Question about Toshiba 35A44 35" TV
Power will only come on with plug into wall- no picture, no buttons working
Soniq E23213a au 12v and 240v works for 20mins then screen goes green stripes and stops
Unplug your TV hold the power button down on the TV itself for one minutes release the power button plug it back in and turn it on yeah power build up and not yet overpowering of the power supplies you probably have it on power bar not plugged directly into the wall post TV to be plugged directly into the wall the wise Yup Yup mismatched power
Jan 07, 2018 | Car Audio & Video
Just updated my Sony tv and it says unfortunately, program guide has stopped. What can I do. I tried to restart the tv with the power button and it didn't work.
Pull the wall plug and count to 10 and plug it back in. The program guide actually comes from your cable supplier or satellite dish provider or your TV over telephone internet supplier, so chop the power to that box as well. That forces the operating systems to load and reset.
The power button merely puts the set into standby, basically, just turns off the picture. You need a full disconnect.
Dec 18, 2016 | Televison & Video
E3 error on LIfesmart heater
Even after replacing thermostat and motherboard offered from company, my heater would trigger e3 error code and shut off. After several (maybe 100!) different attempts to plug in and operate, here is what worked for me!
Depress the power button on the heater while plugging in to wall circuit. Continuously depress power button. It will run through a test cycle and attempt to start. Keep depressing the power button as the heater tries to start, then shuts down with e3 error. While the power button is still depressed, unplug the unit from the wall. When I plug back in the wall the E3 error is gone. Good luck
Nov 03, 2012 | Lifesmart DYNAMIC 1000 to 1100 Square Foot...
I am getting sound from the DVD but no picture. I
I've fought with this for a while and finally figured it out. I recall another piece of hardware that would perform some sort of auto reset when it was unplugged so I tried it and it worked! I don't mean just hitting the power button, I mean crawling down on your hands and knees to follow the power cord from the back of the dvd player to the wall/power strip. Unplug it, wait a few seconds and plug it back in. BAM! All fixed.
-Kevin
J-ville
Dec 27, 2010 | Sony DVP-NC85H Multi-disc DVD Player
LCD TV is hooked thru cable box. When you use the
Try this (may not work):
1. UNPLUG power from TV at wall outlet.
2. Turn ON the TV (with no power cable plugged in).
3. Plug power cable back in (at wall outlet)
4. Turn ON TV (don't use remote this time).
Hope this works!
Sep 03, 2009 | Televison & Video
Unplugged unit
when it is powered off hold the power button on the console for about 15 seconds, that resets the video settings.
Aug 01, 2009 | Sony Playstation 3 (PS3) Console
Last night I turned-off my PC througg Windows and when I pushed the power button this morning nothing hapened. There is no sign of "life" from the PC.
Check the power source to the computer (both ends of the cord), if a surge protector is in line with the power , remove it and plug the computer straight into the wall. also check the wall plug with a lamp or something to ensure power there. make sure the switch on the power supply hasnt been changed to the 220v side.
If no power at the wall- check your breaker box in the house
If it works plugged straight into the wall- check the surge protector
If power at the wall and plugged straight into the computer (no surge protector) and nothing lights up when you turn it on- have your power supply checked.
Oct 08, 2008 | Acer Computers & Internet
Power button is green - no blinks / no picture / no sound
Unplug it from the wall, wait 2 minutes and plug it back in. if problem still exists, its probably the main pcb.
Jun 19, 2008 | Dynex 32 in. LCD Flat-Panel HDTV
Toshiba 35A44 35" TV Logo
15 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Steve Allison
Steve Allison
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
