Just bout a Philips SDW1850/17 antenna rotor and ended up w/ no manual, I thought I wired it right. Silver wire to terminal one?? I can't reall tell on the motor where #1 is? Anyway, I have no manual and the motor doesn't turn. The control box clicks off degrees on the digital readout, but nothing up top
  • cesater May 30, 2009
    no dice e-Guru - wired correctly followed all step sycronized and all - nada
    Got it fixed - had to open the motor case where the internal DC motor was installed crooked and locked up - all is fine now - Thanks Anyway
    President:
  • 1,197 Answers
Good to know that u got it fixed.....
Posted on May 31, 2009
    Brigadier General:
  • 3,917 Answers
Please download the user manual from the link bello which would give you a correct picture how to hook it up correctly.
http://www.retrevo.com/search/v2/jsp/mytrevo/myTrevo.jsp?page=man
Thank You
Posted on May 30, 2009
Do i need an antenna to recieve FM radio?
Yes. Stereo receivers typically have either screw terminals or a coax connector on the back for an FM antenna. You can use a TV antenna for this since FM radio is in the middle of the old TV VHF band. However, if the station you want is nearby, you can pick it up with a piece of telephone hookup wire (solid 28 gauge copper) connected to the antenna screw terminal (strip the insulation off the end of the wire that is connected to the terminal, but leave the rest of the insulation on). If you have only a coax connector, slip the end of the wire into the center terminal on the connector. The wire ideally should be about 30" long, but you may get by with less.
For more distant stations, you may want a long-range TV antenna.
Mar 22, 2015 | Audio Players & Recorders
Whining silver box on top of engine.
Go to the dealer and ask a part person to look at it.
Jan 17, 2014 | 2000 Mercury Cougar
My laptop which is hp 620 wireless connection switches on and off
I would have posted this in a Clarification, or Comment, but only have Post Solution option available at the moment. (SNAFU apparently in FixYa at the moment)
From your statements, it leads me to believe Electrolytic Capacitors; are failing in your wireless router. If it is an AT& T model, this carries relevancy. They have 'caps' that go bad.
Or perhaps the wireless module in the laptop is failing; or wireless antenna wires going to wireless module, are loose. (Loose connections)
!O_O!
http://h20000.www2.hp.com/bizsupport/TechSupport/DocumentIndex.jsp?contentType=SupportManual&lang=en&cc=us&docIndexId=64179&taskId=101&prodTypeId=321957&prodSeriesId=4158863#2
Bold black subheading - Service and maintenance information
Click on the blue file name -
Compaq 320, 321, 420, 421, 620 and 621 Notebook PC and HP 420 and 620 Notebook PC
This is a Service Manual. (Free)
It is in PDF file form.
The computer you are using now has Adobe Reader on it, which uses PDF files.
After you click on the above file name, it may take up to 30 seconds, before the first page comes up.
(Took 6 seconds just now using medium speed DSL connection)
Page 24. (Adobe Reader PDF page number at top)
Illustrated Parts Guide.
Page 26 look at number 22.
Page 30 at bottom. No.22 is the WLAN module.
(Wireless LAN module )
Page 19. Location of WLAN module.
ALL power removed, (AC adapter {Charger}, and Battery) Large bottom cover is removed to access it.
Page 66 - WLAN Module
WLAN Module - HP part number - HP 593836-001, or HP 504593-003
http://www.ascendtech.us/hp-593836-001-wireless-wlan-network-card_i_ltphp593836wifi.aspx
Click on the photo to enlarge. Note the gold plated contact pins in front. The WLAN Module plugs into the motherboard, using these contacts.
Tougher to explain; See the AS of Ascendtech?
Right above them is a small round gold plated terminal.
IF I am correct the White wire, from the Wireless Antenna, connects to it. (Terminal -> 1)
The Black wire connects to the other, small round gold plated terminal. (Terminal -> 2)
YOU will know for sure when you look at it.
