Question about GE DBXR463EDWW Electric Dryer
Cant get drive belt back in place
I unhooked the drive belt on my GE model DBXR463ED1WW so that I could get the drum out to replace the rear bearing. Now I cant seem to get the belt back inplace. I have tried to route the belt and then position the idler pulley and also to route the belt around after the pulley is already into position and I just cant seems to get it back in place. Does the idler pulley just rest against the corner of the frame back where the blower motor is or is my problem that I have this mispositioned?
    President:
  • 2,992 Answers
You might find this site helpful. Good pictures and a sense of humor!
Posted on May 30, 2009
Why is it now squealing when in spin mode
If your dryer is the kind with rotating drums, might be a bearing. You should disassemble it and check if can be replaced
Dryer Repair Replacing the Drum Bearing GE Part WE3M26
Dryer Repair Replacing the Rear Drum Bearing Assembly Frigidaire Part...
Dryer Repair Replacing the Rear Drum Bearing Kit Part 1 GE Part WE25M40
GE Dryer Repair Noisy or Screeching Rear Drum Bearing WE25M40
you can fine more youtube video tutoriala looking in google for terms
Youtube DRUM DRYER
Sep 02, 2015 | Dryers
GE electric dryer (model #: DRSR483ED2WW) sounds like grinding metal when dryer starts/runs
you need to replace the rear drum bearing by removing the front panel lower screws and then remove the top cover and lean back and secure so as not to break wires to control panel,then remove drum belt,lift out drum and replace with bearing kit
Feb 01, 2010 | Dryers
GE Dryer DDE7900 squeaking.
it could be the drum belt that has glazed from age or the front drum glides/rollers or even a rear bearing on the drum
Nov 14, 2009 | Televison & Video
Hi, my GE model DBXR463ED1WW dryer is LOUD!
Roaring could be an over firing burner or fan related. Squeak or rumbles are bearings. Is the noise all the time or only when the burner is on? Eric
Jun 20, 2009 | GE DBXR463EBWW Electric Dryer
No air flow no blockage
did you put the vent back together right, it might be as simple as a wire came off while doing the bearings, check all connetions on your wires first it is a seald system on the exhaust, so the fan that pulls the air out is the problem
May 30, 2009 | GE DBXR463EDWW Electric Dryer
Clothes not drying but back panel of dryer extremely hot
Disconnect power. Next, you will have to remove the screws passing through the front panel into the front edge of the top so the top can be swung back. Remove the screw on each side near the top which are holding the front panel onto each side panel. Set the front panel off to the side. (most times you do not have to remove any wires to do this) Use your long thin arms to reach under the left side of the drum to unhook the drive belt. Now, you can remove the drum out the front of the dryer. Inspect the heating coils for breakage. Replace them with a new element set WE11x10007. (includes instructions, but don't stretch them as much as they say, so that you can leave a little tension on them as you install them. You don't want them too long) Replace the rear drum bearing WE3X75 to get rid of the squeak. Inspect the front drum slides (which support the drum at the top of the front panel) to see if they need replacement also.
May 24, 2009 | GE DBXR463EDWW Electric Dryer
Clothes get caught between drum at front of dryer
the drum has either worn out its felt(front), a fabric bearing, or the roller(rear) bearings, or both, and dropped enough to make a gap. new rollers are3 about $15 /pair, felts between $13 & $90 depending on model.
Generic replacement is simple, and really while you got it apart, do both, the strain of twisting off axis will make the remaining good end fail shortly
The generic steps may not be correct for the actual dryer model.
