Kitchenaid superba regrigerator user's manual
SOURCE: Water Filter Kitchenaid Superba...Where is it??
look for a round peice on the kickpanel at the bottom of the unit it twists and slides out
SOURCE: kitchenaid superba icemaker leaking/freezing in freezer section
Thank you, I am going to go check right now
SOURCE: Kitchenaid Icemaker leaking in big drips on front of freezer bins
Either the inlet valve is stuck or the icemaker solenoid is shored.
Most likely the second one.
Enter the model number on one of two websites below to get parts and diagrams for your appliance:
Appliance Parts From PartSelect
Appliance Parts Pros
SOURCE: how do you take out and change the water filter on
At the bottom of refrig , on the toe plate , press the button on the left kinda hard , and the filter should pop out .
Testimonial: "thanks for the help. "
SOURCE: How do you replace the water filter on a
under the freezer door there is a nob like thing. turn it and pull on it. instead of replacing it, rinse it out under runing tap water and put it back were you removed it from and push the fridge light botton 5X in a row