The two Wireless Antenna wires, MUST go back they way they were originally, if removed.
Point;
The connector on the ends of the two Wireless Antenna wires, that go on the WLAN Module terminals, are flat female spade connectors.
They have a spring loaded 'Tang'. When removing the Wireless Antenna wire connector; the connector is slid off, pulling the connector back from the wire side. (Do NOT pull on wire, though!)
'Corrosion' can develop, on those small round gold plated terminals, on the WLAN Module.
It is advised to use a pencil eraser, and clean them.
(Gold isn't supposed to corrode. Just a term I used to try, and explain)
Rub the eraser all around the small terminal, and into the small shape of the terminal. The eraser will conform to the shape of the terminal, after rubbing a bit. (Eraser wears to the shape)
Suggest clean both terminals. Use air to remove the eraser dust.
(Keep your little fingers OFF of those terminals though! Your body carries Static electricity)
You can use a can of compressed air for computers, if available; or air pressure from your mouth will be sufficient.
Also clean the 'spade' connectors for each Wireless Antenna wire.
I know the eraser does not fit inside the connector. However after rubbing with the eraser for a small period, the eraser shape should conform, and be able to get in pretty deep.
Remove eraser dust with air.
If the connectors on the Wireless Antenna wires, seem to be loose on the WLAN Module terminals; GENTLY see if you can squeeze the connectors, using a pair of pliers. (Connector NOT on WLAN Module terminal, when you do!)
Check for fit. Must fit pretty tight.
Reconnect Wireless Antenna wires to WLAN Module.
Try this. If to no avail, suggest replacing WLAN Module.
(Get the correct one. Use it's HP part number)
[ Just for edification;
The two wires, Black, and White, of the Wireless Antenna; connect to the WLAN Module.
They then route up through the body of the laptop, (Through Channels, and Latches), up through the right Hinge.
(Look at Page 95 in the Service Manual)
From the right Hinge they feed up into the Display Assembly.
This is what the WLAN Transceiver with wireless antenna wires, assembly looks like, not installed in the laptop,
http://www.ecrater.com/p/16225279/hp-compaq-620-625-wireless-antenna-set#
The silvery cylindrical looking object on the left side, connected to the White wire; and the object above it, connected to the Black wire; are installed in the LCD screen assembly ]
For additional questions please post in a Comment.
Regards,
joecoolvette
Nov 20, 2012 | HP 620 T4500 15.6 320/4GB PC
How to wire a coil on a 1989 chevy 2500 with a 5.7 vortec engine?
No. 1 cylinder. Reinstall the spark plug and wire.3 Install the distributor, making sure the gasket is in place, and with the rotor facing the No. 1 cylinder. With the curvature of the gear on the distributor and camshaft, the rotor will turn about 30 degrees when meshed. Place the distributor shaft in the hole, but hold the distributor high enough so that it does not contact the gear. Point the rotor toward the No. 1 cylinder, then rotate it counterclockwise about 30 degrees and insert the distributor. If the rotor does not point in the right direction yet, lift the distributor and turn the rotor a little farther and insert it again until it points to the No. 1. If the rotor keeps lining up wrong, remove the distributor all the way, and insert the long screwdriver in the hole. Turn the oil pump drive a little, then try the distributor again.4 Install the distributor hold-down clamp and bolt. Loosely tighten the bolt so the distributor can still be turned.5 Rotate the distributor so that the vacuum advance, if there is one, is an equal distance from the firewall and the carburetor. Lay the distributor cap on, and pay attention to a spark plug wire terminal location in relation to the rotor. Once you've found a spark plug terminal that is very close to the rotor end, make a mark on the distributor housing directly below the center of the terminal location. Remove the cap, and rotate the distributor housing so the mark just made is exactly under the rotor end. Move the distributor housing counterclockwise another 5 degrees, and tighten the distributor hold-down bolt with a wrench.6 Install the distributor cap, paying attention to which terminal the mark is under and which terminal is closest to the rotor end. Use a screwdriver to tighten the hold-down screws on the cap.7Install the No. 1 spark plug wire in the terminal in front of the rotor end. Install the remainder of the wires in a clockwise direction using the firing order 1-8-4-3-6-5-7-2.
