Question about Dell Inspiron 1525 Laptop
I try to record something from power mixertrough line in. my comp sais can not find the mixer program sndvo 132 /r'' Can you help me? thank you
  • 31 Answers
Go to this link & I'm sure it could solve your problem... Trust me... :-)
http://www.laptops-drivers.com
Posted on Jul 12, 2009
DEAR SIR/MADAM WHEN I TRY TO RECORD MY VOICE VIA MICRO PHONE SINGING WHILE THE CD MUSIC TRACKS ARE PLAYING I COULD NOT RECORD THAT TO THE MINI DISC.PLEASE ADVISE ME HOW COULD I CONNECT IT DIGITALLY
It is much easier to use an analog mixer and microphone thru the mixer. I would plug the microphone into the mike input on the mixer and then the Karaoke machine to stereo LINE inputs on the the Mixer, then Mixer Output or Tape Output on the mixer to analog LINE IN on the MiniDisc recorder.
Let me know if you need more info.
Jan 16, 2016 | Tascam Audio Players & Recorders
How can i recoder from mixer
The CD recorder need to have a Line input usually in the form of RCA Left and Right. Then you need to connect the appropriate cable from the Mixers outputs (line output not from an amplifier for speakers) to the input of the CD recorder. If you have no line outputs then a headphone output will do in a pinch but might be dirty sound. Make sure to keep levels low as in CD recording once you hit O there is no more level like on tape. It will just truncate the data and might give a clipped sound output.
Jan 20, 2013 | Harman Kardon CDR2 2-Disc CD Recorder
I am trying to record with my mxl 990 micrphone onto my laptop but when i try to record no sound is heard
you can't just plug and play with these high end mics. You require a +48v phantom power source from something such as a mixer. Then plug the mic into the mixer and the mixer into the LINE IN on the PC
Jan 07, 2011 | MXL 990s Professional Microphone
I can't seem to figure out how to record one track over another without a delay problem? I am using the behringer 1202 mixer into my computer. No problem recording but can't do multiple tracks. I'm new...
This is a common problem with digital recording. Simply put, it takes some time to convert analog (audio) to digital and then more time to convert it back. So, your playback track goes through conversion and introduces some delay. You don't hear this because you have no zero reference. Your recorded sound goes through the A/D converter and also incurs some delay. When you play them back together, you hear the difference in time from one track to another. Most pro recording programs have some method to minimize or cancel the delay like slipping the tracks so they all start together. Pro Tools just introduced a version that automatically does this. They have always had what it called "low latency" monitoring which attempts to keep the "shortest" digital/analog path so overdubs are close enough that we don't hear any issues. So, since you talk about the mixer but not the recording program, I can't tell you specifics but I'd look into the recording program for time alignment settings and options. If you have a manual for the recording program, try to look up latency.
Dec 08, 2010 | Behringer Rx 1202fx 12 Channel Line and...
I am trying to connect my mackie 1604 into my m audio device so i can record off of a program on my computer. How do I do that?
Using two balanced lines either TRS or XLR depending on what is on your M audiointerface, connect the L and R main outputs of the mixer to the L and R inputs of the M Audio. You will need recording software on your computer.
Nov 27, 2010 | Mackie 1604 Vlz3 16 Channel Mixer
Crackling noise and low volume
If the mic is a condensor you would need to have phantom power, or it will not work. Use a small mixer or externat power supply. We here at Pro Line Music Have small mixers that have phantom power. 215-736-8055
Dec 26, 2009 | AKG Perception 120 Microphone
How to connect mixer 100 fx to uca 202 and laptop
Just connect:
one output from 100fx to uca202 line in. Connect an output that corresponds what you want to get (e.g. if you're going to record something use record out or main out)
one line input from 100fx to uca202 line out.
the USB cable from uca202 to your laptop's USB port.
The solution is the same (in general) whatever mixer you may have.
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"????????? ???????"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0cm 5.4pt 0cm 5.4pt; mso-para-margin:0cm; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} In case of a problem or clarification, don't hesitate to post.
Thanks and regards
Please kindly rate this solution
Stelios
Dec 03, 2009 | Behringer (UCA202) Sound Card
Lexicon Lamda Problem
I have a Sterling st-51 condenser mic and purchased a Behringer xenyx 1002b mixer. Similar problem, dynamic mics work in low impedence with or without phantom pwr on. My Washburn acoustic bass with preamp in line input section. So I tried it on my Omega Lexicon interface. The condenser mic and everything else works on the Omega. This unit has a wall wart ( your Lambda is USB powered). I checked the voltages with a meter and found 23 volts from the mixer and 48 volts from the Omega. Further, I have two Shure SM-82 line mics which work on the mixer with the inputs turned all the way down but do not work on the Omega nor on my Spirit SX mixer which has 48 volts phantom power. The SM-82s are old line mics that have a 9.6 volt battery in the sleeve. They overload badly in all but the 1002B mixer. Their voltage should run btwn the 9.6 battery or a 22 volt phantom power.
Check your Lambda voltage, It could be way less than needed by the st-51. I will check with a friend who has the Lambda and check its voltage. Bet it is too low.
Again, My St-51 and 1002B mixer combo barely works at 23volts, the Mic gain is all the way up as is the channel slider and the main output slider. I cant get any reading on my led meters, occasional bump on the first light, no possible way to clip the input or the output and have to turn the high eq off and the mid way back due to hiss noise. Hope this helps,couldn't find minimum voltages on the ST-51 as yet.
Dec 27, 2008 | Lexicon Lambda Usb Desktop Recording...
Feedback noise from mixer
Your mixer is already grounded, and does not need any additional grounding. It is grounded through the Power Cord.
Now, the feedback might be coming from one of the units you have connected to the mixer. The issue could also be the cable you are connecting to your recorder. Are you recording to a computer, or to some other external recorder (CDR / DVR / MDR, etc?) - try a different cable. Also try the different outputs on the mixer - you have 2 balanced line outputs you can record directly from. Don't use the RECORD OUT line, it's an unbalanced line, and if you want a good quality signal to record, your best bet is to use the XLR outputs. However, that might be connected to your amp or something.
What do you have going to the unit? Disconnect everything, and try by connecting each item 1 by 1, to eliminate where this feedback is coming from. Also, check for any ground loops that you might have, if you have a lot of equipment hooked up in your set up. (Educate yourself on Ground Loops)
If all else fails, get yourself a HUM ELIMINATOR.
- OPTiC
DJ Equipment Repair & Service
A DJ Pro Audio Co.
Nov 12, 2008 | Pioneer DJM-600 Silver Professional DJ...
Dell Inspiron 1525 Laptop Logo
134 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
