Question about Williams 3003622 Ceramic Wall Mounted Panel Heater
How to clean
I am trying to clean the heater and can not figure out how to remove the heater cover.  Please help.
On mine, which is the same model, the entire white cover comes off. It should be secured to the wall with a screw (mine was in the bottom and was visible once the lower door was opened. Once the screw was removed the entire white cover lifted right off.
Posted on Oct 25, 2009
  • 625 Answers
Should be screw in between the louver on the front panel. the top may come off after loosening a few screws that hold the cover on.
Posted on Nov 15, 2007
I have a clogged fuel line (filter?) I do I remove the bushing without damaging it?
(For 40/55/60/70/110/115/155/165 Models
1. Remove side cover screws using 5/16" nutdriver.
2. Remove side cover.
3. Pull upper fuel line off fuel filter neck (see
Figure 15 or 16).
4. Carefully pry bushing, fuel filter, and lower
fuel line (110/115/155/165 Models only) out
of fuel tank (see Figure 16).
5. Wash fuel filter with clean fuel and replace in tank.
6. Attach upper fuel line to fuel filter neck.
7. Replace side cover.
Jan 20, 2012 | Reddy Heater-70,000 BTU Kerosene w/T'stat
No heat.. trying to see why.. gas goes on ands ten off in 10 seconds.. the yellow perge light is flashing - maybe related.. help?
Flame sensor at furance nees to be cleaned. Remove front top cover at furance. Flame sensor is located left of last burner .Remove 1/4inch screw and clean wirh fine steel whole.
Feb 03, 2011 | Honeywell Electronic Programmable...
Header just buzzes when you try to start and the blower will not turn ( reddy heater pro155 155,000bdu).
Remove the top half of the tube so that you can see the blower. Try to turn it by hand to see if it is tight. If it is tight, you may be able to oil it a little and get it to spin easier. Another thing to check would be the compressor attached to the back of the motor. There are 3 screws that hold the filter cover on. Remove the filter cover. Next, 6 screws hold the cover on the compressor. Remove that cover also. Inspect the rotor for damage and make sure the 4 fins in the rotor move freely. With the compressor cover removed try turning the fan to see if it turns easy. Be careful not to let the fins fall out of the rotor. Now put the cover back on the compressor and turn the fan again to see if there is any difference from when the cover was removed. If it doesn't turn freely once the cover is reinstalled then the problem is in the compressor and you need to figure out where it is rubbing. If it is in the motor, you will probably need a new motor.
Dec 24, 2010 | Reddy R155D Utility Heater
Where is the heater core in a gmc van
Welcome to
1. Disconnect the battery cable.
2. Remove coolant recovery tank and lay aside.
3. Place a clean pan under the vehicle and then disconnect the heater core inlet and
outlet hoses at the heater connections. Quickly plug the heater hoses and support
them in a raised position. Allow the coolant in the heater core to drain into the pan
on the floor.
4. Remove heater distributor duct to distributor case attaching screws and distributor
duct to engine cover screw and remove duct.
5. Remove engine housing cover.
6. Remove instrument panel attaching screws: above, at windshield, all lower screws
and tight lower LP. Support bracket at door pillar and engine housing.
7. Lower steering column, and raise and support tight side of LP.
8. Remove defroster duct to distributor case attaching distributor to heater case.
9. Disconnect temperature door cable and fold cable back for access.
10. Remove three (3) nuts at engine compartment side of distributor case and one (1)
screw on passenger side.
11. Remove the heater case and core as an assembly. Tilt the case assembly rearward at
the top while lifting up until the core tubes clear the dash openings.
12. Remove the core retaining strap screws and remove the core.
13. To install a new core. Reverse Steps l-10 above. Be sure core to case and case to
dash panel sealer is intact before assembling unit.
