Question about Dryers
Kenmore electric dryer stopped heating.
Model # 110.61082000. Drum turns. All cycle lights are normal. Electricty is normal.
  • 332 Answers
Are you saying it stopped what> drying, running what,, if it's not drying it will probobly be the heating element or the thermal circuit in the line
Posted on May 30, 2009
Model wm7355s. Drum doesn't turn. Why doesn't it run through a cycle?
first part of cycle normally starts pump.if that fails it wont continue.check for blockage
Feb 04, 2016 | Beko Washing Machines
Samsung ecobubble 7kg red drum flashes at end of cycle? Is it broken?
We have later model and have same flashing drum symbol. You need to perform an ECO DRUM CLEAN cycle.
1. Press power to turn on machine.
2. Turn cycle selector to ECO DRUM CLEAN mode
3. Press Start/pause
Mar 01, 2015 | Samsung Washing Machines
Not clear
well then replace the drum cleaning blade and the developer and while they are being replaced clean the entire drum cartridge DO NOT USE A VACUUM CLEAR can destroy the sensors with static electricty
Feb 23, 2014 | Konica Minolta Minolta 7022 Laser Printer...
Water keeps filling up the drum and inlet light flashes
either the inlet water valve is bad and needs to be replaced or the controller for it is not cutting off the electricty to it, If you are going to replace something, replace the water inlet solenoid valve.
Feb 10, 2014 | Miele Washing Machines
Bosch maxx drum not turning during any cycle
What is the model number of your unit?
Nov 18, 2012 | Bosch Washing Machines
Washing machine works but occasionally makes noise occasionally at end of cycle, when spinning etc. I suspect a missing sock may have found it's way through the gap and is in the drum housing, out...
Clothing cannot get into the drum housing. Noises which occur during the spin cycle suggest that the drum is being thrown of balance during the spin cycle. A possible cause of this is that the bracket which holds the drum to the spindle is partially broken. This bracket consists of 3 or 4 arms and eventually one or more arms will crack and break (this is a result of the interaction between the steel drum, aluminium bracket and electricty, which weakens aluminium over a period of time). If the machine is not examined and repaired, then the drum noise will get worse and the drum will start to knock & rub against other parts, especially the water heating element and this will result in a more costly repair.
May 19, 2011 | Washing Machines
Machine will not final spin
I was given wrong info. the machine did go through the cycle and drain. However, the drum DID NOT revolve at all. Main motor Brushes replaced. Now OK. Thanks.
Feb 15, 2010 | Hotpoint Washing Machines
Model PYE2300 AYW the dryer turns on and provides heat but the drum does not spin
your belt has come off the drum or has broken. Take the model and serial number to parts house for replacement. The belt should be accessed through the back of the dryer. Good Luck on your repair. Make sure to disconnect electricty before removal of back.
Dave
Aug 05, 2009 | Maytag PYE2300AY Electric Dryer
Maytag neptune MLG2000AWW does not turn off at end of spin cycle
d sounds as if your having a timer issue here. not recognizing the end of cycle and entering a new one ( bad timer).. as far as time of unlocking this is normal, theres a wax motor holding the door shut for i believe 3 min's.. and the water sloshing sounds is also normal they use a "water filled" balance ring around the perimeter of tub to help with the overall balance of machine
Mar 20, 2009 | Maytag Neptune MAH5500B Front Load Washer
Dryers Logo
79 people viewed this question
Top Dryers Experts
