Question about Dell Computers & Internet
I need to know the steps to save data onto usb memory stick from accounting program
I need to know the steps from the beginning on how to save data from simply accounting program onto usb memory stick. I back up my data after each session with simply. Do I back up onto memory stick or do I restore???
  • 256 Answers
I suggest that you save your data with Simply Accounting and know where you save it. In window explorer, find the file you saved and copy it to the USB memory stick. You should see the USB memory stick as another drive in Windows Explorer. After the copy is complete, Click the USB memory stick and you should see the file. This way, the copy (back up) is confirmed.
Posted on May 30, 2009
I have Janine 10000. And am buying a new computer. How do I transfer to new compy
Install the program on the new computer. Save the data, patterns and stuff you have saved onto a USB memory stick and not where the program saved it on the old computer. Drop the files into the same location on the new computer.
Jan 06, 2017 | Sewing Machines
Already member Bmenem@aol.com got new computer under name of brainybmenem
Looks like you need to set up your e-mail account onto your new computer. If you still have it set up on your old pc you can go into outlook express and export the account ,save it onto a memory stick,then go onto your new pc and tell the mail program on it (outlook express ? ) to import the account you saved onto your memory stick.
Dec 23, 2013 | Microsoft Windows XP Professional for PC
How to remove and save all contents on Motorola Xoom tablet prier to refactory setting?
Use the Data manager and a usb memory stick and just drag and drop. or copy to your Memory stick.
Nov 25, 2012 | Motorola Mobility Xoom Android Tablet 10.1...
I am having one 4gb pendrive its not opening. now im inserting my pc please recover it.
Don't be panic. you can try some data recovery software. You can see
http://www.asoftech.com/adr/index.html
It tells the steps how to perform data recovery.
If above does not work, you may have to format the pen drive (use quick format), and then use above mentioned software to scan again the pen drive and recover your files.
Apr 05, 2011 | Transcend 4GB JetFlash 110 USB 2.0 Flash...
I just aquired a Dell PC that is newer than my HP PC. I have no idea on how to move all my files and programs over with out loosing anything. Can you send me some instructions through email? Thanks, ...
You cannot just move your programs over, you need to install your programs using the various program installation CDs, because the installation process copies DLL files as well as putting data onto the registery file.
You can copy your data files from your HP PC to a USB memory stick and then plug this USB memory stick into the Dell's USB port and copy the data files to the various folders on the Dell PC.
Sep 03, 2010 | Computers & Internet
I would like some infomation on how to use a memory stick
insert the stick into a USB slot open windows explorer you should the stick(drive)you can save files,data,music,and programs onto this
Aug 19, 2010 | ASUS Computers & Internet
How to use a memory stick right from the start
hi
  • Understand how a Memory Stick Pro works. The small card saves information from a portable device. You can save, delete and rewrite to the card as many times as you want. You can also remove the card and insert it into another device. For example, you can save photos from a camera, then insert the memory card into your laptop to view or download the images.
  • Step 2 Make sure you buy a memory card that matches the demands of your electronic device. The cards have different saving speeds and data-holding capacities. Generally speaking, the more data the card can hold and the faster its speed, the more expensive the memory card. Check your electronic device's product information for recommendations on the best type and size of memory card.
  • Step 3 Insert the Memory Stick Pro into the electronic device. Most devices have a small flap or cover on its side that holds the card. The memory card slides into a slot under the flap. Gently push in the card and close the flap.
  • Step 4 Save to the memory card. Once the card is installed, many devices know to save new data to the card. In some cases, however, you may need to specify where to save files, either to a built-in hard drive or to the memory card.
  • Step 5 To remove the card, open the flap and gently press the card in. The card should then pop out of the slot for easy removal. The card can now be inserted into another device.
  • vote me if your setisfied
    Jun 29, 2010 | SanDisk 2GB Memory Stick Micro M2 Memory...
    My pc havet a drive for my flash memory
    If you want to format to remove all the data from your flash drive and wipe it clean you do not need a program as you can do it through windows.
