Question about Sony PlayStation 2 Slimline Console
Play ps2 games using pendrive
It is the way to insert ps2 games into pendrive and play into ps2?? it is need ro use usb advance to play it??
Cerfer39
  • 709 Answers
SOURCE: My PS2 will not play PS2 games, but it will play PS1 games
Hi
If it will play DVD's this is a good sign. You will only need to clean the lens of the laser. Also clean the hub that the Disc rides on.
I hope your in the right posting area, this is for the Phat PS2 consoles with the drawer that comes out to put the CD in. Procedure is different for Slim PS2.
  1. Disconnect power and turn the case upside down.
  2. Remove the screw covers to expose the case screws. These are little square pieces or square rubber pads. You can use a thin knife blade to pry the hard plastic squares up.
  3. Remove all the screws.
  4. REmove the Warranty sticker to the right edge of the power socket.
  5. Turn the PS2 over to set it right side up.
  6. lift the top cover from the back and pull it forward slightly to clear the CD tray. Be careful of a possibly Ribbon cable attached to the lid going to the REset/Eject buttons. Roll the cover over to the right leaving the ribbon intact.
  7. Remove the Cd tray lid.
  8. Polish the Laser lens, and remove any lint or hair from the Cd area. Use Alcohol and cotton swabs to clean the laser lens. By the way, Alcohol will damage a PS2 Slim lens. All lens are not created equally.
  9. Hook up the power and A/v Cables.
  10. REmove the little white disc from the Cd tray lid.
  11. Place a Disc on the spindle, and cap the disc with the little white piece that you removed from the CD tray cover.
  12. Boot up the PS2 and test it, Continue cleaning until you get it to work.
  13. Put it back together, and your in business.
If you have trouble you can send your PS2 to the Playstation Clinic for Repair. Contact Repairtech@playstationclinic.com
Posted on Nov 05, 2007
Roshan89
  • 271 Answers
SOURCE: PS2 games bought in Bali
Look into the rear side of the PS2 you will see something like (NTSC or PAL).This the format of your PS2.you will have to by games with that format.
Posted on Mar 07, 2008
SOURCE: how to store games , saved games on a USB pendrive?
hi u can
Posted on Mar 08, 2008
  • 586 Answers
SOURCE: please insert a playstation or ps2 format disc
This problem actually related to the region change.For this problem you have to install a modification chip in your PS2 console after that it will play all your games according to your region.
For this you have to contact any expert nearby to you.
Thanks
Posted on Oct 23, 2008
SOURCE: Cant Play Pirated games on my PS2 SLim
get ur ps2 modded then u can play pirated/burned games.
Posted on Apr 20, 2009
How to play games in ps2 with usb
- You need to have a software called USB Advance or USB Extreme(search the internet)
- Write this software using DVD Decrypter onto a blank CD-R.
- Insert the disc into the playstation 2.
- You should have a USB Pen drive ready, of capacity minimum 4 GB.
- Alongwith the USB Advance, you will get a software for your PC to convert the downloaded games into the games playable through USB.
- Open the software, browse for a game file, and convert it.
- Now insert the pen drive into your computer and copy the converted game files into the pen drive.
- Remove the pen drive from computer and insert it in your PS2.
- Boot your PS2 with the USB ADvance CD in it and now select the game and press the 'X' button to play!
Oct 13, 2011 | Sony PlayStation 2 (PS2) Console
I ve got sony ps2 in india and i always have to get a new gaming cd. is there any option to unlock my ps2 so that i even use pirated cds on it.
If your PS2 is made pre-2009 (has a manufacturer number less than 9xxxxxxxx) then you can use a bootloader to unlock the USB and hardrive to play "backed up" games and AVI movies.
You will need on of these things:
1) an original copy of 007 Agent Under Fire or an original PS1 game, to use as a "trigger" disk.
2) a original copy of Gameshark, SwapMagic, or CodeBreaker for PS2 (DL'ed copies wont work)
and you will need:
1) a memory card plugged into your PS2 slot 1
2) a USB drive
Now do this:
Load the boatloader ELF file from a burner "backup copy" of your 007 disk (using the "disk swap trick" on your "sensor-modded" PS2. I used ESR Disk Patcher and Apache V1.1 to alter the TOC values of the ELF file and "patch" the ISO file before burning, and I used the disk swap trick after playing level one of the game, saving, and then loading the "driving level" (level 2).
OR use SwapMagic or similar tool to load the bootloader. You can find Youtube videos detailing this process.
Install Free McBoot onto your memcard using the bootloader. You can use the "noobie package", use google to find this and put the files onto yor USB card. Voila! Now you can play AVI files or "backed up" games from USB or hard-drive, among other fun things.
Apr 24, 2011 | Sony PlayStation 2 (PS2) Console
How to put games on usb in ps2 to play ps2 without cd games usb only..?
Search online for hacks and apps,,also they have a app you can buy or download,,called usb advance,,that makes it where you can do stuff like that,,also find you the ps2 hdd online ,,then buy the thing called hdd laoder,,witch is the best solution for that,,u can then download ps2 games then straight to hdd,,and play them,,download u torrent,,or bit torrent,,thats where u can get hacks,,and any ps2 game for free,,,thanks hope was helpful.
Nov 18, 2010 | Sony PlayStation 2 (PS2) Console
What type of format i can play with my Sony Play Station 2, Model No: SCPH-75004, Can i also play audio songs through pendrive with help of USB in Sony Play station 2
No on the usb also cant you just play audio cds on the ps2 unit it's self and for format a us region ps2 can play DVD, CD,blue disc and black discs with region code ntsc u/c
Sep 18, 2009 | Sony PlayStation 2 (PS2) Console
Ps2 hardisk
nope. yo u can only use a phat ps2 the big ones and the hardrive is very pricing as there not made anymore
Jun 24, 2009 | Sony PlayStation 2 (PS2) Console
Play PAL Disc on NTSC U/C PS2 Playstation
Hi speed Play satation gmae plesae send deatils for my ID Ashisdev@gmail.com
Feb 24, 2009 | Sony PlayStation 2 (PS2) Console
Platstation-2 save files transfer to memory card
interesting... call sony they will have better information but since its a china model it might not read the flashdrive
May 03, 2008 | Sony PlayStation 2 (PS2) Console
How to store games , saved games on a USB pendrive?
u can run ps2,psx,xbox games from pendrive
use dis software
http://www.ps2-scene.org/forums/official-ulaunchelf-forums/37242-unofficial-launchelf-v4-30-a.html
ONLY USE uLE V4.30 and NOTTTT v4.31
(check youtube if u dont believe me)
Mar 08, 2008 | Sony PlayStation 2 Slimline Console
Ps1 disc playing in ps2
Are you inserting a PS2 or a PS1 memory card?
PS1 games can't use a PS2 card because they don't "understand" how to read them.
To save a PS1 game on a PS2 you will need a PS1 memory card.
I hope this helps, I assume this is what you are referring to with your question.
Dec 25, 2007 | Sony PlayStation (PS) Console
Ps2 slim
you can not play a pirated cd because of different region you need the assistance of a technician by modifying this, probably the change of the lens is the correct answer
Dec 02, 2007 | Sony PlayStation 2 (PS2) Console
Sony PlayStation 2 Slimline Console Logo
574 people viewed this question
Top Sony Video Game Consoles & Games Experts
shaun taylor
marley mcelhinney
juanmireles1
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
