Question about Singer 1120 Mechanical Sewing Machine
Thread bunches up from bobbin feed.
The bobbin thread on our Singer CG590 bunches up at the baseplate and stops material feed after 4 or 5 stitches. We have not had the machine very long but have used it extensively with the same material about 15 times. The problem just started all of a sudden. It started doing it during the sewing but now does it when you start sewing. It could be we've dorked up the settings but we're only sewing straight stitch and I can't see how that can be so badly adjusted to cause this problem. We've removed the bobbin case and there's no lose thread or material lodged anywhere that we can see (which is pretty much everything down there.
Any advise would be appreciated.
  • Mongo32
    Mongo32 May 11, 2010
    when you say "bobbin thread bunches up at the base plate" do you mean there are big loops of thread underneath the fabric,
    or on top?
  • 25 Answers
Remove the needle plate and clean the feed dogs there could be fluff gathering.
Check your needle is not damaged.
Posted on Jun 03, 2009
I have just been given a singer melodie 40.When I start to sew, material is stopped by bobbin? Bobbin is breaking off bits of thread underneath?
Try a brand new needle. Make sure the thread is suitable to the needle and fabric you are using. AVOID old or bargain bin threads. Spend an extra dollar or two for good thread.
All About Needles
Check that there are no loose threads stuck in the upper thread path, ie the tension disk.
ALWAYS RAISE the presser foot when threading the upper thread. Verify that the thread path is correct. Mis-threading will invariably cause broken thread.
Clean out the bobbin area & feed dogs of any lint and loose threads. Check that the bobbin has been installed & threaded correctly and turning the right direction in the bobbin case.
Manually rotate the handwheel one turn until the upper thread grabs the the bobbin thread. Pull it the rest of the way to the top. When beginning to stitch, start slowly and gently hold both thread tails in your left hand until it has made a couple of stitches.
How and Why to Bring up the Bobbin Thread
If you have a manual, make sure you follow the maintenance tips. If the machine needs oiling, be sure to follow the instructions using only fresh good quality sewing machine oil. Most machines that have been given as gifts from a sewist's stash may not have been maintained regularly.
If it still does not stitch properly, take it for service. It could have a timing issue, ie the needle arrives at the bobbin at the wrong time to intercept the bobbin thread.
Singer melodie 40 user manual
Oct 25, 2016 | Singer Sewing Machines
I have problems starting sewing with my singer sewing machine.The cotton bunches below the material for the first 2or3 stitches
Before you begin sewing, it is always helpful to pull up the bobbin thread up through the project fabric.
Before you take the first stitch, be sure the thread take-up lever is at its highest point. Then, gently hold the two thread tails in your left hand and slowly begin to stitch.
Sep 18, 2016 | Singer Sewing Machines
Machine well not work with the quilting foot what can I do
Basic Tips for All
  1. Always turn the handwheel TOWARDS you (counter clockwise) as turning it in the opposite direction (away from you, clockwise) may knock the timing out requiring repair from a service center.
  2. Always be sure your presser foot is in the DOWN position before sewing. Sewing with the presser foot in the up position will cause your thread to tangle and your bobbin to jam.
  3. Change needles regularly (after 16 hours of use) as dull/weak needles can cause damage to your machine and fabric. Only use SINGER needles on your SINGER sewing machine.
  4. Always be sure you are using the correct bobbin for your machine. Class 66, Class 15 and Class 15J bobbins look very similar. However, using the incorrect bobbin class in your machine can cause damage.
How do I thread my 3/4 thread serger? (14SH654, 14ET754, 14SH764, 14CG754)
Q.
How do I thread my 2/3/4/5 thread serger? (14T967, 14T968, 14T957)
Why is my electronic machine beeping? Why won't my machine sew? Why will my machine start to sew then stop?
Q.
How do I sew denim and heavy fabrics?
Q.
Why is my bobbin not winding evenly?
Q.
Why won't my machine pick up the bobbin thread?
Q.
Why is my machine skipping stitches?
Q.
Why is the thread looping/bunching under my fabric?
Q.
Why is the thread looping/bunching on top of my fabric?
Q.
Why doesn't my stitch pattern match what is on my machine?
Q.
How often should I oil my machine?
Q.
What types of thread should I use?
Q.