  • Sep 29, 2011 | Cars & Trucks
    My robin subaru 11hp gen just stopped producing elect
    Hi and welcome to FixYa, I am Kelly.
    Robin 11 Hp I am guessing here... RGV6100 (Model?)
    Things to look for:
    1. Open the control panel and inspect the capacitors and the YELLOW wires from the capacitors going to the stator. Look for signs of wax leakage from the long silver 28 MFD capacitors. You would see it in the bottom of the control panel enclosure. Probe the capacitors with a meter on a resistance (ohms) scale of R X 10,000. You should see a huge jump in resistance and then the meter drifts to infinity. Reverse the test leads looking for the same indication.
    2. Inspect for any loose connections from the control panel to the stator. Look for dark or hot connections. Repair as needed.
    _________________________________________________________________________________
    Stator checks
    * STATOR
    (1) Measure the insulation resistance between
    BLUE lead and the core.
    (2) Measure the insulation resistance between
    WHITE lead and the core.
    (3) Measure the insulation resistance between
    YELLOW lead and the core.
    (4) Measure the insulation resistance between
    BROWN lead and the core.
    AC Winding
    White / Red = 0.2 Ohm
    Black / Blue = 0.25 Ohm
    Condensor Winding
    Yellow / Yellow = 0.58 Ohm
    * ROTOR
    Measure the insulation across one of the soldered
    terminals of the rotor and the core
    Then test across the 2 soldered terminals of the rotor.
    Resistance = 1.75 Ohm
    NOTE 1 :
    Because a diode is soldered to the coil ends at
    the terminals, resistance may be measured only
    when tester probes touche the terminals in one
    combination of polarity. Therefore, if no resistance
    reading appears, try checking in reverse polarity.
    Diode rectifier test (Lovated between the 2 capacitors)
    Orange wire should read to all of the other terminals.
    Both Brown wires should read to the Brown White wire (Note polarity)
    Those are pretty much the checks that you can do and should reveal where the problem lies.
    I think you may have a burned wire / terminal somewhere inside the control panel.
    Usually when they just stop working the failures are
    1. The rotor (Bad and horribly expensive news)
    2. Capacitor wires (Yellow) open
    3. Stator wires damaged.
    The stators on these units do not usually fail.
    All manuals for this unit can be found here (Owner's / parts / Service)
    http://www.robinamerica.com/productsupport.aspx?pid=28
    If the link doesn't work use:
    http://www.robinamerica.com Choose Power products and then customer support. Manuals.
    This should give you something to work with. Thanks for choosing FixYa,
    Kelly
    Aug 31, 2011 | Electrical Supplies
    If you have 3 white and 3 black as well as a ground,how do you hook it up ?
    If I understand correctly, your are replacing a GFCI receptacle with another GFCI receptacle
    And your existing GFCI has 3 black and 3 white wires
    And there is not a switch involved in the changeover.
    I downloaded the manual from Lutron
    http://classic.lutron.com/CMS400/techinfopage.aspx?id=22163
    Every wiring diagram in manual shows:
    Black wires connect to brass-colored screws
    White wires connect to silver-colored screws
    The brass and silver colored screws are typical of all residential receptacles. The color-code tells the electrician which terminal gets the black and white wires.
    Are you having a problem putting 3 wires onto 2 screws?
    It is a common problem.
