Question about LG WM-12230FB Front Load Washer
Washing machine has given up
When you turn it on it starts to fill and drain at the same time, even if you put the program in it still dose this, although the drum dose spin normaly, it drains and fills through out the program, well untill the point i got annoyed turned it off and took the top off, nothing seems broken inside all the wires look like they are in all the pipes are connected. do you have any idea what i could do to fix it, if you dont i will chuck it out and get a new one. thankyou very much if you can help me.
  • 332 Answers
The circuit board is shorting out need to replace the circuit board
Posted on May 30, 2009
Does my washer need its own circuit it is a120v 60hz 10amp hotpoint, it's brand new
Yes, it should have a 20 amp circuit. But I don't know if that will correct your problem..
Dec 19, 2016 | Hotpoint Washing Machines
My nanussi washing machine won't fill with water, when i put in onto a cycle it sounds like water is filling then it clicks off 1min later. Drier seems to working fine.
HI lisa
Have you moved your machine recently ? It sounds like it could be the drain outlet hose that is too low and the water is syphoning away If your machine dose not fill within a preset time it will stop. Is there any error codes or flashing lights.If water is going into the machine and the tub is not filling check that the end of the drain outlet hose is no lower than the centre of the door.
May 25, 2016 | Washing Machines
Exactly the Same Problem
It's difficult to say without seeing the machine or having a failure code.
The machine looks for a switch to close as it fills with water. Maybe a pressure switch?
You could find the switch and see if it clicks when blowing into it and even test it with a meter.
That's an easy test.
Maybe the module has failed.
Hope it's given you something to look for.
regards
john
Aug 28, 2009 | Zanussi ZWD12270 Front Load Washer / Dryer
Tub smells like mildew. Possible water still in tub but not visable. When tub is shaken hard by hand, slight sound of water sometimes. Still cleans well.
You will never get all of the water out of a washing machine using the pump
The only way to do it is to take the drain hose out of the standpipe remove all clips so that it lays flat on the floor and put it into a bucket
Even then there will still be a little bit left in.
Run two very hot programs witha good dose of washing soda placed in the drum before you fill it
Leave the door open when the machine has finished to allow it to dry off
Jul 09, 2009 | Whirlpool Washing Machines
The washer doesn't always fill up when we turn it on
Hi, Dose the water fill the first time you start it but, then will not fill in the rinse cycle? Does the water continually try to fill but never gets to the top?
I want to help.
Thanks
Vic
May 12, 2009 | Maytag Ensignia 3.3 cu. ft. Top Load...
When we start the washer dose not keep the water insid going out right away in the same time befor the wash
basic engineering princaples water will take the easiest path, if your drain is lower than the washing machine fill level it will run through the machine to the drain. raise the drain pipe to above the top level of the drum that should do it. otherwise you have a faulty wiring and your drain pump is on all the time.
Nov 12, 2008 | GE Washing Machines
Kenmore stack washer and dryer
gabehart....sounds like belt is slipping. Replace it. The water pump is on a separate smaller motor so is not affected by the agitator/spin motor.
Jun 04, 2008 | Kenmore 98702 Stacked Washer/Dryer
LG WM-12230FB Front Load Washer Logo
69 people viewed this question
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
