Question about GE Spacemaker Washer and Dryer Electric Laundry Center
GE stackable washer loud noise during spin cycle
GE stackable washer/dryer combo washer has loud noise during spin cycle
  • 7 Answers
SOURCE: Washer won't agitate or spin out.
Well it is ethier Belt, Cluch ,motor ,Or transmission. But it does sound like your transmission . The loud clunk is the brake in the gear case ( Trans.). It might have broken off.
Posted on May 05, 2009
catriver
  • 878 Answers
SOURCE: GE Model WHDSR209D2WW makes unbearable loud metal Screeching noise
ppr78, couple of things you want to check. The bottom panel on these GE's are pretty flimsy. I have run into a couple where during agitation the bottom of the motor housing would rub against the bottom panel making a terrible noise. You need to remove the front panel by pusing on the clips on the left and right side just under the top. The front panel will pull out. During agitation, take your foot and push down on the bottom panel and see if the screech goes away. I have also found the suspension rod support sockets at the top dry out and make a screeching noise. You also want to check your belt and pully and see if the noise is from there. Check these things first...Catriver..post back.
Posted on Jan 13, 2007
SOURCE: GE Washer WPSQ4160T
TRY REMOVING FRONT OF WASHER YOU WILL SEE 4 SHOCK LIKE PISTONS TAY GET DRY AND MAKE GRINDING NOISE OR SQUEEKS LUBERCATE ALL REAR HARD TO GET AT MAKE SURE YOU GET TOP AND BOTTOM (RAY)
Posted on Nov 17, 2007
  • 7 Answers
SOURCE: loud noise during spin cycle
this is my experience repairing the maytag washer Atlantis mav series 9750 aww, I had to replace the spin bearing since it was making a jet engine noise when it was spinning out the water. its not an easy job for my 1st time taking this machine apart, you literally take it all apart to get to this bearing, but now I can show how to do it with pictures making it easier for you to do it. even if you have to replace something other than the spin bearing, this how to tutorial will show you how to get to most of the parts in this machine
tutorial located here tutorial located here https://sites.google.com/site/maytagwasherrepair/maytag-washer-repair
Posted on Apr 08, 2008
duby1990
  • 367 Answers
SOURCE: Maytag Washer HAV2558AWW loud noise during spin cycle
Your maytag is really an amana and the bearings are bad. Yes it does cost a lot. If i were you i would buy another washer. Get a whirlpool. (whirlpool now owns maytag)
Posted on Nov 18, 2008
I have a top load fridgidaire washer model fwsc445rfs0. During the wash cycle it makes a high pitched scraping noise.... Struggles also while it winds down before rinse. Bearing maybe?
How To Fix A Washing Machine Making Noise During The ...
removeandreplace.com/.../washing-machine-making-noise-during-the-sp...
Jul 27, 2015 - Agitator directional cogs aka "agitator dogs" (top load washers) ... If you hear a rubbing sound or the drum spins uneven, then the ... A washer making a loud noise during spin cycle can also be caused ... The clutch in a washing machine connects the inner wash tub to the ..... May 8, 2015; High Water Bill?
Dishwasher Making Loud Grinding Noise During Wash Cycle
removeandreplace.com/.../dishwasher-making-loud-grinding-noise-durin...
Apr 11, 2014 - Dishwasher Making Loud Grinding Noise During Wash Cycle ... GE, Whirlpool, Frigidaire, KitchenAid, Maytag, Kenmore, and LG) this is a .... Our Amana dishwasher is making a loud, high-pitched squealing noise throughout the wash ....Out Of A Washing Machine - Top Load & Front Load September 30, ...
All comments on Loud dishwasher Frigidaire Gallery mode ...
https://www.youtube.com/all_comments?v=v-arYb20kOk
Dec 03, 2015 | Washing Machines
My washer/dryer combo Frigidaire washer dosn't spin water out of clothes completely after spin cycles the clothes is still very wet. On the 1st spin cycle drum dosn't spin just makes noise,the 2nd and...
