Question about Craftsman 42 in. Deck 19.5hp Lawn Tractor
19.5 hp B&S engine surges .
When trctr is running it surges low speed to high speed,Does this when cutting and when not. I cleaned plugs,wires,filters etc...Checked gas,all fine.Just started doing this after using last weekend. When it was parked that it was fine.
  • Alan Callison
    Alan Callison May 31, 2009
    It smoothes out a small bit but then it will die out.
  • Dwain Pippen May 11, 2010
    Wil it smooth out if you choke it a bit?
  • 376 Answers
It's hard to say without actually checking it out, but I would say it's a fuel delivery problem. I would have the carb cleand/repaired. That most likey will sovle the problem
Posted on May 31, 2009
Settings for mixture screws
Most Chain Saw Engines Have Three Carburetor Adjusting Screws:
1. Idle Speed/Throttle Stop - This is the adjustment that controls how much the throttle valve (butterfly) stays open when the throttle trigger is released. If this adjustment is set too low, the engine will die when the throttle trigger is released. The throttle valve (butterfly) simply cuts off the supply of combustible air/fuel and the engine stops. If this adjustment is set too high, the high idle speed will cause the centrifugal clutch to engage and the chain will run. This is a dangerous condition and should never be allowed.
2. Low Speed Fuel Adjustment (marked L on carb, this is the low speed jet)- This is the adjustment that controls the proportion of fuel in the combustible air/fuel mixture at idle speed. An adjustment that is set too rich will cause the engine to load up and die at idle speed. A mixture that is too lean will starve the engine and cause it to race or surge. An extremely lean adjustment will cause the engine to die, too.
3. High Speed Fuel Adjustment (marked H on carb, this is the high speed jet) - This is the adjustment that controls the proportion of fuel in the combustible air/fuel mixture at cutting speed. It would not be accurate to say that this is the most important setting, because all of these adjustments need to be accurate for a saw to perform its best, but this is the adjustment that determines how the saw runs in the cut. An adjustment that is set too rich will not allow the saw to reach the RPM level necessary to build maximum power. Throttle response may also be sluggish and the engine would smoke and perform poorly. A mixture that is too lean will allow the engine to reach an RPM level where bearing failure and cylinder seizure are likely. It will also lack power in the cut and tend to run very hot.
The preceding information briefly explains rich and lean running conditions. It also identifies the three adjustment screws and their function. It should be noted that some chain saws lack the high speed adjustment needle. These saws have what is called a "fixed jet" which is set from the factory. "Fixed jet" carburetors are used to prohibit the saw operator from setting the adjustment too lean and damaging the saw. Unfortunately, they also often prohibit the saw from achieving maximum performance.
Apr 11, 2016 | Garden
How to adjusted the high and low in a ryobi rcs3535c4
The initial hi and low jet settings are in the owner's manual or sometimes stamped on the side cover next to the carburetor. If you do not have a manual go to lawnandgarden.manualsonline.com to get one.
Oct 04, 2013 | Garden
How do I adjust the carburator?
There are two needle screws that can be adjusted to make the engine run properly. Be certain that the carburetor is clean and the diaphragm is in good condition, and the fuel is new. The two needle screws mentioned above should initially be adjusted at one turn open from turned in all the way (lightly seated). Each of these needle screws performs different functions. One is for idle and throttle response (this screw is marked "L" and the other screw is marked "H". L and H are marked on the carburetor body and also on the plastic "shroud" near the adjustment screws. These screws are not interchangeable, being foolproof since the thread sizes are not the same. When properly adjusted the low speed screw (L) allows the engine to idle properly and throttle response will work properly. When the high speed screw is adjusted properly the engine will have correct power at full speed. Adjust the low speed screw so that the engine idles and when you squeeze throttle all the way to wide open the engine should not hesitate and should come up to full speed and when you drop the throttle it should idle nicely without stalling. Now adjust the high speed screw. Hold throttle wide open, holding it there while you adjust the high speed screw. If this scares you (be carefully so that the spinning chain does not cut you!) you may adjust the high speed screw at idle, turning it just slightly in or out. The high speed screw should be adjusted so that the engine does not run clean at wide open throttle but sputters slightly, slightly adjusted open from running clean to slightly sputtering. When under load (cutting a log) the engine should run clean. Good luck!
May 21, 2012 | Husqvarna , No.455 Rancher, 20" Gas -...
My Homelite ZR10926 16-Inch 33cc Ranger it is starting, idling, it dies when I accelerate it. I assume is the carburetor, maybe ? thank you.
It probably is not getting enough fuel. Check the filter in the tank. If it has been sitting with stale gass this filter plugs up.
Try running the engine with some choke. If this helps, try adjusting the carburetor high speed screw.
Jun 04, 2011 | Homelite ZR10926 16 Chain Saw
Coleman Powermate 3000 surging
Check your air filter to make sure it is clean, especially if the gen. has been run in dirty, dusty conditions. Make sure the gas tank vent is not clogged.
Also, pour some combustion cleaner into the carb. through the air intake to clean the carb. It sounds like it is starving for gas.
Hope this helps.
Rob
Sep 27, 2009 | Coleman Powermate Premium Plus 6250W...
Describe your Poulan "" Push
Please change your are filter,or clean it, I hope this helps you and thank you
Sep 10, 2009 | Poulan "" Push Mower
91 honda accord cut off
Here are the most common causes of surges, stalls at stops, low erratic idle speed, rough idle and engine hesitation (and other problems), it is in most cases the idle speed control air-bypass valve and or throttle valve and upper intake, these area's get full of gunk and combustion residue over the miles and cause idle issues (stalls, low idle) like yours, Get a can of intake cleaner from any local parts store, not carb spray, intake cleaner, it is made by a company called CRC, remove the air intake hose to the engine, hold the idle high so the engine won't stall, then spray the can of cleaner into the intake while keeping the engine running, use at least 1/2 the can, shut down the engine and disconnect the battery for 5 minutes, then restart and complete a number of mixed driving cycles, town, freeway, stop and go etc., after a few days the problem will go away as the system will relearn to the clean intake
Apr 06, 2009 | 1991 Honda Accord
Pump will not work in high speed
Only three posible problems. High is out on pump. Spa side control is out. Control box relay that runs high pump is out.Does upper controls(spa side) read out a code? Kirk
Feb 12, 2009 | Jacuzzi MAGNUM FORCE POOL PUMP - TWO SPEED...
Dodge ram 1500 engine rpms surge at freeway speed
those sensors could cause the issue, clean the MAF 1st, also clean the idle system using the following procedure, the IAC can cause cruise surge. I use this to cure these problems all the time.
Here is the most common cause of surges and stalls and low idle, it is the idle speed control air-bypass valve (IAC) and throttle valve, they get full of gunk over the miles and cause idle issues (stalls, low idle) like yours, Get a can of intake cleaner from any local parts store, not carb spray, intake cleaner, it is made by a company called CRC, remove the air intake hose to the engine, hold the idle high so the engine won't stall, then spray the can of cleaner into the intake while keeping the engine running, use at least 1/2 the can, shut down the engine and disconnect the battery for 5 minutes, then restart and complete a number of mixed driving cycles, town, freeway, stop and go etc., after a few days the problem will go away as the system will relearn to the clean intake.
Jan 13, 2009 | 2001 Dodge Ram 2500 Truck
Craftsman 42 in. Deck 19.5hp Lawn Tractor Logo
250 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Dean Gruber
Roland W VanLue
Roland W VanLue
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