Thank you for using
Regards, Lee Davidian
Nov 06, 2010 | 1984 GMC VanDura
Needto replace heater core in 99 ford taurus,need help
Instructions Things You'll Need:
  • Replacement heater core
  • Clean container
  • Wrench
  • Screwdriver
  • Steering wheel nut
  1. Disconnect the negative battery cable and wait at least one minute for the air bag system to lose power. Make sure the front wheels are straight ahead and lock the steering column.
  2. Detach the air bag module by removing the bolts from underneath both sides of the steering wheel and the electrical connector. Remove the steering wheel bolt and press the wheel away from the steering column. Remove the lower steering column cover.
  3. Insert a 1/8-inch wire or pin punch in the shroud hole under the ignition switch while it's in the "Run" position. Press on the pin and pull on the ignition switch lock cylinder to remove it.
  4. Disassemble and remove the instrument panel from the Taurus' interior. This includes the radio and all panels, electrical connectors, harnesses and screws. You'll need an assistant to help you lift and remove the instrument panel.
  5. Drain the engine coolant from the cooling system, using a clean container for reuse. Remove the heater hoses, actuator and metal cover from the heater. Disengage the spring from the heater core cover and the lever.
  6. Depress the locking ramp and remove the lever from the secondary air temperature control (the lever is brittle, so don't bend it). Remove the primary air conditioning air temperature control door shaft from the pin.
  7. Remove the heater core cover and seal from the heater/air conditioning housing assembly. Remove the heater core from the heater/air conditioning housing by pressing on the core tubes and assembly.
  8. Installation
  9. Install the replacement heater core to the heater/air conditioning housing. Install the core cover, seal, lever, spring, metal cover, actuator and heater hoses.
  10. Replace and assemble the instrument panel with your assistant's help. Connect the steering wheel (use a new bolt to connect it to the column), air bag and negative battery cable.
  11. Refill the cooling system with either the old coolant or new. Start the Taurus' engine and let it reach normal operating temperature. Watch the climate control operation and check for any leaks.
Read more: How to Replace the Heater Core in a Ford Taurus '
Oct 21, 2010 | Ford Taurus Cars & Trucks
How to install a new top and bottom hvac heater hose fitting for a 2002 buick lesabre custom
The hoses are moved by turning them a few degree's, then pulling them off. See diagram below.
Jun 19, 2010 | 2002 Buick LeSabre
Laars Lite 2 Heaters starts up (ignites) and shuts down in 2 secs
usually indicates a flame sensing problem. remove sensor and clean with steel wool .
Jun 23, 2009 | Lite On Laars Lite 2 Heaters: 250,000BTU...
1994 buick lesabre heater core removal
The heater core is located under the dash, in the center. The container holding the core looks like a black plastic box. Remove the ash tray for easier access. You may have to also remove some other covers under the dash. You must first drain the radiator then you have to disconnect the hoses. There are two hoses connected to nipples of the heater core that go thru the center of the firewall. Remove the screws that hold on the cover to the heater core. Then you should be able to get the old one out. There might be a couple of other minor steps but I'm sure you can figure them out. For re-installation just go in reverse order to put it all back together.
May 25, 2009 | 1994 Buick LeSabre
  1. Drain the cooling system to a level below the heater core.
Disconnect the coolant hoses at the heater core tubes.
  1. Remove the glove compartment.
  2. Disconnect the temperature and function cables.
  3. From inside the passenger's compartment, remove the 7 screws that secure the heater core access cover to the plenum chamber. Remove the cover.
  4. Remove the heater core.
  5. Installation is the reverse of removal. Replace any damaged sealer. ... and if your having a problem tiring to get the heater core itself you have to wiggle it till it clears ..they can be a real pain to get out.
Dec 07, 2008 | Ford F-150 Cars & Trucks
Williams 3003622 Ceramic Wall Mounted Panel Heater Logo
131 people viewed this question
Top Williams Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
vance jones
Are you a Williams Heating and Cooling Expert? Answer questions, earn points and help others
