Question about GPX TVR950 VCR
Tape comes out of cassette when ejected.
When I eject the cassette, the tape is partilly out of the cassette. Is there something that I can do to fix this? It has happened the last three times that I ejected the tape.
  • 45 Answers
Your VCR is "eating" tapes, this is a common problem. First, wind the tape up by sticking a penny or other rounded object into the white "gears" on the back of the tape (with the tape hatch open by holding down the small button on the left side of the tape) and turn either clockwise or counterclockwise. Then check inside the VCR for moisture and remove any and all moisture with a clean rag. Moisture can cause the tape to stick to the VCR's internal components.
Best of luck to you.
Posted on Jun 07, 2009
After the tape rewinds and then I push the eject button, the tape doesn't rewind back into the cassette before ejecting.
This should also be happening when you just eject the cassette without rewinding.
NOT KNOWING THE BRAND, MODEL, OR NUMBER WE CAN ONLY DO SO MUCH!!!!
Best guess is a belt needs to be replaced.
Sep 19, 2016 | Televison & Video
How do you fix a VCR that will not receive a VCR tape?
If a particular cassette is rejected, the tape could be defective. You will have to open up the cassette to determine whether this is the case. If all cassettes are being popped out, the fault may be the internal mechanism and you will have to disassemble the VCR to find what's wrong and fix it.
Mar 20, 2015 | Televison & Video
A cassette has jammed inside my vcr machine. It will not move forward or backward Can yoy please help
Since the tape won't come out then it means you will have to manually remove the stuck tape. This involves you disassembling the unit in order to help/assist the player get the stuck tape out.
Turn of the unit and remove from the wall, get a Philip screw driver, use it to remove all the screws from the unit and take it apart.
Open the cover and you will see the stuck tape and what's hooking or preventing it from coming out/ejecting.
Now plug the unit, and turn it on. Press the eject button, as the tape tries to come out, support it with your hand so that it can come out.
Or if it happen that the cassette tape has coiled inside the unit, carefully free the coiled tape and the press the eject button.
Lastly, the moment you disassemble the player, you would see what's preventing it from coming out, then you can free whatsoever that is making it stuck press the eject button and the tape should come out.
Make sure the unit is turned off each time you want to remove what's making the cassette stuck.
I hope understand the above explanations.
Good luck.
Mar 04, 2011 | Panasonic NV-FJ620 VHS/S-VHS playback VCR
MX2, it displays the following: "remove the cassette" or eject. I thought it was a condensation problem but all attempts failed, please help me.
On Canon camcorders, "remove the tape" error is due to no data reading by video head. You may have clogged heads or somewhere along the area. Initially, I would try to insert good clean "video head cleaning tape" and run for about 7 seconds and see if that resolve the symptom. If it persists, it need a help from a technician. Good Luck. For further help, go to www.camerarepairjapan.com James
Feb 26, 2009 | Canon DM-XM2 Mini DV Digital Camcorder
Denon Dual Cassette Deck DRW-660 will not eject either tape. I put a tape in right side, played a bit, stopped, will not eject. I put another tape in left side, closed, cannot eject. Cannot eject either....
Some dual decks use a common drive belt. It may have become too slack (due to age) to drive mechanism. I am sure its time to change all belts in both decks. This will solve the problem
Apr 05, 2008 | Audio Players & Recorders
Tape stuck in uvw1800 beta cam sp
Use menu system to access "manual eject". Hold left arrow key and press menu to access menu. Follow from there.
Feb 22, 2008 | Sony Betacam SP Small Videocassette 30...
Cassette Tape stuck
Try pushing the eject button while pusshing the power button. Mine was doing the same and that is how I was able to eject the tape.
Good luck
sam
Jan 01, 2008 | Sony TC WE435 Stereo Dual Cassette Deck...
C:32:11 message flashes, cassette eject won't work, camera doesn't work
Just had this problem myself... called Sony. Here is what I did to fix this:
1. Turn off power
2. Open the LCD Display
3. Press "Reset" with paperclip/pen
4. Unplug ANY wires connected to the camcorder
5. Eject battery
6. Plug in DC charger
7. Power on
8. Attempt to eject tape
9. At this point, the metal tape holder comes out but refuses to open... slightly "close" the portion of the camcorder that has the button to eject the tape, and then open it fully again (you'll hear a click, this signals the device that the 'hatch' is open and to eject).
10. The metal door *should* pop out and allow you to withdraw the tape.
I've tried 4 different cassettes and about 2 seconds after hitting play, I get the error every time... my solution: Not going to try to play my tapes on the camcorder anymore... will find another player to play Hi8 MP cassettes. Unknown if able to record to tape as of yet.
Nov 24, 2007 | Sony Handycam DCR-TRV240 Digital Camcorder
Camcorder Canon ZR 200
First if you have a very bad tape (miniDV) (hard to turn by your hand) the camera will automatically eject coz it cant load the tape to it. it is not a head problem. It seems that you have a mechanical loading issue here. But try to put new miniDV tape. ANd post here what happen. PS Dont use compress gas to clean it you might put new problem. Please use only the head cleaner tape (MiniDV) if you want to clean the head. Hope this may help you
Aug 13, 2007 | Canon ZR200 Mini DV Digital Camcorder
GPX TVR950 VCR Logo
148 people viewed this question
Top GPX Televison & Video Experts
Bill T
Level 1 Expert
Jaime Hernandez
Are you a GPX Televison and Video Expert? Answer questions, earn points and help others