I can't see the take-up lever? h
May 17, 2015 | Juki Sewing Machines
How can I stop my material sliding around when I am sewing?
Basic Tips for All
Q.
Q.
Q.
Q.
Q.
Q.
Q.
Q.
Q.
Q.
Q.
I can't see the take-up lever? t
May 16, 2015 | Sewing Machines
I have a Singer
Which stitch are you using?
To check thread tension for straight stitches, use different colors of thread in your top thread and bobbin. If the top thread shows on the bottom of the fabric, turn the dial counter-clockwise (towards a lower number). If the bottom thread shows on the top, turn the dial clockwise. Do not adjust the tension too much (for example, go from 2 to 2.5 if increasing the tension) at a time; test another set of stitches. Alternatively, you can adjust the bobbin tension in the reverse directions. However, it's very easy to damage the set screw in the bobbin case so do this as a last resort. Since this is a vertical bobbin case, put the bobbin in and hold onto the thread. If the thread moves when you dangle the bobbin case, tighten the screw. Loosen the screw if the thread doesn't pull out of the bobbin when you hold the unit.
For zig-zag decorative stitches lower the tension until the puckering stops. Usually the top thread will show on the bottom of the fabric.
If the tension is not changing when you turn the dial, make sure that the presser foot is down. The sewing machine may need repair. The tension mechanism depends on a spring and that can break. See the Singer site for a parts breakdown and contact your Singer dealer for the parts.
If the top and bottom fabric are not moving at the same rate, you can get a different type of puckering. You may want to get an even feed foot if there are several layers of fabric.
The manual for the 3116 is available from Singer: http://www.singerco.com/uploads/download/438_3116.pdf .
I hope this helps.
Dec 08, 2011 | Singer 3116 Simple
The thread is bunching under the fabric even though the stitch looks perfectly find from the top
Change needle-flat side to the back of the machine
Clean under needle plate where feed dogs are for lint
Clean bobbin area for lint or loose threads
Rethread machine top thread make sure to get every thread guide
& make sure bobbin is wound correctly & that it is inserted correctly in the bobbin case or shuttle
Check tension 3 or 4 is usually good
with some machines the thread comes off the thread take up lever
Nov 24, 2010 | Singer Sewing Machines
Thread is bunching up and pulling fabric into feed dogs. also breaking top thread. i have cleaned and oiled,adjusted stitch length,changed needle, re-threaded, and adjusted tension. i should note i am a...
If the thread bunches up on the bottom sometimes it is the bobbin tension. You can remove the bobbin housing and may notice a screw. This screw "tensions" the tab where the thread goes through, creating tension on the thread. Another thing to check if the machine is on a "loose/stretch" stitch setting, this will allow the elastic to freely expand and contract. You may need to also adjust the "speed" of the feed teeth, to compensate for the slack. Often there is "stray thread" in or around the bobbin, which can cause problems, One of these may be the solution, Im being general in my information.
Mar 21, 2010 | Singer 7442 Mechanical Sewing Machine
Singer sewing machine stiches not forming & thread bunching
Sounds like what is called bird nests or thread nests. The top thread is not seated completely in the tension disk.
Remove the top thread completely from the machine.
ALWAYS RAISE the presser foot and rethread from the beginning. Verify the thread path is correct.
Now, retest your machine.
Jun 28, 2017 | Singer Sewing Machines
Thread bunchingup on bottom of material on singer
Here are some solutions to try.
* Re-thread your machine
It may be threaded incorrectly.
* Raise your feed dogs If your machine has this feature.
* When you start to sew a seam, hold the upper and bobbin thread tails back and out of the way as you sew your first couple of stitches. This will keep them from getting caught in your machine.
I hope this helps.
Dec 28, 2009 | Sewing Machines
Bobbin thread bunching
I have a Singer 2950. The thread keeps getting bunched up on the reserve side of the fabric, and does not stitch. It is driving me crazy. I think I have the bobbin threaded correctly, as well as the machine. I have tried everything! Please help!
Oct 22, 2007 | Sewing Machines
Singer 1120 Mechanical Sewing Machine Logo
456 people viewed this question
Top Singer Sewing Machines Experts
Tally Girl
Tally Girl
mystery_soul
Are you a Singer Sewing Machine Expert? Answer questions, earn points and help others
