Question about Hyundai Electronics Hyundai Elantra 2004 Stereo/radio Wire/wiring Harness
Hyundai shift lock
Wont shift out of park. shift lock override engaged w/pen-works ok. w/out it wont budge. how do i locate solenoid fuse? could that be the problem?
2005 Hyundai accent gear shift stuck in park after brake failure
Make sure the brake lights are coming on if not the release solenoid that unlocks park gets no power and will not release the shifter from park position. Also check the owner's manual for a possible way to override the solenoid lock.
Jun 24, 2016 | 2005 Hyundai Accent
Where is location the automatic transmission shift lock relay in my s10 1998 2.2 2wd
Automatic Transmission Shift Lock Control Description
The brake transmission shift interlock (BTSI) system prevents the automatic transmission from being shifted out of PARK unless the brake pedal is depressed. When the brake pedal is depressed, the BTSI solenoid releases a lock pawl. This enables the shift linkage to move and the shift lever to operate.
When service operations are required, the BTSI system can be overridden.
On vehicles equipped with a column-mounted shift lever, override the BTSI system by performing the following steps:
  1. Turn the ignition switch to the OFF position.
  2. Remove battery voltage from the solenoid.
  3. Turn the ignition switch to the ON position.
For vehicles equipped with floor-mounted shift levers, an override lever is mounted on the right side of the assembly. The override lever can be accessed by removing the shift lever boot. Push the lever to the left in order to override the BTSI.
Which does your S-10 have column or floor shift ? No relay ,has a solenoid .
With Column Shift A/T
The brake transmission shift interlock (BTSI) system prevents the automatic transmission from being shifted out of the PARK position unless the following conditions are present:
The brake pedal is depressed.
The ignition switch is turned to the RUN or the START position.
When the ignition switch is in the RUN or the START position, the current flows from the B/U Lamp fuse located in the underhood bussed electrical center (UBEC) through CKT 839 (PNK) to the park/neutral position switch. The park/neutral position switch also feeds the backup lamps portion of the switch. With the transmission in the PARK position, the current flows to the BTSI fuse located in the underhood bussed electrical center (UBEC) through CKT 275 (LT GRN). The current then flows to the TCC/stoplamp switch through CKT 584 (LT GRN/BLK). The current continues to the BTSI solenoid through CKT 1135 (DK GRN/WHT). The ground path is provided through CKT 1850 (BLK) to G207. When the brake pedal is depressed, the normally closed contacts in the TCC/stoplamp switch open and the current flow is interrupted. When the current flow is interrupted, the BTSI solenoid de-energizes. The transmission may then shift to another gear. When the transmission shifts to another gear (except PARK), the contacts in the park/neutral position switch open. This condition stops the current flow to energize the solenoid when the brake pedal releases.
Whic
Jun 09, 2016 | 1998 Chevrolet S-10 Pickup
97 mazda 626 wont shift from park. release button on side of shifter wont push in. removed knob, plastic rod in center wont move
The 1st thing you need to do is check the brake lights, if they are not wiorking the park lock solenoid doesn't get power and the park lock remains engaged.
Apr 17, 2012 | 1997 Mazda 626
Sometimes I can't get the trnsmission out of park. The button to select will not engage
I found that if you take a pencil and poke down in the Shift Lock Override hole located on the shifter console, you should feel slight spring pressure, gently push down until it bottoms out, while holding it down shift the shifter out of park. This is not the fix,but it could allow you to use your car until it can be properly repaired.The actual problem is the shifter lock mechanism is not working properly.
Feb 14, 2012 | 2000 Hyundai Elantra
My gear shift is stuck in park. The car starts up fine, but shifter wont budge.
the fuse is bad for shift lock solenoid. Read owner manual section on brak-shift interlock. Check fuse for nbrake lights. Brake lights work.
Owner manual has emergency by pass procedure. I think you turn key to OFF and then shift to neutral and start car then. Next time in park, you have to repeat.
Oct 29, 2011 | 2005 Lincoln Aviator
My 2006 dodge charger will not shift out of park. i tried the pink override switch, it still wont shift out of park.
This would indicate a failure with the " shift lock " solenoid. Ya, I bet you figured that out on your own already! The odd thing here of course, is that the " over ride " button doesn't work either. Is there any chance that there could have been something spilled in the console recently, any work performed in that area? Any items such as; coins, pen, small appliances dropped into that area recently?
Aug 21, 2010 | 2006 Dodge Charger
My 2005 hyundai accent wont shift out of park unless i use the shift lock override. any advice?
on most cars when u step on the brake pedal youll hear a "click" near the center console which is the shift solenoid releasing the "lock" on the floor shifter allowing the shifter to come out of park.check to make sure all the fuses are good and check the brake lite switch(es) and wiringfrom brake lite switch to shifter solenoid.a wiring diagram always helps.
Aug 28, 2009 | 2005 Hyundai Accent
Hyundai Accent (97, auto) wont shift out of Park, unless I use the shift lock override. How do I fix this?
ur solenoid is bad u can replace it which is kinda expensive or u can take ur center consil out and remove the peg that unlocks ur shifter the only thing ur lock override does is manually pulls it out. i just jammed a golf tee in it to keep it open and it seemed to work just fine
Mar 16, 2009 | Hyundai Accent Cars & Trucks
Car wont shift out of park and blower motor quit.
Fuse #23 controls the turn signals, heater blower, reverse lamps, and the shift lever solenoid. There is a hole in the right side of the console where you can poke around with a ball point pen and unlock the shift lever. The fuse is located in a panel behind the glove box. I took my car to a dealer and had them change the fuse, but the ball point pen trick will save you a tow job.
Dec 26, 2008 | 1998 Ford Contour
2001 Ford Focus shift button stuck in park
it's under a dime size cover on your console near the shifter. But, your brake/shift interlock solenoid is not working. either a fuse or the solenoid is bad. see owner manual for lcoation of over ride.
Dec 08, 2008 | 2002 Ford SVT Focus
Hyundai Electronics Hyundai Elantra 2004 Stereo/radio Wire/wiring Harness Logo
490 people viewed this question
Top Hyundai Electronics Car Audio & Video Experts
xxxxxx xxx
Are you a Hyundai Electronics Car Audio and Video Expert? Answer questions, earn points and help others
