Roper RES7646KQ Electric Dryer Logo
Posted on Oct 22, 2007
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Re: no heat and timer not moving
Hi - Our Roper dryer was working fine until last week.
The barrel turns and there is air moving, but no heat and the timer doesn't
move.  I'm wondering if this could be a fuse, thermostat or ??
Any help would be appreciated.
Thank you in advance, Amy
  • 6 more comments
  • Anonymous Nov 05, 2007
    I have the same thing happening right now.
    Will try to check the fuses as well. I'll post up what I find out.
    Thanks Amigaman
  • Anonymous Jan 08, 2008
    same problem
  • lvang209 Jan 22, 2008
    I am having the same problem. My dryer will start but does not heat up. Its a pretty new model, 2 years old. I have reset all the breakers on the fuse panel outside of my house, but it doesnt help. Any ideaS?
  • bobweiss Mar 01, 2008
    the dryer is is spinning but no heat or timer
  • susiebou May 19, 2008
    We are having the same problem. We ordered a new timer and had it shipped overnight and it still does not work. Please Help
  • austdry Jun 03, 2008
    spins, blows air, no heat
  • chevelle72_5 Apr 04, 2009
    I have the same problem, it is a gas dryer and the way you state your answer that it sounds like you are talking about an electric unit. I will check my thermal fuses and such though thanks. I have a gas dryer model number rgx4635eq1 worked great till last this week then timer stopped working and so did the heat. Ran all night
  • Anonymous Mar 23, 2014
    Dryer turns, but no heat and timer does not move
Gerald Griffin
Level 2:
  • Expert 248 Answers
  • Posted on Oct 23, 2007
Gerald Griffin
Expert
Level 2:
Answers
248
Questions
0
Helped
148402
Points
570
  If the timer is set for a auto dry cycle,  the timer won't advance if not heating.  You need to check for 220 volts at outlet.  It's possible to have only 1 110 volt circuit.  May be a bad breaker. or outlet.  If you have 220 volts at outlet,  you need to have an ohm meter to check continuity of the thermal fuses and the heater.   Access by removing rear panel.  UNPLUG FIRST!!!!!
Roper gas dryer does not heat, timer does not move, runs continuously, can the timer malfunction cause dryer not to heat?
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check out this electric no heat tip...
heatman101
5helpful
I have a Roper Dryer Model #REX3514PQ0 and it's about 5 or six years old. I was drying my laundry. The first load dryed fine. One the second load I notice that the setting nob up top was not moving and...
What I would do is pull the dryer out and unplug the power cord. I would remove the rear cover and check the components back there for continuity.f08dda1.jpg83a4f65.jpg15ccca9.jpgIf all of that is good then the timer or breaker might be bad. Why? The timer calls for heat through the RH leg. The amp draw from the heating element arcs up the contact point inside the timer. The motor runs on 120 volts the heater runs on 240 volts. So the breaker will take a beating on the heater side of it. The dryer will hower still run. To recap It could be the heater the limits the time or an electrical problem.6db32c2.jpga2de035.jpg
Rate it or Hate it:
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
My roper gas dryer doesn't heat and the timer dial does not advance. I recently cleaned out the interior ductwork, it worked fine for a week, and then it seemed like the timer started becoming less and ...
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
heatman101
1helpful
Won't run
ensure your door switch is working then move into timer.
3helpful
Dryer Timer dial will not move but dryer works
Will the dryer move forward in timed dry? if it does not then you need a new timer. If if will advance in timed dry but does not advance in auto mode then the high limit needs to be replaced on the heater.
4helpful
2answers
Roper Electric Dryer Heats but drum won't spin
Yank the filter out the top. Remove the 2 screws in the filter housing. Use a putty knife to pop the top and then remove the screws holding the front on. NOTE: raise up on the front panel slightly so you won't damage the bottom clips. Get the front out yer way and remove the drum. Clean out the dryer and oil the rollers and idler. Use this handy ROUTING GUIDE to see how to put the belt back.
Top Roper Dryers Experts
ZJ Limited
ZJ Limited
Mike Cairns
Mike Cairns
CJ Rock
CJ Rock
Are you a Roper Dryer Expert? Answer questions, earn points and help others
