Question about Brother MFC 6490CW InkJet Printer
CD-ROM download install
EVERYTIME THAT I AM NEARING THE COMPLETION OF THE CD DOWNLOAD AN ERROR SCREEN CONTINUES TO COME UP INDICATING:\r\n
AN ERROR OCCURED DURING INSTALLATION
PLEASE RESTART YOUR PC, ENSURE ALL APPLICATIONS ARE CLOSED
-THEN RE-INSTALL "MFL-PRO-SUITE"
ISO31 - CreateFaxRxDataFolder - 0
I have gone to the task manager and ensured that all applications are closed prior to re-inserting CD. I have even tried to close some of the processes (hoping it would help) in the task manager.
Has anyone come across this before?
Thanks,
Craig from Texas
  • 221 Answers
I have a link for you here:
http://welcome.solutions.brother.com/BSC/Public/Templates/DownloadTop.aspx?NRMODE=Published&NRNODEGUID={2C7B4D65-D5B3-47BF-958E-322BE5EFDCA8}&NRORIGINALURL=%2fbsc%2fpublic%2fus%2fus%2fen%2fdlf%2fdownload_top.html%3freg%3dus%26c%3dus%26lang%3den%26prod%3dmfc6490cw_all&NRCACHEHINT=NoModifyGuest&prod=mfc6490cw_all&reg=us&c=us&lang=en
Are you selcting the right OS in the list?
Posted on May 30, 2009
In acer laptop i am getting blue screen error code is 0000000007
Try to restart the computer in Last known good configuration from the Advance boot options by restarting the computer using F8 key continuously.
If doesn't work then put in the Windows CD.
If Windows XP :
Restart the computer and keep tapping F12.
From boot menu highlight CD/DVD or IDE CD ROM or USB CD ROM.
Keep on pressing enter on it until get the screen loading files.
Then on the first Welcome page press "R"
If you have a dual-boot or multiboot system, select the installation that you want to access from the Recovery Console.
Enter the Admin password if dont have any password then leave blank and press enter.
Then type the command chkdsk drive /p /r
(drive is the partition on which windows is installed, C: or D:)
It will take around 30 to 45 mins to complete then restart the computer.
Jun 13, 2011 | Computers & Internet
Tip
If your system is giving you so much performance problem and you have fixed it...
If your system is giving you so much performance problem and you have fixed it now and then, it may be time to reformat the system.
To start, you must have the OS CD you want to run on your system. It may be the same as the one you are running or a newer version. I will advice you get the original CD of the OS this way you can be sure you are installing a complete and certified version of the OS. It will also be bootable. You should also have the copy of all the software you want to run on the system. You may also download the latest drivers for the OS before start the re-installation.
Before starting, move all your document and other important files to the D drive if you have more than one Drive on your system or to an external drive.
Put the OS CD on the CD-ROM and restart the system. As the system boots it will prompt you to press any key to boot from the CD-ROM. at this time press any key and the system will boot from the system. It will prompt you for upgrade or custom installation. Chose custom installation and you will be prompted to choose the drive to install into. Chose drive C and chose the delete option. (Note that this will wipe out all you have previously on this drive).
You will be returned to previous window (with drive and option to delete format etc) click continue and when prompted to format click continue. (Note: this will give you a clean installation without the files and error in the old installation).
After the formatting process the OS is temporarily load to the hard disk and the installation continues. Read very prompting properly before accepting any option provided. Follow the on screen guide and complete the installation. At the end of the installation you will be prompted to enter the computer name and password you can change the default suggested computer name and enter your preferred name. Then enter your desired password.
When you complete this process you have installed a new OS on your system. Update the driver on the system with the drive CD or the downloaded drivers.
Install other necessary software and your system is as good as new.
on Jun 01, 2010 | Computers & Internet
Tip
How to reformat your system with windows Vista or windows 7
If your system is giving you so much performance problem and you have fixed it now and then, you it may be time to reformat the system.
To start you must have the OS CD you want to run on your system. It may be the same as the one you are running or a new version. I will advice you get the original CD of the OS this way you can be sure you are installing a complete and certified version of the OS. It will also be bootable. You should also have the copy of all the software you want to run on the system. You may also download the latest drives for the OS before start the re-installation.
Before starting, move all your document and other important files to the D drive if you have a Drive on your system or to an external drive.
You will be returned to previous window (with drive and option to delete format etc) click continue and when prompted to format click continue. (Note: this will give you a clean installation with the files and error in the old installation).
