Question about Black & Decker Garden
My Black and Decker grasshog weedeater does not spin with power
My grasshog does not has power when it is spinning. It sounds like it is spinning freely inside.
  • 166 Answers
SOURCE: my Black and Decker grasshog weedeater does not spin with power
Sounds like you have a broken shaft internally.
Posted on Jun 16, 2009
SOURCE: Black & Decker Grasshog GH600 lever replacement
this has been driving me crazy. try this pdf from the black and decker site http://support.blackanddecker.com/cgi-bin/blackanddecker.cfg/php/enduser/fattach_get.php?p_sid=98uDbvBj&p_li=&p_accessibility=0&p_redirect=&p_tbl=9&p_id=1885&p_created=1148586888&p_olh=0
Posted on Jun 28, 2009
woobie dog
  • 1273 Answers
SOURCE: how to reload the line on a black and decker grasshog xp
Hello, W/D here. This is a previous post, but it should help.
I'm afraid that mental pictures are the best I can do, but bear with me; I'm good at it....We'll go over the spool parts, and the first time you wind tha spool, don't put any line on it....just read the directions while you hold the spool in your hands. Get a feel for what you are going to do. See how it will fit where it needs to go.....
All right......
Pull the spool out of the head.
Just look at it. You'll see that it is actually two spools.
Look at the divider between the spools. See the notch?
Look at the middle of the spools, or the core, where the line winds on the spool. See the small holes, one for each spool?
Flip the spools upside down. Look at the bottom. Note the notches in the rim of the bottom, and the arrows indicating the direction to wind the line. Look near the notches. There should be numbers next to the notches. This is the line size that fits your machine.
Take a brief look into the hole where the spool will attach to the head. We'll talk about that in a minute.
All right, let's do it. Remember, no line for the first walk thru. Take your line and snip the end at an angle, say about 45 degrees. Now take the pointed end and poke it about 1/8" into the small hole in the core of the inner spool (the spool closest to the bottom of the spool assembly). The purpose of placing the line in the hole is to anchor the line while you wrap (load) the spool. Start wrapping the line on the spool, going in the direction of the arrows. When you have that spool wrapped almost to the diameter of the rim, place the line in the bottom rim notch that is 180 degrees from the notch that is in between the spools. The line should fit into the notch snugly. You want about 6" of line to hang out past the notch and cut it so you have a 6" tail hanging out.
Now, fill the outer spool the same way. When you get it full, you'll pass that line into the notch in between the spools, and anchor it into the notch on the rim. Again, leave about a 6" tail, and cut it off.
Hard part's done. Get the spool close to the head, and thread the tails into the grommets on the machine head. Once both ends are in the grommets, straighten up the spool (align the notches holding the tails with the grommets) and push the spool into the head.
Almost there! When the spool is firmly set in the head, you'll feel a bit of a click, Grasp the tails, and tug on them enough to pull them out of the notches that were anchoring them to the rim.
Let's check our work. Push the spool in, simulating bumping the spool on the ground to advance the line. Once you have pushed it in, tug again on the tails. You should pull about an inch or so from each side, and then the line will stop.
Once you have that, you're done!
Now, about the hole in the bottom of the spool where it connects to the trimmer head....Sometimes, the line will be difficult to advance, so you should clean it out a bit from time-to-time. The trick that will help you is that, after cleaning it, put a little graphite dust in the hole. This lubricates the advancing mechanism without leaving an oily residue that will collect debris. Don't do it this time, maybe not next time, just some time. I probably do this maybe every eighth or tenth time I wind the spools or so. I buy the graphite usually at Lowe's2.gif or similar. It's used for locks, but you an also get it at Hobby Lobby where it's used for Cub Scout race cars (Pinewood Derby). Same stuff.
Sorry about no pictures. Turns out you didn't need them after all!
You've been a great student, and it's been a pleasure.
Best regards, --W/D--
Posted on Aug 19, 2009
SOURCE: how to replace line on the double sided spool for my grasshog
HOW TO REPLACE LINE, PLS CAN YOU SHOW ME FROM THE PICTURES.
Posted on Nov 16, 2009
radar001
  • 1051 Answers
SOURCE: Black and Decker Grasshog auto line feeder just
I'm gonna take a guess and say you re-spooled the line yourself. If you did you may have put too much line on the spool. The max. is 30', but I've found that that can cause jamming, which forces out more line, if not done perfectly. Reduce the amount of line by about 5 feet and you should be OK.
Posted on Apr 11, 2010
My grasshog weed trimmer only spins when it is upside down.
It sounds like the rod that runs from the motor to the head, is either loose or it has broken, so when you turn it upside down that causes it to engage itself and turn. You will have to take this apart and make sure that the holding clamps are in place
May 04, 2010 | Black & Decker 14" Grass Hog Xp...
How to replace line on the double sided spool for my grasshog
Oct 14, 2009 | Black & Decker 14" Grass Hog Xp...
B&D grasshog XP motor squeeled and spin rate slowed. repairable?
I just saw your post. Check the area between the housing and the head, along the shaft. Fibrous debris (in my area, this loosely translates into "lilly leaves") gets wound around the shaft, and will slow the universe down to a crawl. The only way to get it loose is to cut it loose, or unwind it.
Aug 18, 2009 | Black & Decker 14" Grass Hog Xp...
My grasshog has no power when it is spinning.
A pluged air filter will cause that. Depends on what altitude you are at, the carb needs to be adjusted per the altitude, see if it runs at a half choke, this tells you if it is getting to much air. The fuel mixture screw should out 3/4 to 1&1/4 turn out from bottom. Also if your oil mixture is to rich it will power out, 50:1 is 3.2oz. to a Gal. of gas. Also dependes on how old the machine is. Might have to go 80:1
May 30, 2009 | Hand Tools
The motor runs but the base doesn't spin.
The nylon Gear in the head has theeth missing. I need a parts break down and a source for part.
this is for a Grasshog. NST 2018 Trimmer
May 25, 2009 | Black & Decker Grasshog 12 Inch 18 Volt...
Black & decker grasshog gh600 Rethreading?????
see www.dewaltservicenet.com.look 4 the icon find it now.enter the model # of ur tool then seach etc
Aug 21, 2008 | Black & Decker Electrical Supplies
Garden Logo
346 people viewed this question
Top Black & Decker Garden Experts
Nick Olsen
Roland W VanLue
Roland W VanLue
Tim Whalen
Are you a Black & Decker Garden Expert? Answer questions, earn points and help others