Good Afternoon Friend,
I understand your Frigidaire laundry center, model# FGX831CS, is not spinning water out of your clothes completely. I see that on the first spin cycle the drum is not spinning and is just making noise, and on the second spin cycle the drum spins to the left very slowly and loudly. First check to see if your washer is overloaded. Try taking some clothes out and spinning them again. Secondly, make sure that the load is not out of balance. Try rearranging the clothes to allow for proper spinning. I ask that you please follow up with a comment on the post, at your convenience, to advise if further troubleshooting is needed or if your dryer status has changed successfully. Hope this is helpful.
-Best Regards-
WP
May 19, 2014 | Frigidaire FGX831CS Top Load Stacked...
Drum knock when spin cycle
Hello.
Noises are common when using a two-in-one washer and dryer, as clicking or whirring is part of the cleaning process during the transition to the next cleaning process. The GE Spacesaver washer and dryer combo uses a top-loading washer stacked beneath the front-loading dryer, and uses an agitator that makes noises throughout the spin cycle. Although whirring or clicking is normal, other noises or malfunction indicates a problem with the washer that requires minor troubleshooting. Professional repair is necessary if the washer continues to experience problems during the spin cycle, as there may be a problem with the washer's agitator.
1 Open the washer's door and check the balance of the load's clothes. Clothes that are unevenly distributed around the agitator cause excessive shaking and result in an imbalance during the spin cycle. Reduce the load's size by removing clothing if the washer's drum is overloaded.
2 Push "Start/Pause" to pause the spin cycle and turn the washer's cycle knob to the "Off" position. Turn the knob to "Spin Only" and press "Start/Pause" to reset the cycle.
3 Turn the wrench counterclockwise or clockwise around the unit's legs to adjust the appliance's balance. The legs are adjustable with the help of a wrench to ensure the unit does not shake while in use. An unleveled unit shakes as it spins, and causes excessive squealing or rattling as it attempts to dry the clothes.
4 Touch "Start/Pause" on the front of the washer's control panel and unplug the washer/dryer unit's power cord from the electric oultlet. Wait two minutes and plug the power cord back into the electric outlet. Push "Start/Pause" to resume the spin cycle.
Thanks.
Nov 08, 2011 | Whirlpool Duet GHW9150P Front Load Washer
LG washer - loud noises & brown spots on clothes.
The drum bearing has perished this wild cause the noise and the brown spots on your clothes is probably the grease from the bearing
May 05, 2017 | LG WM2077CW Laundry XL Front Load...
Ge stackable washer dryer MODEL wsm2700wbwww
3 year old GE stackable washing machine, had water coming out the top and would not drain or go through cycle, when shut off it drained a little but when turned on again it filled up and over flowed.
Apr 18, 2010 | GE Spacemaker Washer and Dryer Electric...
Water under stackable washer dryer
The front panel comes off and you will be able to trace the water source. These combo units spin immediatly and if the drain is slow the water will spin up over the edge of the tub during drain.
Eric
Dec 24, 2009 | Kenmore 98702 Stacked Washer/Dryer
Extremely loud noise during spin cycle of my Neptune dryer--just started happening in the last month. The dryer is probably 7-8 years old, so it's not the newer Neptune model.
Here is a tip that I wrote about dryers and noises...
It will help you determine what is happening there...
Dryer Repair Squeaks, Grinding, Clicking and Knocking Noise
heatman101
hgd76
Jun 26, 2009 | Maytag Neptune Washer
Loud noise coming from bottom of washer during spin cycle
If it is a ge kenmore it sounds like your tub bearing is dry and needs to be replaced.The reason i say ge kenmore is because they fall under differant companys depending on witch year you bought it
May 07, 2009 | Whirlpool Inglis IP4400 Washer
Washer won't spin
Check the washer motor. Make sure that the motor is getting correct voltage and is working and spinning when you turn it on. It sounds like the motor is bad. You can remove the back cover to get to the motor to check it out
Feb 13, 2009 | GE Spacemaker Washer and Dryer Electric...
Noise during spin cycles
GE WPXH214ACC Washer drum makes loud noise when spinning sometimes. We've had it since 2005 & never had this happen before. Washer is level, must stop & redistribute clothes to correct. Just started happening now.
Oct 12, 2007 | Washing Machines
GE Spacemaker Washer and Dryer Electric Laundry Center Logo
1,165 people viewed this question
Top GE Washing Machines Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