After the formatting process the OS is temporarily load to the hard disk and the installation continues. Read very prompting properly before accepting any option provided. Follow the on screen guide and complete the installation. at the end of the installation you will be prompted to enter the computer name and password you can change the default suggested computer name and enter your preferred name. Then enter your drsired password.
on May 28, 2010 | Computers & Internet
How do i operate my gearhead web cam
Hi, Follow the below steps.. 1]Turn on your computer 2]After Windows has loaded; insert the enclosed Driver CD into the CD-ROM drive of your computer. 3]The setup screen will start automatically. If it does not start automatically, please click "Start", then "Run...", type "D:\Setup.exe" into the dialog box. (NOTE: "D:\" represents the drive letter assigned to the CD-ROM drive you are using. If D is not the letter assigned to your CD-ROM drive, please replace D with the appropriate drive letter). Then click "OK". 4]Select your language, and then click "OK" to continue.Make sure your Webcam is not connected to your computer, and then click "OK" to continue. 5]At the welcome screen, click "Next" to continue. 6]. Click "Next" to start the installation. For WindowsXP Users: Windows may notify you that the software that you are installing has not passed Windows Logo testing; if this occurs, please click "Continue Anyway" to continue. For Windows Vista Users: If the "Windows Security" dialog box appears during the installation, please click "Install" to continue. 7]After the installation is complete, click "Finish" to close the wizard 8]Plug the USB connector for your Webcam into an available USB 2.0 port on your computer. 9]Windows will detect your Webcam and start the "Found New Hardware Wizard" for your Webcam. 10]For Windows Vista Users: Select the "Locate and install driver software (recommended)" option to start the installation, then click "Continue" under the User Account Control screen. Then please proceed to Step 15. 11]Windows may ask for your permission to connect to the Internet and search for the best driver; if this occurs, please select "No, not this time" and then click "Next" to continue. 12]Select the option "Install the software automatically (Recommended)", and then click "Next" to continue 13]Windows may notify you that the software that you are installing has not passed Windows Logo testing; if this occurs, please click "Continue Anyway" to continue. 13]After the installation is complete, click "Finish". Restart your computer.Once your computer has restarted and Windows has loaded, your Webcam is ready to be used. 14]For other details please go to the below link and download the user manual and refer it. http://pcgearheadsupport.com/download/GH/product/Manual/ML_WC535I.pdf
FEEL FREE TO POST YOUR COMMENTS..THANKS FOR USING FIXYA.. BEST WISHES..
Dec 19, 2010 | Gear Head WC535I Webcam
Hi i'm ricky. my laptop is always shutting down everytime there's a message apppeared telling that NT AUTHORITY SYSTEM TERMINATED UNEXPECTEDLY, DCOM server process launcher terminated unexpecetedly..what...
Just putthe cd windows xp to the rom drive and re-install the windows, be sure that your priority boot will be the cd rom then continue the installation and the system will repair your program.
Feb 02, 2010 | Computers & Internet
These errors may occur during installation: Error 1335. The cabinet file 'Data1.cab' required for this installation is corrupt and cannot be used. This could indicate a network error, an error reading from...
If you have downloaded the package containing this cab file, turn off your firewall. Like wise turn off your anti virus software also for the time being. Download it again and then continue with installation. If the cab file is corrupted on the CD, you may need to find a new one. Hope this helps.
Jan 30, 2010 | Microsoft Windows XP Professional With...
Ibm thinkpad A31 Windows unable to start normally. Message on blue screen indicating "unmountable_boot_volume". Also got "Kernal_data_inpage_error" message. Does this indicate hard drive failure??
No, this is a known error within Windows. Read more information on it here: http://support.microsoft.com/kb/555302
But, if you are like me and don't like to read, just put your windows XP installation CD into the CD-ROM, boot up from the CD-ROM, DO NOT reinstall the operating system...just repair the installation and run "chkdsk /r".
Once that is done, restart the machine and it should boot up fine.
Jan 08, 2010 | IBM ThinkPad A31 Notebook
Brand new computer and i did not install the adobe it came with the computer Vista basic and i get the 1311 error message when i try to run adobe computer 1 day old !
no big problm if u comp is new r old...
When you try to install Adobe Acrobat 6, 7, 8, or 3D on Windows, the installer returns the error message "Error [1311, 1335 or 2350]. Source file not found: [drive name]:\ Adobe Acrobat [version]\data1.cab. Verify that the file exists and that you can access it." If you click Retry, the installer returns the error message "Cannot find the file Adobe Acrobat [version]\data1.cab."
