears to be working,(didn't check it with a meter). I push the start button, run it through all the cycles and still nothing. Are there any resets or circuit breakers that I could check? Where do I go from here?
Mar 06, 2010 | Dryers
Dryer stops when I release push to start button
Timer may need to be replaced. You can test it with an ohmmeter or test light.
You can do the same with the push button. If you have more problems, then the main control could be faulty
Sep 10, 2009 | Whirlpool GEW9878LW Electric Dryer
Kenmore Dryer (Model #11073952101) starts, but WON'T stay ON
your motor maybe going out. theres a switch on the motor that starts it . on most models the start switch is built into the motor. however some models the switch can be replaced by itself.
Aug 30, 2009 | Kenmore 73952 Gas Dryer
Maytag MDG9316AWW Wont start
HI again. this seems to be a wiring harness issue. there may be a lose wire connection or some corrosion on the couplers that are connected to the timer and push button starter. I recommend checking all wires and clips for lose and corroded ends. make sure the clips aren't touching any other individual wire clips. The second issue may be the timer itself. it may have some damage with in the circuitry.
This reoccurring issue leads me to believe that there is something abnormal within the current flow. this. This abnormality is continuing to blow the starter switch. there are only three areas you can check to find this issue. the timer itself should be check for proper voltage and the wires and harness should be inspected as well. The last check would be the terminal block. Check the terminal block for lose power cord wire connectors.
If you have anymore question, please feel free to ask:)
Apr 08, 2009 | Maytag Dryers
Dryer won't start.
possibly the starter/hold relay or the timer itself. ensure the door is shut properly aswell.
Mar 13, 2009 | Dryers
Kenmore dryer keeps on going and going
The timer is bad. It is located behind the knobs and can be replaced really easily. The price for a new timer is about 35 dollars. If this helped please rate
Feb 12, 2009 | Kenmore 64902 Electric Dryer
Kenmore dryer stopped working, start button does nothing
hi thanks for the question i would check the thermal fuse at the back remove back panel . by the air duct theres a small thermal fuse with 2 smaller blue wires to it check that it does cause this thanks appliance doc
Sep 13, 2008 | Maytag PYE2300AY Electric Dryer
need the model # from the unit should be where the door closes to the CYE4000AWW is not a Kenmore Model
Jan 21, 2008 | Magic Chef CYE4000AWW Electric Dryer
Dryers Logo
42 people viewed this question
Top Dryers Experts
Dan Webster
Dan Webster
