Question about Homelite Garden
Starts but when throttled continues to die
Homelite weedeater starts, but when throttled dies homelite weedeater ut20002a starts then dies
  • 1,041 Answers
You have carburetor problems. You will need to take the carb. off and disassemble. Clean the carb. with carb. cleaner and use a Den Tek Brush, (used for cleaning teeth), for the small portals. Check the small screen in carb. to make sure it isn't clogged. The smallest of particals can cause the carb. problems. Check the gaskets as well. Depending on how old your trimmer is, you may have to buy a carb. kit and replace the Needle valve, appropriate gaskets, diaphragm, and small screen.
Jim
Posted on May 30, 2009
  • Jim Parker
    Jim Parker May 30, 2009
    Thanks for the rating firefeiter. If you have any questions on drywall finishing, or know someone who does, put your questions to Tools-Building & Power-Hand Tools at FixYa.com
    Thanks again,
    Jim
Carb settings for Homelite weedeater ST-275
Set both the H and L for 1 1/2 turn out from bottom, start and adj. The H for max rpm for full throttle, now set the low for good idle and very little or no hesitation when opening throttle. Now set H for max rpm again and then back off until you get more of rumble at full throttle.
May 31, 2017 | Homelite Garden
Correct fuel mixture for homelite zip start weedeater.25cc,ut20785..
50:1 five liters unleaded petrol and 100ml 2 stroke oil
Sep 09, 2014 | Homelite Garden
Homelite trimlite weedeater will start and idle in full choke position only. Cannot use any throttle or it dies. Cannot switch out of full choke or it dies. Cannot use any throttle to start it as well, if...
Fuel starvation either too the carb or in the carb itself, start with a simple cheap fix, replace the fuel filter in the tank on the end of the fuel hose.
Aug 16, 2013 | Garden
When i try too start the weedeater it either doesn't start or it acts like it is only firing half the time. Then it dies out.
check your compression on the weedeater needs to a min of 110 psi to run properly..email me with any questions on how to check the compression..whitejeff74@yahoo.com
Jul 25, 2011 | Homelite Garden
Have a Homelite mightylite 26ss String Trimmer. When i pull the trigger in the run position it cuts out and will shut off continuously. I checked the filter screen and it is clean(looks brand new). I've...
Let the engine warm at idle adequately before applying full throttle. With the engine warm, slowly bump the throttle and see if the response is good: if the engine wants to die again, let it continue warming at idle. If the problem persists, check that you are mixing your oil/gas mixture at the correct ratio: too much oil and you risk clogged the works.
Oct 07, 2010 | Homelite Mighty Lite Lawn Trimmer
Homelite whipper wont start. Replaced the primer
check your gas and oil mix remove the plug take some carb cleaner spray in plug hole pull start replace plug pull start if it fire you mix is wrong.....Good Luck
Aug 15, 2009 | Homelite Consumer Products 4.0 Amp, 13 In....
Starts then dies stihl fs45/weedeater
I sounds like it sucked up some debris in the bottom of the fuel tank and obstructed fuel flow somewhere. Start by blowing out the in-tank fuel filter (You will have to fish it out with something), then load the line with carb cleaner (wear safety glasses) put fuel filter back in line and crank it a few times to pull the carb cleaner into the carb. This may dislodge the obstruction. If this doesn't work, you will have to remove and cleant he carburator. Hope this helps.
Jul 04, 2009 | Homelite Mighty Lite Lawn Trimmer
You have a dirty carburetor or a carburetor in need of new parts. Disassemble carburetor. Clean with carb. cleaner and use a Den Tek Brush, (used for cleaning teeth), for the small portals. Check the small screen in carb., making sure that it's free of debris. Reassemble and see if it works properly. If it doesn't, then you will need to buy a carb. kit and replace the small screen, needle valve, appropriate gaskets, and diaphragm. This should do it.
Jim
May 30, 2009 | Homelite Garden
Garden Logo
1,302 people viewed this question
Top Homelite Garden Experts
Jim Parker
Jim Parker
roeb
Mike Squire
Are you a Homelite Garden Expert? Answer questions, earn points and help others
