Question about Husqvarna 23 Hp 48" Deck Yard Tractor
Need help identifying bagger #24893 part
Have a YTH 2348 Husqvarna with a DR lawn vacuum attached. However, DR sent a very strange looking hose/chute connector that is bizarre. You have to cut the hole yourself in this giant piece of plastic.
So, if any of you have the 24893 attached to your Husqy I would appreciate the name of...and the part model number of the piece of the bagger asembly that attaches to the deck as well as the lower portion of the hose connection assembly if there is more than one piece.
I thank you.
SOURCE: I have a Husqvarna YTH 2348 the deck anti sway bar
Once you've straightened it - you've finished the hard part. Now take the end without the pin and stick it into the hole located on the transmission frame (the metal piece that the transmission sits on.) It is directly under the seat. The hole is on the front side of the tranny frame. Once you have it all the way in, take the pin end and put it through the mower deck brace (right side.) There is a hole there also for this end. If it doesn't go through enough to get the washer and pin through, push the mower deck towards the anti-sway bar. It should give a lot since the anti-sway bar is off. Once you fasten it, your'e done!
I only know this because it just happened to me today. I have the same mower as you, so I thought I would share.
Posted on Jul 04, 2009
  • 24 Answers
SOURCE: bagger problems
I would say is to run the mower at high rpm's and slow the tractor speed down and not take full cuts.
Posted on Aug 23, 2009
brado83
  • 106 Answers
SOURCE: belt replacement on a husqvarna yth 2348 mower
do you need to know the belt configuration for this mower ive attached a user manual that shows the configuration and all adjustments on the deck and belt...
http://72.3.225.179/manuals/YTH2348-ow-e-96045000502-420798_r0.pdf
Hope this helps
Kind Regards
Brad
Posted on Jan 02, 2010
SOURCE: chute for bagger keeps getting clogged
John Deere LA 125. Chute keeps clogging up with grass.
Posted on May 01, 2010
daneinwv
  • 124 Answers
SOURCE: what battery size and voltage
My name is Dane and I am going to try to help you solve your problem.
Your battery should be a 12VDC 330 AMP.
I hope I
Posted on Dec 04, 2010
Show me how to start a Husqvarna yth 2348 riding more
A copy of the manual is available here: http://www.manualslib.com/download/502577/Husqvarna-Yth2348.html
Apr 01, 2015 | Husqvarna Garden
How to start a Husqvarna yth 2348
Is the electric clutch bearing replaceable on the YTH 2348?
Not normally as they are staked in. It can be done but you need a way to re stake the new bearing so the clutch assy does not fall apart.
It probably best to just replace the clutch assembly and yes they are expensive. If can find the Warner or Ogura model on the clutch you may very find an aftermarket version to fit. You can even the OEM version for purchase outside Husqvarna network.
Jul 31, 2014 | Husqvarna Lawn Tractor 48" Deck, 23 Hp,...
I canot get a bagger kit for the 54inch cut lawn tractor in UK, can a 48, bagger be fitted and altered to fit which I can get in the UK
I have never seen a catcher for this size of deck, Husqvarna do not offer one, i am sure the deck aperture is different from the 48" machine, if the catcher is available in the US, would they just supply the upper and lower chutes? the 52" deck produces a vast amount of grass, so will fill the boxes very quickly, you would spend more time going back to the dumping area than actually mowing, mulching would be a much better option, if you have to collect would a tow sweeper not be better, it holds more grass, and you would not have issues with poor draught, and grass blocking in the chute ( a big problem with noise compliant machines, and damp grass , and side ejection )
Oct 10, 2012 | Husqvarna Lawn Tractor - 54in. Deck, 26...
Hello folks; My Husqvarna yth 2348 rider is very hard to start on the initial start. After once getting to run, it restarts easily with little hesitation or need of choke usage. Help please on how to start...
Sounds like your choke cable needs adjustment. Follow the choke cable to where it mounts on the carb.
Move the choke lever at the same time watching where it mounts to the carb. there is usually a clamp holding the cable in place, you may need to loosen the clamp and slide the cable back to make the choke fully close
Aug 30, 2011 | Husqvarna Lawn Tractor 48" Deck, 23 Hp,...
I was given a bagger for a husqvarna YTH20K46 riding mower. the bagger has a square base that looks like it should bolt to the back of the mower fram, but the four hole in the bagger attachment dont match...
It is made by AYP, how about you use google, find their website, purchase or download an illustrated parts breakdown and manual for it. This way you learn to help yourself. You are asking someone else to do for you what you can easily do for yourself. Hand a man a fish or teach a man to fish.
Mar 18, 2011 | Husqvarna Riding Lawn Mower 42 Inch Cut...
What battery size and voltage do I need for a YTH 2348
I hope I
Dec 04, 2010 | Husqvarna Lawn Tractor 48" Deck, 23 Hp,...
Belt replacement on a husqvarna yth 2348 mower
Hope this helps
Kind Regards
Brad
Dec 28, 2009 | Husqvarna Lawn Tractor 48" Deck, 23 Hp,...
Mtd bagger not bagging ...its 100 deg today grass is short and the tube keeps clogging up w /grass it wont go into the bagger .how can i fix the problem??? chris
The MTD web site has a list of items to check:
http://support.mtdproducts.com/cgi-bin/mtd.cfg/php/enduser/std_adp.php?p_faqid=68&p_created=1027017166&p_sid=tq2XafGj&p_accessibility=0&p_redirect=&p_lva=214&p_sp=cF9zcmNoPTEmcF9zb3J0X2J5PSZwX2dyaWRzb3J0PSZwX3Jvd19jbnQ9MTQsMTQmcF9wcm9kcz0wJnBfY2F0cz0wJnBfcHY9JnBfY3Y9JnBfcGFnZT0xJnBfc2VhcmNoX3RleHQ9YmFnZ2VyIGNsb2dz&p_li=&p_topview=1
Aug 10, 2009 | Gaiam Reel Lawn Mower Grass Catcher
Husqvarna 23 Hp 48" Deck Yard Tractor Logo
98 people viewed this question
Top Husqvarna Garden Experts
Jim Parker
Jim Parker
Phil Walker
Phil Walker
Are you a Husqvarna Garden Expert? Answer questions, earn points and help others
