Question about Stainless Steel 40,000 BTU Propane Patio Heater
Outdoor propane patio heater wont light
I cant get my outdoor gas heater to start
  • jimd684574 Jun 02, 2009
    how does one go about replacing the thermocouple on a patio gas heater? is this a fairly standard part that can be purchased at most hardware stores? how simple is it to replace?
    thanks,
    President:
  • 1,197 Answers
Hi before u cud go to replace the thermocouple.... there are other reasons too why ur patio gas heater doesnt light up or stay lit.... plese refer the picture below... it tells u the possible causes... only after checking all the possible causes can u be sure that the problem is with th thermocouple.....
if u feel the thermocouple needs to eb replaced... here is how u do it... before u do it.. u wud need a wrench and a screwdriver...
  • Shut off the gas valve on the water heater and the gas valve on the line near the heater. Remove outer and inner doors, and loosen the pilot and supply tubes and the thermocouple connections to remove the burner assembly.
  • Step 2 Loosen the screw holding the thermocouple to the bracket. Remove old thermocouple. Bring it with you to the store to ensure you are buying the proper replacement.
  • Step 3 Install the new thermocouple. Position the thermocouple so that the pilot flame heats 1/2 inch of the tip.
  • Step 4 Reinstall burner assembly in the water heater. Tighten burner supply tube, pilot tube and thermocouple connections. Tighten thermocouple no more than a quarter turn more than hand-tight.
  • Step 5 Turn on both gas valves. Check supply tube and pilot tube for leaks with soapy water. If soap bubbles, tighten connections to fix leak. Ignite the pilot light, and make sure the thermocouple tip is heating up. Replace inner and outer doors.
    note:
  • While both doors are off, vacuum the burner compartment and check the water heater for water leaks.
  • Follow instructions on water heater to reignite the pilot light.
  • here is a video link on how to replace a thermocouple of a generic water heater... u can use this as a guide......
    http://videos.howstuffworks.com/discovery/34524-gimme-shelter-replacing-a-thermocouple-video.htm
    you can get the thermocouple at ebay for a lesser cost... or you can get them at any one of the following websites...
    http://www.thefind.com/appliances/info-heater-thermocouple
    http://www.drugasar.co.uk/spares/300370.html
    thank you good luck
    Posted on Jun 02, 2009
    • 355 Answers
    I would change the thermocouple and here is why:
    The thermocouple is the pilot's, well, co-pilot! It is the electronic device that senses if the pilot flame is hot enough to sustain burning the gas fuel from the burner. If the thermocouple thinks it's safe, then it keeps open the main gas valve located in the pilot assembly. If the thermocouple does not sense enough heat from the pilot flame (such as when the pilot is out), then the thermocouple shuts off the gas valve to the burners.
    How the Thermocouple Works
    So what is this thing and how does it work? Well the thermocouple (technically called a thermocouple junction) is a device that contains two metal wires welded at the ends and placed inside a protective metal case. The thermocouple sensor is found at the business end of the pilot flame and is designed to be placed in the hottest part of the flame. The other end is connected to the pilot valve body. As the thermocouple heats up, it produces a small amount of electricity and when it gets hot enough from the pilot, send a signal to open the gas valve by using a solenoid operated by a 24 volt transformer. The thermocouple calls the shots, and by converting heat to an electrical signal, it allows the gas valve to open or close. Once the gas valve is open, gas is then constantly supplied to the pilot and as required for the gas burners (as called for by the thermostat). If the pilot goes out, then the thermocouple gets cold and produces no electric signal to open the gas valve's solenoid and the gas valve shuts off the gas supply to the pilot and burners
    Posted on May 30, 2009
    • Rohit  Asthana
      Rohit Asthana Jun 02, 2009
      you can get a part from here
      http://www.patioheaters4u.com/spares.htm
      or
      Patio heater burner will not light?
      1. Allow 30 seconds for the LPG gas to reach the chamber before trying to light the patio heater burner.
      2. If the burner will not light and you cannot smell gas turn off the patio heater controls and check for blockages - see above.
      3. If there are no blockages and the patio heater thermocouple is working OK (pilot lights quickly) remove the patio heater's electromagnetic valve (located at the rear of the gas control valve) and if worn or damaged replace with a new electromagnetic valve.
      4. If the patio heater burner will not light and you can smell gas, turn off and check for leaks - see above leakage test.
      5. Next
        check the piezo igniter for a spark. If there is no spark remove the
        flame screen - see above. Turn the LPG gas supply to OFF position and
        check the piezo igniter. The piezo igniter should close to the patio
        heater thermocouple, if it has dislodged so the spark cannot reach
        adjust it until a spark can be seen. If the piezo igniter is failing to
        produce a spark check the igniter lead is connected to the rear of piezo igniter.
      6. To
        test the patio heater piezo igniter is working OK remove the ignition
        lead at rear of the igniter, place thumb over end and press the red
        button - you should feel a small sting. A new patio heater piezo
        igniter, see piezo igniter AFX470 for commercial patio heaters, piezo igniter AFX475 for domestic patio heaters and piezo igniter AFX477 for electronic commercial patio heaters, should be fitted according to the manufacturer's instructions.
