Question about Frigidaire GLEQ2152ES Electric Dryer
Torn clothes I too have had many clothing items being ruined by this dryer. Any item that has a strap, string or any kind of a cutout seem to get caught on the lint vent. I have written a letter to frigidaire hoping to get some kind of feedback. Any ideas on what to do? I do feel like I should not have to take any special prcautions on drying a tank top or underwear! Just real tired of this.....
  • 332 Answers
There should have been a plastic gaurd on the lint catcher inside to keep this from happening, at anytime when taking your clothes out did you find something you might have though how did that get in there> could have been it, or look under the dryer and see if it made it's way out past the drum to the floor
Posted on May 30, 2009
    President:
  • 1,136 Answers
Hi, If they are getting caught in front between the drum and front panel, try this. UNPLUG the dryer.
Put a flat blade screw drive in the gap between the top and front panel on each edge there is a spring clip.
lift the top and look down along the front of the tub and see if the front felt bearing has gone bad. When they go bad, the tub drops and things get caught. The front bearing on some models have three nylon glides the drum rides on. If these are gone replace the front bearing.
I hope this helps. Please let me know if I can assist you further.
Vic
My Frigidaire Affinity dryer keeps wrecking my clothes by breaking straps
In any front load machine, whether washer or dryer, the manufacturer will suggest to have the items with buttons or straps, or small items, put into a mesh bag. Now you can have a professional check to see if you have too much of a gap between the drum and the door itself.
Jul 27, 2012 | Frigidaire Dryers
We have had a consistent problem with our dryer. The lint filter eats any staps in the dryer. I have found straps from bras, tops, and belts twisted around the lint filter. They get caught on the edge...
sound like front felt glide assy # upper felt seal part #134440200 lower felt seal #134134700 u can order these from sears.com
these componets support the front of drum and when felt wears away then clothing slips in gap and when dreyer tumbles clothing gets snagged in gap and tears clothing and leaves black scuffs
Jan 31, 2011 | Frigidaire GLEQ2152ES Electric Dryer
My dryer does takes ages to dry clothes and then not completely. In addition any string item like bikinis will be torn .
check to see if exhaust vent is cloged with lint, both behind dryer and outside. this should give you more air flow.
Dec 04, 2010 | Frigidaire GLEQ2152ES Electric Dryer
Straps, some satin night garments get caught inbetween drum
what model number do you have?sounds like drum roller /bearing issue
Jun 19, 2009 | Frigidaire GLEQ2152ES Electric Dryer
Dryer thumps when running, clothes get stuck...
It always helps if you list the brand and model number in your post. I would look at the seam on the drum to see if the weld has cracked. (right at the front and / or rear of the seam.)
Jun 10, 2009 | Dryers
Narrow streak of what looks like grease on clothes from dryer
hi anne-
Your dryer may use rollers, or wheels, to support the rear of the clothes drum. When these are worn out, they may cause the clothes drum to drop down slightly, which can pinch the clothes between the top of the clothes drum and the rear of the dryer interior. When the rollers wear out, you need to replace the whole set.
Rear seal Your dryer may have a felt-like seal at the rear of the drum. If this seal is worn, torn, or missing, clothes can get caught and torn in the space between the clothes drum and the rear of the dryer interior. When the rear seal wears out, you need to replace it.
May 09, 2009 | Dryers
Clothes keep catching in front ring area
>>A repair man replaced the plastic ring but the gap is still there, ruining several items per load. Is it repairable or a fatal defect?<<
The repairman should check the drum rollers, the guides, and the baffles to be sure the dryer drum is rolling true (round). Also, the replaced ring should be re-checked to be sure it's installed correctly.
Apr 10, 2009 | Frigidaire Dryers
Torn clothes
If your clothes get marked or torn in your dryer, check these:
Rollers
Rear seal
Front glides
Front seal
Rollers Your dryer may use rollers, or wheels, to support the rear of the clothes drum. When these are worn out, they may cause the clothes drum to drop down slightly, which can pinch the clothes between the top of the clothes drum and the rear of the dryer interior. When the rollers wear out, you need to replace the whole set.
Front glides Your dryer probably uses nylon or plastic glides at the front of the clothes drum for support. When these are worn out, they may cause the clothes drum to drop down slightly, which can pinch the clothes between the top of the clothes drum and the front of the dryer interior. When the glides wear out, you need to replace them as a set.
Front seal Many dryers have a felt-like seal at the front of the drum. If this seal is worn, torn, or missing, the clothes in the dryer may get caught and torn in the space between the clothes drum and the front of the dryer interior. When the seal wears out, you need to replace it.
If my assistance helped resolve this issue, please show your appreciation by rating how effective my advice was in resolving this issue.
Thank you,
Dave E. (Illeagle)
"Your satisfaction is my personal reward"
Mar 30, 2008 | Frigidaire GLEQ2152ES Electric Dryer
Frigidaire GLEQ2152ES Electric Dryer Logo
327 people viewed this question
Top Frigidaire Dryers Experts
Tim Whalen
Sal De
Are you a Frigidaire Dryer Expert? Answer questions, earn points and help others