    You can buy a short piece of white and black wire at hardware store
    Lets work on the black wires as example:
    Strip back insulation on short piece of black wire
    Hold together two of your black wires and start twisting them together
    Now add the short wire to the two black wires you started twisting
    Now twist together the two blacks and short black
    So three wires are twisted together and you have a short lead that can connect to screw on GFCI
    Put a wire nut over the twisted wire
    Now you're ready to connect other end of short black wire to brass-colored screw
    This reduces the number of wires that connect to screws
    http://waterheatertimer.org/How-to-twist-electric-wire.html
    http://waterheatertimer.org/How-to-select-right-wire-nut.html
    Oct 20, 2010 | Lutron NTR-20-GFCI VAREO 20A GFCI...
    I have 1988 pontiac grand prix se with 2.8 v6 i have 3 spark plugs on the back and 3 on the front i replaced the the spark wire but i dont know what wire gose where in the spark coile
    this engine is turned sideways in the engine compartment. looking at the front of the engine, where belts and pulleys are mounted, the odd number cylinders are on the left, the even to the right. starting from the front of the engine, counting towards the rear, the cylinders are numbered 1, 3, 5 on the left and 2,4,6 on the right. remove the spark plug in the number one cylinder and place a peice of tissue in the hole. now crank the engine in very short bursts. as soon as you hear the engine crank, let off the key. check for the tissue to fly out of the spark plug hole. once the tissue flies out, the number one piston is up. now you need to take the cap off the coil, and see where the rotor is pointed. hold the cap over the rotor to see which terminal lines up with the rotor contactor. connect one end of the plug wire to the corresponding terminal, and the other end to the number one cylinder spark plug after it is reinstalled. from here the coil terminals are numbered in a clockwise direction. the firing order for your engine is 1-2-3-4-5-6, so you just connect one end of a plug wire to the number two terminal, and the other end to the spark plug in the number two cylinder. repeat this procedure for the remaining wires,
    Jan 21, 2010 | 1988 Pontiac Grand Prix
    Three wires melted.....
    Possibly....usually a melted wire indicates a bad connection. Can you solder or crimp the wires to the compressor?
    May 01, 2009 | Intertherm Heating & Cooling
    Philips Home Theater Speaker Wire (can it be cut?)
    Sure you can, Joel.
    Put the speakers wherever they will go, and cut the wire from the speaker to whatever length you need to reach your wall terminals. Leave some slack so you can move the speakers if needed. Strip off whatever length of insulation you need to make the terminal connection. Note that the speaker wire will have some kind of polarity marking. There will be a colored stripe or other mark on the insulation, or the conductors themselves may be different colors (usually one wire is copper, and the other tinned so it's silver colored). It doesn't matter which you use for positive as long as you're consistent and use the same one for each speaker.
    At the other end where the prewiring comes out for your home-theater system, splice the connector ends you cut off onto the installed wires, following the same polarity. I recommend using an appropriate size insulated **** splice to make the connection. The crimper and splices can be found at auto parts stores, Radio Shack or most hardware stores. It's quick, reliable and makes sure there are no bare wires to short out.
    Plug the speakers into the system and you should be good to go. Whip up some popcorn and enjoy the show!
    Jan 28, 2009 | Philips HTS-3565 Theater System
    GPS antenna
    If it is an RS 120 or an RS112 antenna you do not need to change it.These are both active antennas in other words they do all the gps computing in the unit itself. You need to look at the wire from the antenna. If it is a coax cable(2 wire) it will not work.If it is 3 or 4 wires it will work. If 3 wire (red ,silver yellow) just hook up color for color.If 4 wire you are going to have to figure out the wiring for it from the units wiring diagram.That could be a big enough pain that you might be inclined to change to the new antenna. If you wire the new RS125 antenna you must wire it to the seatalk buss. The seatalk wires are Red Silver and Yellow.The wire from the RS125 are red yellow silver green and brown.Wire as follow to your sea talk cable.Yellow to Yellow, red to red , silver to silver, green to red, brown to silver.
    Hope this helps.
    Jun 04, 2008 | Raymarine C80 GPS Receiver
    Televison & Video Logo
    179 people viewed this question
    Top Televison & Video Experts
