Our Samsung digital TV has within the past three days, began a clicking noise when initially turned on for the day. After turning it off and on a few times with the cable system romote, it eventually comes on. Can you help?
  • b_rounsavell May 30, 2009
    I need more specific info. if available. Are you sure this is a TV issue and not with hte cable devices?
    Yes, the explanation was satisfactory.
    Novelist:
  • 151 Answers
Yes very sure this issue with the tv definately.its the exact problem in the main board of tv.its not at all a major fault or issue.but if not resolved can become very major problem.as whole  main board gets faulty if the problem avoided. now i will explain the problem: its the problem of any capacitor getting short due to moisture or humidity issue. what exactly happens is any of the capacitor on the main board gets weak and whenever the tv is turned on the currents passes through all the componets,also passes from that weak capacitor that is weak.but in that weak capacitor when the current passes it clicks and a minute spark comes on the part. at present its a minor problem.but later the noise of spark will become more louder and that 1 weak capacitor will make many other capacitors and ic weak.so on the main board there are hundreds of this tiny capacitors .it cannot be said exactly which capacitor is weak and sparking.but this is usually checked by openong the back of the tv and then turning the tv on 3--- 4 times .and while that look at the main board of the tv which is easily seen when the back of the tv is kept open.you will see the spark at that pareticular component which is faulty.just note the number of the capacitor mentioned on itys body.get the same component from local electronics hard ware shop. if you are not familiar with it.getting it done with a local tv repair technician is also advisable as this will not cost much for getting it repaired as the new capacitor willnot cost more then $5 for per capacitor. this will help you. thanks.please do rate the solution.thank you for using fixya.keep updated.
Posted on May 30, 2009
  • 489 Answers
It is about with power part. something is wrong with power and it saves yourself and shut down. it looks like need to get service
  • meteshadow May 30, 2009
    this is not aobut with cable. because you told it turned off. if it was wire issue system doesnt shut down itself only stands by
    anyway. you are saying clicking noise which one i understand comes from electronic card in between inverters and power section. it is the important things something wrong with the power.
    again. need to get service because it can hurt all electronic system.
Samsung UN46D7000 tv still isn't turning on. I've already replaced the power board (I think the original was fried in a power surge).There's no standby light either.
Fault at its main digital board. Short circuited component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Pull up older posts. http://electronicshelponline.blogspot.com/ In most cases, the main board might have to be replaced. If so, a software [firmware] update too might be necessary.
Jan 06, 2017 | Samsung UN46D7000LF 3D TV
Green LIght Blinking
Does the led ever stop blinking? No ..well in that case generally this indicates a standby voltage problem...if all those voltages ok then the cuircit known as digital module is at fault. also make sure the lockout has not been activiated. i really dont think it could but to unlock hold menu button down for 10 seconds. After all that i believe it would be a bad digital module
Willie@fordtv.com
Jan 08, 2008 | Mitsubishi WS-55813 55" Rear Projection...
I have a Samsung Plasma PN63A650 that has worked 4 8 years, until today. I turned it on, stays on for 14 seconds, then turns off for 8 seconds. Would not respond to remote commands either
Easy fix for new Samsung TV switching on and off power ...
? 4:41
https://www.youtube.com/watch?v=H0cG3lzjuw8
Sep 15, 2012 - Uploaded by alwaysafix
My tv turns on and off by itself the minute I plug in the cable. ....Samsung E6030 led tv hv blinkin red light issue ... capacitors are looking good ...
Help PLEASE! Samsung Plasma Turning On/Off Repeatedly.
michiganstate.247sports.com > Topics
247Sports.comMy Samsung Plasma HDTV (approx 3.5years old) has some issues as of late. When Iturn the tv on, invariably, it starts to turn off and back on repeatedly.
Samsung Smart TV turning off - Forums - CNET
www.cnet.com > Forums > Samsung
CNETJun 11, 2015 - I have a Samsung plasma 60 inch model number PN60E6500EFXZA TV. It began to turn itself off every 5 minutes, for the past few days. I was able to factory ... Samsung TV Keeps turning off and on.
Jun 11, 2015
Samsung TV Keeps Shutting Down
Jun 11, 2015
Samsung Plasma TV turns off by itself
Jun 22, 2011
My Samsung 50 in PN50B650 turns off by itself then on again ...
Apr 30, 2010
More results from www.cnet.com
Jan 13, 2016 | Samsung Televison & Video
SAMSUNG PROBLEMS - Red and Green Shading All Over Screen
adjust vscan  vs & va voltages on power supply, if not that drive pcb's are bad
Jun 05, 2009 | Samsung LN-S4051D 40 in. LCD Television
Clicking noise when turning on the tv. Everything works but the clicking.
When you turn your tv off turn it off using the remote control then turn off the tvs switch itself... Try this for a few days hope it works for you.
Thanks.
Jun 22, 2008 | Akai PT5492S 54" Rear Projection...
Clicking noise sony bravia kdl-40v3000
Normal 0 My kdl-46v4100 has been off all day and I've heard two or three clicks. It sounds exactly like the click you hear when it’s been off all day and you go to turn it on. A few minuets after it clicked I turned it on and to my surprise there was NO click sound.
This LCD TV (like most large displays) uses an Active Matrix of thin film transistors, aka TFT. Essentially the screen is a large array of transistors and capacitors. According to my previous observations; I suspect the random clicks are associated with the LCD circuitry providing a fresh “standby charge” to the TFT array (hence no click on power on following a “refresh”).
Not a solution, but an explanation other than “cooling off…”
Nov 29, 2007 | Televison & Video
GE Side by Side Model: GSH25VGRECC Refrig.
I had luck with a board with a clicking relay by replacing capacitors C29 and C30, which had bulged tops. Bravo, fridge works!
Oct 18, 2007 | Refrigerators
Televison & Video Logo
37 people viewed this question
Top Televison & Video Experts
Electro Med Services...