Felt seal
for most dryers,
Go buy HiTemperature silicone adhesive (tube)
tools required couple pairs locking pliers/visegrips screwdrivers
Unplug dryer
remove the front cover, either
  • couple screws at the bottom and spring clips to pop off with a screw driver OR
  • couple of spring clips to hold the top lid on, then screws top and bottom of both sides
    examine the case to find the exact mounting
unclip cables from door switch
set front panel aside
unhook drive belt from tensioner pulley
pull drum forward and out
remove old felt
scrape off old adhesive
put adhesive per instructions (some 2 surfaces some 1) on drum/felt
clip felt in place on drum with visegrip at 1 point
stretch felt around drum, gluing and clipping in place with vicegrips as you go
allow glue to set
reassemble in reverse order
Roller bearings
for most dryers,
tools required needle pliers/visegrips screwdrivers
Unplug dryer
remove old rollers:
  • pry triangular circlip from axle post
  • discard circlip
  • remove and discard roller
  • install new roller
  • install new circlip
    ALWAYS replace rollers in pairs
wow took longer to type than it actually takes to do it
Jul 22, 2008 | GE Dryers
GE,Dryer,dbxr463ed1ww,
It sounds like the belt broke off. Unless you have replaced even just the belt before,you need a experienced repairman, trust me.....
May 30, 2008 | GE DBXR463EBWW Electric Dryer
I am hearing a very loud chirping noise as my dryer works. I have disassembled the dryer in an effort to find the source of the noise. I found no obvious breakage. I intend on replacing the tub drive belt...
The rear drum bearing is the most common place I see noise on this unit. You will also won't to check the front pads the drum rides on and the idler pully for the belt. GE parts can get expensive so I would look it over good before buying anything.
May 15, 2008 | GE Dryers
How to replace drum belt.
Opening the cabinet and removing the drum of GE dryer models
Note:
Disconnect the power source to your dryer before you begin to remove the drum. Either unplug the unit from the wall outlet, remove the appropriate fuse from the fuse box, or flip the appropriate breaker in the circuit breaker panel.
Pull your dryer out from the wall. Behind it, on the bottom, you will find a lower panel that will give you access to the unit's belt tensioner (also known as an idler pulley arm). Remove the screws holding this panel in place, and then remove the panel itself. Reach inside and release the belt tension by removing the belt from the motor pinion.
Older GE dryer models have a small drum bearing inspection plate in the center of the back of the dryer. This drum bearing inspection plate provides access to the dryer's circlip (also known as an e-ring). This clip holds the rear drum shaft in place. Newer models do not have this circlip or the drum bearing inspection plate.
If yours is an older GE model with an inspection plate, remove the plate now. It will be held in place with a single screw. With the plate removed, you will be able to see the drum support shaft and the e-ring (circlip) holding the shaft in place. Use a small screwdriver to remove the e-ring. You may also want to use a magnet to keep the circlip from falling into the dryer. You will also find several metal and nylon shims between the bearing and the e-ring, inside the bearing, and between the bearing and the drum. Take careful note of how they come off so that you will be able to put them back on again in the right order.
Now remove the front panel of the dryer. There are a couple of different ways this is accomplished. Whichever method you use is dependent upon your model. Some older models have two spring catch clips under the cabinet top, one on the left side, and one on the right side of the front. Use a putty knife, or some other flat and thin object to wedge in under the cabinet top. Release both spring catches and lift the cabinet top off the dryer. In some newer models, there will be screws joining the cabinet front panel to the cabinet top. You will have to open the door in order to find these screws. Once they are found, remove them and then slide the cabinet top forward and lift it off the unit.
Next, there are two screws located in the bottom of the front panel, one in each corner. Loosen these, but do not remove them just yet. Locate and remove the two screws at the top inside of the dryer's front panel. Again, there is one screw in each corner. Proceed to remove the other two screws you have just loosened. Disconnect the door switch wires and then lift the front panel off your dryer. With the front panel removed, lift the drum and slide it out of the dryer.
NOTE: In some models, you will have to remove the dryer drum glides before you can remove the drum. Also, now that the interior of your dryer is completely exposed, it might be a good time to vacuum out all of the dust and lint that has built up in there.
Feb 05, 2008 | Dryers
GE DBXR463EDWW Electric Dryer Logo
254 people viewed this question
Top GE Dryers Experts
Dave Harrison
John Tripp
John Tripp
vince
Are you a GE Dryer Expert? Answer questions, earn points and help others