Solution Perform one or more of the following solutions:
Solution 1: Check the Acrobat CD-ROM.
Make sure that the CD-ROM from which you are installing is free of dirt and debris. If necessary, clean the CD-ROM with a soft, lint-free cloth.
Solution 2: Temporarily disable anti-virus software, and then install Acrobat.
For instructions, see the documentation for the anti-virus software or contact the manufacturer.
Solution 3: Extract the compressed installation files, and then install Acrobat.
  1. Right-click the folder and choose Extract All.
  2. Follow the on-screen instructions.
  3. To install Acrobat, double-click the Setup.exe file located in the folder that contains the extracted files.
Solution 4: Uninstall the CD-ROM drive and let Windows redetect it, and then install Acrobat.
  1. Right-click My Computer and choose Properties.
  2. Click the Hardware tab, and then click Device Manager.
  3. Expand the DVD/CD-ROM drives section.
  4. Right-click each device listed under DVD/CD-ROM drives and choose Uninstall. Click OK to confirm.
  5. Close Device Manager and restart the computer.
  6. After Windows redetects the DVD/CD-ROM drive(s), insert the Acrobat CD into the CD-ROM drive and install Acrobat.
Solution 5: Install Acrobat from the desktop.
  1. Insert the Acrobat CD into the CD-ROM drive.
  2. Copy the Acrobat folder from the Acrobat CD to the Desktop.
  3. Double-click setup.exe in the Acrobat folder on the Desktop, and then follow the on-screen instructions to complete installation.
Additional Information Errors 1311, 1335, and 2350 occur when the Acrobat installer is unable to access the necessary files from the CD-ROM drive. These same errors may also occur if antivirus software interferes with an installation or if the installation files are compressed.
thank u sir,, if u feel i helped u, then plz vote/rate me with good marks..thank u!!
Jul 18, 2009 | Dell Inspiron 530s Desktop Computer...
Canoscan Lide 20/lide30 Ver. 1.02 Will not load in my Mac 10.4.11 Tiger.Had it in my previous vergin mac 10.2 but since I've upgraded scanner tells me I've got error .06 and will not reload. I assume I...
http://www.usa.canon.com/consumer/controller;topic=609.msg7369?act=ModelInfoAct&tabact=SupportDetailTabAct&fcategoryid=104&modelid=6624#DownloadDetailAct
Mac OS X (Native Mode)
  1. Turn the computer on. Log in as the first created administrator account to install the software. You cannot install the software when logged in using added administrator accounts.
  2. Place the CanoScan Setup Utility CD-ROM in the drive.
  3. Double-click the CD-ROM icon.
  4. Double-click the MacOS X folder/icon.
  5. Note: Some versions of the CanoScan Setup CD-ROM will not include the Mac OS X version of Toolbox. If this is the case, you should download and install Toolbox from Canon's website. www.canontechsupport.com
    If you will not be installing Toolbox at this time, skip to step 7.
    Double-click the CanoScan Toolbox folder/icon.
  6. Double-click the CanoScan Toolbox Installer icon. Follow the on-screen prompts to complete the installation.
  7. Once the installation of Toolbox is complete, you should then access the ScanGear CS folder also located in the MacOS X folder.
  8. From the ScanGear CS folder, click the ScanGear CS Installer icon. The installer will search for available install locations for the scanner plug-in driver. Follow the on-screen message prompts to complete the installation.
Jun 18, 2009 | Computers & Internet
IN MY SYSTEM UNFORTUNATELY UNINSTALLED THE DRIVER SOFTWARE BUT I HAVE THE CD ROM. AFTER I PUT THE CD ROM AND EXECUTE, DURING THE PROCESS AFTER REACH THE INSTALLATION AT 34% BUT AUTOMATICALLY DISABLE THE...
You can try this:
I am assuming you have a PC based sound system.
1. Remove your Creative Labs Home Theater from your PC. You should remove all hardware.
2. If you have Windows, go to "Control Panel"
3. Select "Add or Remove Programs"
4. Delete all Software releted to your Creative Labs System
5. Go to http://www.creative.com/language.asp?sDestUrl=/support/downloads
6. Download the appropriate driver for your system
7. Reinstall the system with the new driver
You could try your CD ROM after completely deleting the software from your PC, but I think I'd just try the downloaded version. The important thing is to completely remove all hardware and software before reinstalling.
Apr 08, 2009 | Creative Labs Audio Players & Recorders
Brother MFC 6490CW InkJet Printer Logo
768 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
