Question about Refrigerators
I have the above listed Hotpoint side by side HSS251FMD WW. It has chronically frozen up. I have replaced the motherboard, several temperature sensors and the defrosting unit. Yet the problem continues. Ice builds up on the coils and frost on the coverplate in the freezer side side soon or later. Have lost a lot of food because of this problem. Is it common? What does it take to repair it or should I just consider replacing it?
    Brigadier General:
  • 3,917 Answers
Since you have already changed some of the parts which could possibly be one of the reasons for the chronically freezing up issue I would suggest one last thing.
It most likely that the contacts in the cold control (thermostat) have fused together keeping the compressor running all the time and freezing everything. You need to replace the cold control.
It could also be that the condensate drain is plugging up causing the condensate to backup and freeze on the coils, or you have a defective evaporator.
In any case, if your fridge under warranty, I would recommend getting it replaced or serviced by a qualified technician, preferably someone from Hopoint itself..
If this does not work , then please give a thought of replacing the fridge with a new one.
Thanks
Posted on May 30, 2009
How do I fix my refrigerqtor hotpoint double door not defrostiong
Generally, if you unplug the refrigerator and set the freezer and refrigerator temperature controls to off then plug it back it, this will put the refrigerator in forced defrost mode. Keep the doors closed and allow defrosting to last for about 20 minutes. Then unplug again and reset the temperature controls to mid-range or a little above, and plug it back in. If this does not reset the defrost cycle, you probably need service.
Mar 07, 2015 | Hotpoint Refrigerators
After a moving to a new city, we had our Hotpoint model HSS251FMD WW refrig in storage for 4 months. When I installed it in our new house it will not cool. Is there a reset button?
flush the refrigerant by nitrogen & refile new refrigerant.every work doing by qualified technician.my be some compressor oil over com in freezer
Jan 03, 2011 | Hotpoint Refrigerators
Where is the hotpoint HSS251FMD WW defrost timer located?
Hi, I think Your model number is HSS25IFMDCC . There is no defrost timer on your refrigerator, main relay board controls defrost cycles in this fridge. main board p/n WR55X10942 But I suggest to check on heater and defrost switch first - more common problem on this refrigerators. here is my video. hope it helps.
Aug 24, 2010 | Hotpoint HSS25IFMCC / HSS25IFMWW Side by...
Hotpoint side by side (Model HSS251FMD) ice/condensation build-up by the ice exit. We had the entire freezer door replaced several years ago covered by a recall. Same problem re-occuring. Any repair...
more than likely no the baffel door that opens when the call for ice is performed is more than likely sticking open due to the possibilty of beverage sloshing up and around the piviot points
Nov 28, 2009 | Hotpoint HSS25IFMCC / HSS25IFMWW Side by...
I have a side by side Hotpoint model #HSS251FMD.The water dispenser stopped. Replaced filter and now no water or ice.
sounds like the water inlet valve is not letting the water come in. need to check and perhaps replace this valve. hope this helps.
Oct 13, 2009 | Hotpoint HSS25GFT 25.0 Cu. Ft....
Freezer is completely covered with white ice
sometimes a faulty door rubber can make the freezer work overtime. Does the door close firmly?
Oct 25, 2008 | Refrigerators
Refrigerators Logo
37 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
