Question about Philips Televison & Video
Philips 27T500 C101 standard set won't respond
Philips 27T500 C101 standard set is unresponsive to remote and front power button. It keep s displaying the sales screen with all the features of the tv. How do I reset it?
  • garymillward May 30, 2009
    Yes.  I unplugged and then re plugged twice.
    I figured it out myself.  Press both volume buttons at the same time.
    Can I close this request now without being charged?
    Gary
  • 489 Answers
You pluged everything. ?
Posted on May 30, 2009
  • meteshadow May 30, 2009
    i really dont know. ask the boos you know :) i know that they are refunding but i dont know how.
    i hope you solved your problem.
Philips model ms2671 c101 tv no power.
Check and replace damaged component/s at its main power regulator [SMPS] section circuit. Contact any service technician. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts.
Sep 17, 2014 | Televison & Video
I have a philips SRU3003WM universal remote im trying tn program to work on a magnavox tv model TR2510 C101 but cant find the codes to do so
The codes for Magnavox are 0807, 0002, 0502, 0919, 1914, 0224, 0430, 0247, 0402, 0408, 0109, 0715. Enter the code in the Setup and then check if the remote does any feature other than on/off.
You can search through all the codes as well. Turn on the TV. Press and hold the Setup button until the light remains lit. Press the TV button. Press Channel Up repeatedly (up to 300 times) until the channel changes on the TV. (If you miss this, press Channel Down to backtrack). Press the Mute button to set the code. Check if the TV responds to other functions of the remote. Continue the search as above if it doesn't work for all desired functions.
However if your TV was released less than 6 months before the remote was programmed or is newer than the remote, the code you need may not be in the programming.
I hope this helps.
Oct 03, 2010 | Philips Magnavox 27MS343S 27" TV
Philips TV model 34PW9815/17 the LED on the front of the unit turns green when first plugged into electrical outlet, and then immediately starts to flash red. nothing on the unit works and it doesnt...
Philips TV model 34PW9815 the LED on the front of the unit turns green when first plugged into electrical outlet, and then immediately starts to flash red. nothing on the unit works and it doesnt respond to controls either on the set or the remote
May 12, 2010 | Philips 32PT81S 32" TV
The menu keeps coming up every few seconds and changing options on it's own. Like someone is using the remote, but the actual remote is unresponsive.
The problem is most likely a short in the switch panel on the front of the TV. The remote won't work because the TV thinks that you are using the manual buttons on the front, and the manual buttons override the remote. Have the front button panel replaced....it's under $200.00 - or you could solder the switches apart and just use the remote.
Nov 01, 2009 | Toshiba 36A43 36" TV
TV not working
Looks like a cpacitor blew and your smelling the burn liquid from it that would smell like wire all you have to do in theis case is indentify witch one and replace it.
Jul 18, 2009 | Televison & Video
Power button changes channels and volume does not work
bad solder connections. front control panel.
Nov 23, 2008 | Philips 27PT543S 27" TV
Philips TV stuck on the blue language selection screen.
unplug the TV from the wall outlet for two minutes, then try again
Nov 04, 2008 | Philips 32PT5441/37 32" TV
OLDER 32" TV WON'T TURN ON/KEEPS TURNING OFF
re solder your tv,if its not works, check the horizontal output transistor
Oct 01, 2008 | Samsung DLP HL-P5663W 56" TV
TV not reponding to remote
Remote IR LED receiver defective located on front edge of PC board.......I will get the part # for you........................T.
Feb 27, 2008 | Televison & Video
Televison & Video Logo
259 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
