Question about Epson Stylus cx7450 All-In-One InkJet Printer
Scanner stop working afte spring clip fell and I replaced it. "E" error on top pannel.
My epson scanner "pop" the belt tensioning spring-clip on the belt. I open the scaner and put it back. It report "E" on the display. It also reports "Not ready, No connected"
DECK BELT KEEPS COMING OFF--
MOST probably needs a new belt. Or, if you recently replaced belt, it's the wrong size (too long).
Make sure you get right sized belt, and get Kevlar belt - non-Kevlar belts wear out and stretch sooner.
May 26, 2014 | Cub Cadet Garden
How do i replace the belt which has broken on my tumble dryer
Pop the top (spring clips) ... remove the front (screws) ... pull the drum out ... clean everything! ... find the belt tensioner which clips into the floor ... get a new belt ... put it around the drum ... through the tensioner ... around the motor pulley ... reassemble,
Jun 21, 2010 | Indesit IS70C Electric Dryer
Heats up but drum wont spin
Belt broken. Pop the top ... held on by spring clips ... remove the front. Put on the new belt. The tensioner clips into the floor.
Mar 10, 2010 | Dryers
Need To Change Belt Can You Go Through The front or the back. How do you change the belt.
Pop the top - it is held down by spring clips. See the belt? Is it tight? Be careful of the finish. Use a putty knife or a screw driver.
No? remove the front panel be careful of the door switch wires. Set it aside - remove the drum. Clean everything. Find the tensioner near the motor. With help from a assistant, put the belt around the drum, through the tensioner, around the motor pulley. Set the drum, replace the front panel, pop the top down.
Allow 2 hours for this job. Get the belt where applicance parts are sold.
Thanks for your question at FixYa.com
Feb 24, 2010 | Dryers
How do i fit a new belt to my white knight cl447 wv dryer
Pop the top (spring clips) remove the front - use care with the wires. Find the belt tensioner on the floor of the dryer. Do a complete cleaning of the inside. Put the new belt around the drum get an assistant to help you hold the drum while you thread the belt through the tensioner and place the tensioner in the tensioner holder slots sin the floor. Put the front back on, snap the top back down.
Feb 17, 2010 | Dryers
Fan belt replacement
Pop the top - it is held in place by spring clips. Lift it up ... you should see the belt. If you can lift the belt, it is broken - if you don't see it, it is broken. If you see it and can't move it, you have a different problem.
Broken belt, remove the front panel - be careful of the door wires.
The drum will fall free - remove it. Pay attention to the belt tensioner. It snaps into the floor. The belt goes through the tensioner and around the motor pulley.
Get a replacement at a appliance parts place or from a FixYa.com advertiser.
Thanks for your interest in FixYa.com
Jan 09, 2010 | Dryers
How do you change the drum belt
remove the top (generally spring clips), remove the front (spring clips and/or screws) the drum will fall out.
Check the small tensioner on the bottom of the machine. There are two slots for the tensioner to sit in. make sure it is in the slots.
Put the new belt around the drum, get on the floor, pull a loop of the belt through the tensioner and place it around the motor pulley.
Get up ... get help, put the drum in place, replace the front panel, drop the top down, give it a try. If it works, pop the top down and bingo - you are done
Thanks for using FixYa.com
Please vote
a
Dec 04, 2009 | Lands Phones
My Maytag washer will agitate without clothes in it but will not agitate with clothes in.
The belt is not doing it's job. It could be that the belt is worn, if so a replacement can be bought from a Maytag dealer. It is also possible that the belt is just not under the proper tension. Maytag motors are mounted in a slide, and tension is applied by a spring. if the grease in the slide gets old and hard, the slide will stick making for a loose belt. To access, you'll need to remove part of the cabinet. Pop the top loose at the front, remove two screws at the top of the front panel, and release the clips at the bottom to remove the front panel. Free up the slide with some light motor oil and re-assemble.
Jul 12, 2009 | Maytag HAV3460AWW Top Load Washer
Clothes get caught between drum at front of dryer
the drum has either worn out its felt(front), a fabric bearing, or the roller(rear) bearings, or both, and dropped enough to make a gap. new rollers are3 about $15 /pair, felts between $13 & $90 depending on model.
Generic replacement is simple, and really while you got it apart, do both, the strain of twisting off axis will make the remaining good end fail shortly
The generic steps may not be correct for the actual dryer model.
Felt seal
for most dryers,
Go buy HiTemperature silicone adhesive (tube)
tools required couple pairs locking pliers/visegrips screwdrivers
Unplug dryer
remove the front cover, either
  • couple screws at the bottom and spring clips to pop off with a screw driver OR
  • couple of spring clips to hold the top lid on, then screws top and bottom of both sides
    examine the case to find the exact mounting
unclip cables from door switch
set front panel aside
unhook drive belt from tensioner pulley
pull drum forward and out
remove old felt
scrape off old adhesive
put adhesive per instructions (some 2 surfaces some 1) on drum/felt
clip felt in place on drum with visegrip at 1 point
stretch felt around drum, gluing and clipping in place with vicegrips as you go
allow glue to set
reassemble in reverse order
Roller bearings
for most dryers,
tools required needle pliers/visegrips screwdrivers
Unplug dryer
remove old rollers:
  • pry triangular circlip from axle post
  • discard circlip
  • remove and discard roller
  • install new roller
  • install new circlip
    ALWAYS replace rollers in pairs
wow took longer to type than it actually takes to do it
Jul 22, 2008 | GE Dryers
Replacing Belt on Jenn Air CLothes dryer
1. Disconnect power
2.Use Putty knife and push in to release two spring catches between top and front panel about 3 inches from either side. Top then lifts up. Undo two hex screws on either side of side panels close to top. Front panel then tilts forward. Un-clip door switch and wiring harness before lifting off front panel. If belt is broken, drum should lift off by slowly raising front of drum to disengage wheels at rear of drum.
3. clean accumulated lint from inside fan housing and duct work on front panel as well as from total inside of dryer base before placing new belt around drum, smooth side up before carefully replacing drum in place to engage two wheels at rear of drum.
4. reaching left hand under drum, raise spring loaded idler arm and place ribbed side of belt around pulley on end of motor with right hand before releasing idler arm to provide tension on belt.
5. Place front panel on bottom clips and reengage door switch wiring harness before reattaching hex screws at top of side panels.
6. drop top pannel of unit in place to reengage spring clips before reconnecting power
Dec 24, 2007 | Dryers
Epson Stylus cx7450 All-In-One InkJet Printer Logo
69 people viewed this question
Top Epson Office Equipment & Supplies Experts
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
