Question about Acer ASPIRE 3680-2022 Notebook
Nothing happens when powering up
No functions at all. Daughter plugged it into the wall socket without a power surge and the laptop won't boot up. I see the battery lite but nothing. I believe the motherboard is fried. So I am trying to see how much a motherboard would run me. If its fesible to repair or just buy a new one.
  • fougzki May 11, 2010
    Did you try to reseat or clean the RAM module? Turorials see youtube videos.
  • 479 Answers
if the motherboard has gone then it is better to opt for a new one.
Posted on May 30, 2009
My net book won't boot but the power lights are on. I waited almost a day for it to boot but nothing happens It doesn't dispaly anything.What happen.
Try turning off the laptop, unplugging it, pulling out the battery and holding power down for 30-60 seconds. After that's done, put the battery back in, plug it back in, and turn it on.
Oct 19, 2012 | ASUS Eee PC 1000H Laptop
Won't boot up without primary screen.
2 Beeps sometimes refers to memory problems. Try re-seating.
Sep 28, 2012 | Acer Ferrari ONE 200-1799 Notebook
I can't get my dell inspiron to power on. I will charge the battery using the wall charger but will not come on. What can I try?
Try this if will help.
Remove battery and unplug the ac adapter from laptop.
Without the power sources hold down the power button for 10 seconds.
Check the ac adapter from wall power socket if ac adapter LED is ON.
Plug back in the ac adapter to laptop then check the LED from the ac adapter if it stayed on.
If ac adapter LED turned off right after you plug in the ac adapter to laptop then you need to replace the ac adapter, motherboard and power daughter board.
Hold down the D key then Press Power Button once. Check if color display will appear in the screen.
if the ac adapter stays on you and still no power indicator from the laptop you need to replace motherboard and power daughter board.
Hope this helps.
Jun 02, 2011 | Dell Inspiron 6000 Notebook
Won't start up - power supply ok, but no power to laptop
Try removing the battery, plug the power cable into the laptop while it is already plugged into the wall then hold the power button down till it comes on. If/when it works, let it boot all the way, shut it down and put the battery back in. It should boot normal again.
It happens due to a relay tripping after a power surge. That procedure resets the relay. Works on a few name brand laptops, including Toshiba.
May 13, 2010 | Toshiba Satellite A100-S8111TD Notebook
HP PSC 2355 does not "boot up".
Is it connected directly to the wall socket for the power supply or thrugh a surge protector.. if its through surge protector try connecting directly to the wall jack ..
Oct 19, 2009 | HP PSC 2355 All-In-One InkJet Printer
My pc gets no power the flashing green light doesn't come on no fan nothing happens when i press the power button
best guess bad motherboard or bad power supply.
things to test:
1. Check that the power cord is plugged in snugly to the back of the computer and connected to a working power outlet or surge protector.
2. Check that the power cord is good. Replace if needed
3. Have the computers power supply checked. Replace if needed
4. Have the motherboard checked. Replace motherboard or get a new computer your choice.
Sep 09, 2009 | HP Compaq Presario SR2011WM PC Desktop
I have a Canon MP830 and I cannot turn it on when I touch the on off switch nothing happens I have checked all the power sources and they are plugged in; any suggestions?
1. If your MP830 is plugged into a power surge / power strip, power off/on the strip.
2. Plug the MP830 directly into the outlet.
3. Disconnect the power cord and wait 5 minutes before connecting
4. Replace the MP830 printer power cord.
5. Have the MP830 serviced.
Hope this helps.
Aug 12, 2009 | Canon PIXMA IP3500 Photo Inkjet Printer
Asus p5kpl-cm boot problem
Could possibly be a fault on your hard drive the same happened to me ,I checked the hard drive on another pc and it was dead..Good luck John
Aug 02, 2009 | ASUS MB P5KPL-CM C2D LGA775 INTELG31 ICH7...
HP DESKJET380 NOT RESPONDING WHEN CLICK ON PRINT
After sitting in power save mode for a long period of time the printer might not function properly. This happens when the printer is plugged into a surge protector. Unplug from the surge protector and plug directly into the wall power socket.
Step 1:
Please try to print Self test Print from the Printer (without PC ie. remove the USB cable from the PC)
Step 2:
If the Self test Print is Ok, try to connect your printer to PC
and Print Test Page
Go to Start >> Printers and Faxes >> Select your Printer F380
then Right click Properties and Click on "Print Test Page"
If this prints Ok then all the connections you have made are correct
In case, it does not print then please check your USB cable try to change it
Step 3:
You can uninstall your Driver
and install the new driver, to download the driver for F380 All in One Printer Please click the below link
Choose appropriate Operating System
HP F380 All in One Printer Driver
I hope this will resolve your problem
all the best
Jan 05, 2009 | HP DeskJet F380 All-In-One Printer
Acer laptop won't boot up
Try booting the laptop with the battery removed while the laptop is plugged into the wall outlet. Acer has a weird problem sometimes with the battery preventing it from booting. Sometimes it will get as far as logging into windows and then act crazy, slow down, and freeze.
Jul 14, 2008 | Computers & Internet
Open Questions:
Acer ASPIRE 3680-2022 Notebook Logo
44 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Steve Sweetleaf
Steve Sweetleaf
