Question about Dell Dimension 3000 PC Desktop
Dell Dimension 3000 will not power up after outage
After a brief power outage my Dell will not power up. I opened the side panel and see a steady green light on the MB. I tried unplugging and plugging back in. That was the extent of my tech skills. Any ideas?
  • 479 Answers
If the green lihgt is coming on the board means smps is fine.
there is the issue with the mainboard need to repair.
Thank You.
Posted on May 30, 2009
Dell Dimension 3000 will not power up. Solid amber lit stays on. Any help would be accepted.
  • If the power light is steady amber, a device might be malfunctioning or incorrectly installed.
    • Remove and then reinstall the memory modules.
    • Remove and then reinstall any cards.
    • Remove and then reinstall the graphics card, if applicable
Refer to the link: http://support.dell.com/support/edocs/systems/dim3000/en/SM/adtshoot.htm#wp1043338
Jan 26, 2011 | Dell Dimension 3000 PC Desktop
Dell dimension 4600c won't turn on since we had a power outage
hi
if you CPU has a green light it meance your Power supplay is working fine chack back side of your CPU fan is working or not if it's working then just open case
folow the 2 step
1 remove RAM
2 CIMOS beetery which is on mother board leave your CPU for Some thime re fix both i hope you CPU will give you the disply
Jul 19, 2010 | Dell Dimension 4600 PC Desktop
Dell Dimension 5100c Model: DCCY will not boot.
Is the power button a steady abmber light?
If so follow the instruction below>>>>
Remove the power cord from the back of the computer. Then open the side casing of the tower and unplug the 24 pin block connector from the motherboard. The 24 pin block connector looks like this >>>>>
Once removed press the on/off button on the computer to dispel and residual power from the motherboard.
Then connect the block connector again and put the side panel back on and then plug the power cord back in and try to boot the computer up.
If its still the same then the power supply inside the computer may need replacing.
Good luck.
Jul 03, 2010 | Dell Computers & Internet
During a recent thunderstorm, the power fluctuated and my dell dimension 3000 turned off. There was popping sound and now I cannot power on the computer. When I take off the side panel, I can see a green...
The popping sound is most likely your power supply or something on your system-board like a capacitor.
If the problem is only the power supply:
If you want to see if you can salvage it try just replacing the power supply. The part is around forty dollars. You can google "Dell Dimension 3000 250w power supply" to find a deal on a power supply.Here is a link on how to replace the power supply in that computer.
http://support.dell.com/support/edocs/systems/dim3000/en/SM/parts.htm#wp1075727
Hope that helps.
Joel
Jun 03, 2010 | Dell Dimension 3000 PC Desktop
Can't open dell dimension 3000 to add memory
A tool-free side panel slides open easily to reveal a roomy interior with two free PCI slots. ... The Dell Dimension 3000 is an affordable computer designed to handle essential multimedia demands for the home user. The Dimension 3000 comes with the latest processor and memory technology, and won't break your budget.
May 14, 2010 | Dell Dimension 8300 PC Desktop
Hi, how do i remove the side panel of my dimension 3000 pc?
Hi:
There is either a half moon shaped lever on the back of the case to down and the cover pops off, or you have a button on the top and bottom of the case, and the entire case opens like a suitcase.
Nov 03, 2009 | Dell Dimension 3000 PC Desktop
Dell Dimension 3000
There is an L shaped lever on the back. Press and hold that down and push side panel of case back. It will lift off. When you put it back on just align the slots on the bottom edge and push forward to close it.
Feb 14, 2009 | Dell Dimension 3000 PC Desktop
Dell Dimension 3000 PC Desktop Problem
Push the black L shaped lever down on the back of the pc and slide the panel back
Sep 07, 2008 | Dell Dimension 3000 PC Desktop
Dell Dimension 3000 PC Desktop Logo
171 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
