Question about Dishwashers
Whirlpool quietpartner I Dishwasher wont clean anymore.
Ive only had the dishwasher for a couple of years. Every time I wash a load of dishes The bottom dishes are somewhat clean and the top dishes arent clean at all and the detergent still in the despenser even with the door open. Can anyone help me?
  • 332 Answers
You need to take the blades that spin out and clean them off they have grime on them, is there water still in the bottom of the dishwasher when done> if so there is a plastic grate in the bottom rear of the dishwasher you need a 1/4 inch nut driver take the cover off and clean the debris out, there is a small stainless steele cutting blade in there be careful, it is to cut up foods that might not be washed off before putting dishes in the washer, also it is pressure that makes the detergent door open make sure you are getting full pressure comming into the waher, if non of this works the pump should be replace or it;s new dishwasher time
Posted on May 30, 2009
Correct cycle. Get to wash dishes.
Whirlpool Dishwasher Repair Online Manual
www.appliancerepair.net/whirlpool-dishwasher-repair.htmlFREE ONLINE Whirlpool dishwasher repair manual - Diagnose your problem ... Noneed to call an expensive serviceman, and then wait a couple of hours (or ... Common complaints are covered, such as wash quality problems (spotting,
Jul 19, 2015 | Whirlpool Dishwashers
My whirlpool dishwasher is locked and it wont unlock
Need model number to give you more info. If it has a child lock on it hold same for 3 seconds to unlock. You may have a broke handle also.
Dec 01, 2013 | Whirlpool Duet GHW9150P Front Load Washer
Hello ! We have a Whirlpool "Quiet Wash Plus" dishwasher that is approx 12yrs old. It has performed exceptional over this time, but notice recently it does not get the dishes as clean as before....
Is the water level ok? Check your water temp into the tub. It needs to be a minimum 120 degrees. Check for plugged spray arms. Do they turn freely? Does dishwasher drain completely?
Sep 25, 2011 | Whirlpool GU2400XTP Built-in Dishwasher
Suddenly not getting dishes clean. Also drawers squeek when opening and closing
If your dishes arnt getting cleaned anymore most likley your sump motor assy needs to be replaced and the squeaking is prolly the door cables. Ive enclosed the part numbers you would need. Whirlpool has a 5 year warrenty on the sump motor. So maby whirlpool could send it to you and you would just have to get someone to install it. Save yourself some money. I hope this helped you any questions feel free to ask.
http://www.repairclinic.com/SSPartDetail.aspx?s=t-gu2455xts-%3d%3di1548391&PartID=1548391
Good Luck
Phillytech
A.S.A.P. APPLIANCE REPAIRS LLC
Aug 22, 2010 | Whirlpool GU2455XTS Built-in Dishwasher
Does not get dishes etc. clean no matter how loaded. Must pre-wash by hand to get all food off or will not come out clean. Why have a dish washer? Is there any secret to how to get it to clean? Or do we...
This is a good washing machine if it is working properly. There could be a couple things that have happened to make this not work well. You should not have to pre-wash or rinse anything, just scrape and load.
First thing is look below the bottom rack, there is a ring that looks kinda like a horseshoe. This is the heat element. If it is dark in color you are okay, if it is white then it may be coated in hard water deposits, if this is the case that means the inside of the pump and wash arms are plugged up too. If so all you need to do is clean it out using a dishwasher cleaner. Here are some good ones that you can find at the store near the detergents, follow the directions on the label. Lemi Shine, Rinse aid dishwasher cleaner, finish dishwasher cleaner, Glisten. Here is a link to a few more details on that.
http://www.fixya.com/support/r4666624-hard_water_calcium_white_powder_build_up
The second thing and most common is a plugged sump, debris can restrict the water flow to the pump. I have put together some instructions on cleaning this out. Follow the link below and let me know if this helps.
http://www.fixya.com/support/r4628450-poor_cleaning_or_noisy_pump_whirlpool_or
May 19, 2010 | Whirlpool GU2400XTP Built-in Dishwasher
I have a Whirlpool GU2600XTPS7 dishwasher - long washing time
You could have a couple things going on here. It could be either related to water temperature, build up in the sensor area or poor washing.
If the dishes are coming clean then you can discount the poor washing.
1st thing to try is clean out the dishwasher, a build up or residue can form on the sensors in the bottom and they can be fooled into thinking the water is cloudier or cooler than normal and it would take longer to heat the water and wash. Here is a link to some instructions I put together on how to clean it out.
Clean Out Procedures
2nd thing to try would be to run the hot water in the kitchen sink until it is hot before you start the dishwasher. By doing this the dishwasher will not have to slow down and pause while it is heating the water enough to clean the dishes
May 01, 2010 | Dishwashers
I have the Whirlpool Quiet Partner 1 the wash cycle starts and about 20 Min.'s into it the clean light starts flashing or the the start light, one or the other each time and it wont dry the dish's anymore...
If the clean light blinks 7 times thats you heating circuit. Test the heater with an ohm meeting to see if it has open. If so order the heater kit and it comes with the control board.
Jan 12, 2010 | Whirlpool GU2400XTP Built-in Dishwasher
Dishwasher doesn't clean the top rack whwn we riun it.
sounds like the jets are cloged you can try a small wire to try and unglog the jets that or you water does not have enoph pressuer hope this helps
Feb 12, 2009 | Whirlpool GU2400XTP Built-in Dishwasher
Whirlpool gold quiet partner IV
You probably need to clean the filter; here is a site to show you how to do it: http://01tutorials.com/video/1686251/how-to-clean-the-filter-on-a-whirlpool-gold-quiet-partner-iv-dishwasher/4107
Sep 20, 2017 | Whirlpool Gold 24 in. Built-In Dishwasher...
Whirlpool dishwasher quietpartner 2-soap residue
check that the sump screens are clear in the tank,also check that the wash arm holes arent obstructed.
Dec 30, 2007 | Dishwashers
Dishwashers Logo
248 people viewed this question
Top Dishwashers Experts
