Question about Refrigerators
I had my fridge fixed,the drfroster heater went bad,now the ice maker wont turn on,it doesnt show the green led light,that the unit is on.Also,the freezer light lost power,the buld is good..any ideas??
    Novelist:
  • 166 Answers
Actually, when main power is supplied to whole fridge it is accordingly distributed to each & every component in accordance of its power needs.
But while distributing using relay switches the power supply needs special controlling from the CHIP's program.
So, just replace these relays & cross-check internal wirings also.
Thats all you can do at your level.
I hope you will get rid of your problem soon.
Rate this solution if it was helpful to you.
With Regards,
Shyny
Posted on May 30, 2009
I have GE Monogram Side by Side. Purchased back in August 2006. It has been pretty good except for the ice maker. After the first year a leak ruined our new wood floors. Recently the ice maker has...
The green light flashing is a fault code, usually for a no, or long fill situation, GE has nixed this electronic ice maker and returned to one that looks similar but is non electronic, while your ice maker is probably at fault you may actually have a separate issue causing the ice maker to display a fault code, such as a spent water filter, or low water pressure, or even a bad water valve on the fridge it's self. IM6 is the current replacement ice maker kit for previous ice makers. Pleazer Appliance...
Apr 17, 2014 | GE Monogram Side by Side Refrigerator
F-330bah-c stopped making ice & unit is 1 month old
it should be under warranty . is the water shut off to fridge . ice maker could be bad . make sure water to the ice maker is on just check your water line . a very easy common mistake and very easy fix if the water is not turned on to the ice maker it wont make ice . hope this helps let me know how it gos
Nov 02, 2013 | Hoshizaki Freezers
Underneath the freezer drawer builds up with ice (have to chip it off a (makes opening the freezer difficult) and sometimes when I open one of the fridge doors (does not matter which door) water pools...
it seem that you have a clogged freezer drain. you can fix this by first turn off the unit leve all door and let it thaw about 4 to 6 hours or longer. if this doesnt cure the problem then repeat above procedure but this time open the plastic cover on the freezer and clean out the drain make sure all drain are unclogged also while your at it check the operation of the drain heater pan underneath the unit. and lso check the operation of the defrost timer. hope it help you.
Sep 18, 2009 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
My clr 2060 ice maker is not doing anything,their is no ice in the storage bin. opened up ice maker and cleaned the condenser coils. Found red light on board lit, with a slow steady blinking green light
HI
It sounds like you have a drain issue. You can do a test with the unit on open the panel with the board and remove the 2 pink leads and make a jumper for those terminals. If the unit comes on 3 min fill then circulating pump and compressor and fan come on then you know you either have a kink in the drain line or a bad pump. If your unit doesnt have a drain pump then the pink lines could be open and it will turn the unit off too.
Sep 13, 2009 | U-Line Icemaker
Kenmore bottom freezer died, fridge not cold either
Please keep in mind, I'm attempting to diagnose the problem without being there and with little information.
You are most likely going to have one of five problems.
  1. Condenser fan not turning (Fan under unit)
  2. Defrost problem (Heaters bad)
  3. Coils under unit dirty
  4. Defrost timer bad
  5. Bad compressor (Vary unlikely)
These are listed in order as to be the most likely to be the problem. I would check them in this order if I were called out on a service call with this problem.
. Respond back if you need me to walk you through checking any if these.
Please rate solution
Sep 10, 2009 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
I have a PSS26 ge profile fridge and it quit making ice
The icemaker is bad . You have an electronic icemaker and the internal boards cannot take the freezing and the heat (freezing moisture) . Just replace the icemaker .
Jul 28, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
GLHS38EE Ice maker over flows Fridge runs and wont shut off.
Refrigerator does shut off. The icemaker was calling for cold temp. It is removed. I am waiting on a NEW Icemaker. The heater in the tray was bad. Easy fix. THANX!!
Jun 21, 2009 | Frigidaire GLHS38EE Side by Side...
Water Filter Red Light
Press and hold "ICE MAKER LOCK" button, and while holding it shortly press "LOCK" button, and the light will change to green LED.
Jan 12, 2009 | Jenn-Air JCD2290HES Side by Side...
Whirlpool Gs5shaxnb02 Ice maker
is there water in the ice trays?if not try pushing the test button normally underneath the unit. possibly it will initiate a reset and start working. sometimes a limit is not activated when it should be.
Aug 07, 2008 | Whirlpool GS6NBEXR Side by Side...
Daewoo refrigerator water filter red light still on after replacing the filter
Ivan
Oct 08, 2007 | Refrigerators
Refrigerators Logo
Top Refrigerators Experts
John Tripp
John Tripp
Brian Coughlan