    Step 1 - Plug in your flash drive to a working usb port Step 2 - Click on start and then click My Computer. Step 3 - Find your memory stick. In most cases drive C is your hard drive and drive D is your disc drive. This means that your memory stick is most likely drive E. It is a removable storage device and not your hard drive. This is very important because you don't want to format your hard drive. Step 4 - Back up any data you want to keep from your flash drive. When you are done with the formatting everything will have been removed from it. Drag the files you want to keep from your memory stick onto a folder on your computer. Step 5 - In your My Computer folder right click on your flash drive icon and click format.
    Mar 18, 2010 | Dane-Elec DaneElec 4GB USB Drive Copper...
    I downloaded the update but the pc cannot open the file . the updater is called eboot. i have it in my pc but cannot open it
    The file is not supposed to be opened by your PC. You have the transfer the file from your PC to the PSP. To do this, you need a USB cable and you have to plug your PSP into your PC.
    Download procedure
    1. Prepare to save the update data on either system storage or Memory Stick Micro™ (M2)™ media, using one of the following methods:
      • Connect the PSP® system to the PC using the USB cable
      • Connect a commercially available Memory Stick USB reader/writer to the PC
      • Use the Memory Stick slot on a PC
    2. Create a folder for the update data on either system storage or Memory Stick™ media.
      Using your PC, create a folder named "PSP". Within the "PSP" folder, create a folder named "GAME". Within the "GAME" folder, create a folder named "UPDATE". (Folder names must be in all uppercase letters).
    3. Download the update data for the PSP-N1000 (PSP®go) series and save it in the "UPDATE" folder created in step 2.
    Notice
    You must save the downloaded data as noted in these instructions. If you do not save in the correct location and with the filename shown below, the system will not recognize the update data.
    • Filename: Save as filename "EBOOT.PBP"
    Nov 19, 2009 | Sony PlayStation Portable (PSP) Console
    Hey i have prob in iso games
    STEP 1: CONNECT YOUR PSP TO PC
    The PSP can function as a USB Memory Stick Duo reader. Using this functionality, you can copy pictures, audio, and other content to and from your Memory Stick Duo. To access the Memory Stick Duo in your PSP from your PC, you'll need a USB cable that has a "Mini-B" connector (common for digital cameras) and a "Standard-A" connector (common for printers, etc). Plug the Mini-B side into the top of your PSP and the Standard-A side into your PC. From the PSP software, navigate to the top of the settings list and select "USB Connection." Your PC (Windows/Mac/Linux) should detect a new "Removable Disk Drive" that you can then access.
    STEP 2: FORMAT YOUR MEMORY STICK
    In order to be able to use your new memory stick on your PSP, you'll have to format it. When you format your memory stick, the formatting will create a set of new folders on your PSP: GAME, MUSIC, PHOTO, and SAVEDATA.
    STEP 3: EXTRACT THE SAVED GAME
    This process will greatly depend on which software you use to extract zip files. WinRAR for instance offers the "extract here" option, which will simply extract the contents of a zip file to it's current directory.
    STEP 4: TRANSFER SAVE GAME TO "SAVEDATA" FOLDER
    Just copy the folder you have just extracted, and paste it into the PSP's "SAVEDATA" folder. But, BEWARE!, to any folder overwrite warnings! Because the PSP save game folders use the same names for the same games, copying folders into these locations could lead to lost data. For this reason, we recommend that you backup your old save games before overwriting them. For Example, I would simply rename a folder like "ULPS0004" to "ULPS0004_backup."
    STEP 5: EXIT USB MODE
    Because your PSP has been in USB Mode throughout this process, just push X to exit. Then you can safely disconnect your PSP from your PC.
    STEP 6: VERIFY TRANSFER OF SAVE DATA
    To verify the integrity of the SAVE GAME data you have just transferred, use the PSP's built-in Save Data Utility. Select it from the "Game" menu.
    That's it, simple and smooth.
    Oct 16, 2008 | Sony PlayStation Portable (PSP) Console
    Computers & Internet Logo
    277 people viewed this question
    mukhtar21 shaikh
    mukhtar21 shaikh