      7. If
        you cannot smell gas and the pilot and burner will not light, check the
        tilt switch (if fitted) function. A failed tilt switch on patio heaters
        will prevent the LPG gas entering the gas control valve. Older patio
        heaters will have a factory fitted mercury tilt switch, newer patio heaters are fitted with mechanical tilt switch type A or mechanical tilt switch type B.
    • Rohit  Asthana
      check this guideline for better understanding
      http://www.patioheaters4u.com/PatioHeate...
    BernzOmatich3200n
    Repairing Benzomatic Patio Heater
    The above link unfortunately states Benzomatic no longer provides parts for their patio heaters. There may be a comparable generic part out here that you can substitue for the original part.
    Tall Propane Patio Heater Starting Striker Switch
    The second link shows an igniter switch that may work. You can find other possiilities by doing a search on the web for" Propane Heater igniter switch"
    May 16, 2014 | Stainless Patio Heaters - Steel Deluxe...
    I have a nexgrill propane patio heater the pilot light works but when i turn it to lo or high after a minute or so the pilot light stays on but the burner wont light
    Propane Patio Heater Troubleshooting - YouTube
    ? 6:54
    www.youtube.com/watch?v=BqYIWuDUZOUDec 12, 2008 - Uploaded by PatioShoppers Great tips about troubleshooting your outdoor patio heater. ...Pilot Light Won't Stay Lit - How to Replace a Broken Thermo Couple on Furnace ...
    May 12, 2014 | Williams 2509612 Ceramic Mid-Size Heater
    Portable patio heater is a DCS Phoenix Professional Patio Heater Model PHF8-DWBZ-L. Burner ignites and operates for a few minutes. Then teh flame is reduced to a short yellow flame. Regulator is covered...
    The regulator covered with frost is the problem. It freezes the gas and the gas line up. But, usually this only occurs when it has been exposed to subfreezing (in the teens) temperature for a long period of time. The quick fix, is to soak a bath towel in hot water, ring it out and quickly wrap it around the regulator. Once it thaws, the gas will start flowing again and you can light the burner. Generally, once it's flowing and being used, it won't freeze up again, right a way. Most propane companies add ethanol to the propane in the winter, to help keep it from freezing in the lines and the regulator.
    Hope this helped answer you question and provided, at least a quick fix solution.
    Apr 21, 2011 | DCS PHFS Phoenix III Outdoor Patio Heater
    All Pro patio heater modle SPC54PHW, PHB, PHT, PHS. Pilot will not light and burner will not light.I installed a new regulatoe, propane tank is full. Took the gas pipes apart from bottom to top and no...
    If your propane tank has an OPD valve.. in other words if when the tank is disconnected and you open the tank valve and no gas escapes..it's an OPD valve..these are pretty much standard especially on the exchangeable tanks.
    The problem sometimes is at the connection hose..it too of course must be an OPD connector to depress the internal ring on the tank valve before any gas will come out.
    Chances are the knurled knob is either cross threading or is cracked..and won't snug up enough to depress that internal ring on the tank valve. Or you have miss matched components.. unlikely if you bought genuine replacement parts.
    The All Pro Heater you have requires a specific part (fitting) to be added when using a universal regulator (Part number 6122) which is a 3/8 connector male.
    This of course is assuming you hear no gas hissing.. cannot light it manually..
    Sounds simple..but I have seen this problem on outdoor BB'Q's many times.. cracked knob on the connector hose and a few times simply backing it off and putting it back on.. tight enough to depress that ring..
    Best of luck!
    Apr 12, 2011 | Stainless Patio Heaters - Steel Deluxe...
    Im not getting enough fuel pressure to create a decent flame, everything lights as it should and stays lit but its not letting enough pressure out. Could it be the pressure regulator on the line thats...
    Check what type of fuel, if using butane on cold days it will stuggle to stay alight, always use propane on outdoor patio heaters, propane will work in vvery low temperatures. If using propane check for leaks, do a leakage test, found this patio heater specialist site very useful.
    Feb 21, 2011 | Endless Summer Blue Rhino 235000...
    I have a propane patio heater that is not getting gas to the igniter how do i fix...
    I've been told spiders can block outdoor gas lines,try to remove any blockage
    Dec 11, 2010 | Rta International Patio Heater
    Main Heater will not light off
    turn the gas on real slow. The air in the line is blowing out the pilot
    Aug 26, 2009 | Stainless Patio Heaters - Steel Deluxe...
    Kirkland outdoor heater will not stay lit
    The thermocouple is bad. That is the part right next to the pilot light that sense's the flame and hold the gas valve open to the pilot. Take the old thermocouple off and go to hard ware store and get a 18" one of what ever length you need and replace. 5 dollar part.
    May 31, 2009 | Stainless Patio Heaters - Steel Deluxe...
    Heating & Cooling Logo
    1,068 people viewed this question
    Top Stainless Heating & Cooling Experts
    paulcarew
    Dan Webster
    Dan Webster
    Donni Steen
    Are you a Stainless Heating and Cooling Expert? Answer questions, earn points and help others
